Vage error
HellupUandMe
21 jan 2007
Ik ben bezig met een programma maar ik kan opeens m'n form niet meer opstarten.
Hij staat ingesteld als het form wat de gebruiker als eerst te zien krijgt.
Maar voordat ie het form geladen heeft zegt ie dit:
An error occurred creating the form. See Exception.InnerException for details.  The error is: Conversion from string "" to type 'Integer' is not valid.
Ik heb niks in "load" van m'n form staan dus daar kan het probleem niet inzitten.
Als ik verdere details opvraag over de fout beweert ie dit:
System.InvalidOperationException was unhandled
  Message="An error occurred creating the form. See Exception.InnerException for details.  The error is: Conversion from string \"\" to type 'Integer' is not valid."
  Source="Ellusoft Mathpats Calculator (Requested)"
  StackTrace:
       at Ellusoft_Mathpats_Calculator__Requested_.My.MyProject.MyForms.Create__Instance__[T](T Instance) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 190
       at Ellusoft_Mathpats_Calculator__Requested_.My.MyProject.MyForms.get_Form8()
       at Ellusoft_Mathpats_Calculator__Requested_.My.MyApplication.OnCreateMainForm() in C:\Documents and Settings\Laptop\Mijn documenten\Visual Studio 2005\Projects\Ellusoft Mathpats Calculator (Requested)\Ellusoft Mathpats Calculator (Requested)\My Project\Application.Designer.vb:line 35
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at Ellusoft_Mathpats_Calculator__Requested_.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
Heeft iemand misschien een idee?
Ik moet dit soort dingen ook gewoon niet meer hier vragen.
Op de meeste fora krijg je binnen een paar seconde antwoord, is het niet zo dat je geen antwoord krijgt en staan vragen van de vorige dag niet op dezelfde pagina.
Laat staan van 2 weken geleden.
Vaarwel
Geeft aan dat je ergens een getal hebt staan in plaats van een string.
Meest logische verklaring is meestal dat je een aanhalingsteken (per ongeluk) hebt weggehaalt. op
