<?php
* Class to dynamically create a zip file (archive)
* @author Rochak Chauhan
class createZip {
public $compressedData = array();
public $centralDirectory = array(); // central directory
public $endOfCentralDirectory = "\x50\x4b\x05\x06\x00\x00\x00\x00"; //end of Central directory record
public $oldOffset = 0;
* Function to create the directory where the file(s) will be unzipped
* @param $directoryName string
public function addDirectory($directoryName) {
$directoryName = str_replace("\\", "/", $directoryName);
$feedArrayRow = "\x50\x4b\x03\x04";
$feedArrayRow .= "\x0a\x00";
$feedArrayRow .= "\x00\x00";
$feedArrayRow .= "\x00\x00\x00\x00";
$feedArrayRow .= pack("V",0);
$feedArrayRow .= pack("v", strlen($directoryName) );
$feedArrayRow .= pack("v", 0 );
$feedArrayRow .= $directoryName;
$this -> compressedData[] = $feedArrayRow;
$newOffset = strlen(implode("", $this->compressedData));
$addCentralRecord = "\x50\x4b\x01\x02";
$addCentralRecord .="\x00\x00";
$addCentralRecord .="\x0a\x00";
$addCentralRecord .="\x00\x00\x00\x00";
$addCentralRecord .= pack("V",0);
$addCentralRecord .= pack("v", strlen($directoryName) );
$addCentralRecord .= pack("v", 0 );
$ext = "\x00\x00\x10\x00";
$ext = "\xff\xff\xff\xff";
$addCentralRecord .= pack("V", 16 );
$addCentralRecord .= pack("V", $this -> oldOffset );
$this -> oldOffset = $newOffset;
$addCentralRecord .= $directoryName;
$this -> centralDirectory[] = $addCentralRecord;
* Function to add file(s) to the specified directory in the archive
public function addFile($data, $directoryName) {
$feedArrayRow .= "\x14\x00";
$feedArrayRow .= "\x08\x00";
$uncompressedLength = strlen($data);
$compression = crc32($data);
$gzCompressedData = gzcompress($data);
$gzCompressedData = substr( substr($gzCompressedData, 0, strlen($gzCompressedData) - 4), 2);
$compressedLength = strlen($gzCompressedData);
$feedArrayRow .= pack("V",$compression);
$feedArrayRow .= pack("V",$compressedLength);
$feedArrayRow .= pack("V",$uncompressedLength);
$feedArrayRow .= $gzCompressedData;
$addCentralRecord .="\x14\x00";
$addCentralRecord .="\x08\x00";
$addCentralRecord .= pack("V",$compression);
$addCentralRecord .= pack("V",$compressedLength);
$addCentralRecord .= pack("V",$uncompressedLength);
$addCentralRecord .= pack("V", 32 );
* Fucntion to return the zip file
* @return zipfile (archive)
public function getZippedfile() {
$data = implode("", $this -> compressedData);
$controlDirectory = implode("", $this -> centralDirectory);
return
$data.
$controlDirectory.
$this -> endOfCentralDirectory.
pack("v", sizeof($this -> centralDirectory)).
pack("V", strlen($controlDirectory)).
pack("V", strlen($data)).
"\x00\x00";
* Function to force the download of the archive as soon as it is created
* @param archiveName string - name of the created archive file
public function forceDownload($archiveName) {
$headerInfo = '';
if(ini_get('zlib.output_compression')) {
ini_set('zlib.output_compression', 'Off');
// Security checks
if( $archiveName == "" ) {
echo "<html><title>Public Photo Directory - Download </title><body><BR><B>ERROR:</B> The download file was NOT SPECIFIED.</body></html>";
exit;
elseif ( ! file_exists( $archiveName ) ) {
echo "<html><title>Public Photo Directory - Download </title><body><BR><B>ERROR:</B> File not found.</body></html>";
exit;
header("Pragma: public");
header("Expires: 0");
header("Cache-Control: must-revalidate, post-check=0, pre-check=0");
header("Cache-Control: private",false);
header("Content-Type: application/zip");
header("Content-Disposition: attachment; filename=".basename($archiveName).";" );
header("Content-Transfer-Encoding: binary");
header("Content-Length: ".filesize($archiveName));
readfile("$archiveName");
class createDirZip extends createZip {
function get_files_from_folder($directory, $put_into) {
if ($handle = opendir($directory)) {
while (false !== ($file = readdir($handle))) {
if (is_file($directory.$file)) {
$fileContents = file_get_contents($directory.$file);
$this->addFile($fileContents, $put_into.$file);
} elseif ($file != '.' and $file != '..' and is_dir($directory.$file)) {
$this->addDirectory($put_into.$file.'/');
$this->get_files_from_folder($directory.$file.'/', $put_into.$file.'/');
closedir($handle);
