Privacywetgeving
Ik weet niet welke code je nu gebruikt, maar de gegevens moeten natuurlijk nog wel steeds uit de combobox komen.
Private Sub CmdOK_Click()
If CboBonnr.ListIndex > -1 Then
With Workbooks("Fustbon.xls").Sheets("Bon")
For j = 1 To 26
.Range(Choose(j, "N14", "N13", "L19", "O19", "L20", _
"O20", "L21", "O21", "L22", "O22", _
"L23", "O23", "L24", "O24", "L25", _
"O25", "L26", "O26", "D13", "D14", _
"D15", "G15", "D16", "E16", "L27", _
"O27")) = j
Next
Unload Me
For j = 1 To 26
"O27")).Value = [B]CboBonnr.List(CboBonnr.ListIndex, j)[/B]
Next
Unload Me
Code:Private Sub CmdOK_Click() If CboBonnr.ListIndex > -1 Then With Workbooks("Fustbon.xls").Sheets("Bon") For j = 1 To 26 .Range(Choose(j, "N14", "N13", "L19", "O19", "L20", _ "O20", "L21", "O21", "L22", "O22", _ "L23", "O23", "L24", "O24", "L25", _ "O25", "L26", "O26", "D13", "D14", _ "D15", "G15", "D16", "E16", "L27", _ "O27")).Value = [B]CboBonnr.List(CboBonnr.ListIndex, j)[/B] Next End With End If Unload Me End Sub
Wigi
OK het werkt naar behoren en ik heb het op deze manier gedaan.
Code:Private Sub UserForm_Initialize() CboBonnr.RowSource = Workbooks("Green Trees").Worksheets("Fust").Range("A4:Z" & Workbooks("Green Trees").Worksheets("Fust").Range("A65536").End(xlUp).Row).Address(External:=True) End Sub
Code:Private Sub CmdOK_Click() If CboBonnr.ListIndex > -1 Then With Workbooks("Fustbon.xls").Sheets("Bon") For j = 1 To 26 .Range(Choose(j, "N14", "N13", "L19", "O19", "L20", _ "O20", "L21", "O21", "L22", "O22", _ "L23", "O23", "L24", "O24", "L25", _ "O25", "L26", "O26", "L27", "O27", _ "D13", "D14", "D15", "G15", "D16", _ "E16")) = CboBonnr.List(CboBonnr.ListIndex, j - 1) Next End With End If Hide End Sub
Met vr gr
Jack:thumb:
Ik gebruik wel Excel 2007, misschien dat het daar aan ligt!
Met vr gr
Jack
En wat wil je nu met al die quotes zeggen?
Je weet toch dat ik in die laatste "oplossing" enkel code hebt geplakt (het stuk in het vet) dat al in eerdere posts in deze topic stond?
Ik heb de optie 2003 of 2007 maakt geen verschil uit , bij mij werkt het in de twee .
Heb het wel opgeslagen als fustbon en niet als Ctest(1) zoals ik een bepaalde code van jouw terug te vinden was .
Ok bedankt trucker10,
het werkt allemaal naar tevredenheid:thumb:
Bedankt voor je inzet:thumb:
met vr gr
Jack
