Welk Geheugen kan ik mee uitbreiden
  • Onderwerp starter Onderwerp starter DebZ
DebZ
2 apr 2009
Het volgende moederbord is in mijn bezit en ik wil graag het geheugen uitbreiden.
Nou heb ik al een beetje gezocht en gekeken maar het werd me onduidelijk wat nou wel of niet past :o dus vandaar mijn hulpvraag wat ik kan kopen.
CPU
• Supports 64-bit AMD® Athlon™ 64 processor (Socket 754)
• Supports 2800+, 3000+, 3200+, 3400+, 3700+
• Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+
Chipset
• VIA® K8M800-CE Chipset
- HyperTransport connection to AMD Next Generation of CPU
- 8 or 16 bit control/ address. data transfer both directions
- 800/600/400/200MHz "Double Data Rate" operation both direction
- AGP v3.0 compliant with 8X transfer mode
- On-board Graphic shared up to 64MB
• VIA® VT8237R Chipset
- Ultra DMA 66/100/133 master mode EIDE controller
- Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1
- ACPI & PC2001 compliant enhanced power management
- Supports 8 USB2.0 ports. (Rear x4/ Front x4)
Main Memory
• Supports two 184-pin DDR SDRAMs up to 2GB memory size
• Supports DDR400*/DDR333/DDR266 DDR SDRAM (*Refer to MSI recommended modules)
• Note: PC3200 (DDR400) maximum 4 banks (2 double-sided) only
Due to the High Performance Memory design, motherboards or system configurations may or may not operate smoothly at the JEDEC (Joint Electron Device Engineering Council) standard settings (BIOS Default on the motherboard) such as DDR voltage, memory speeds and memory timing. Please confirm and adjust your memory setting in the BIOS accordingly for better system stability.
Example: Kingston HyperX DDR500 PC4000 operates at 2.65V, 3-4-4-8, CL=3.
For more information about specification of high performance memory modules, please check with your Memory Manufactures for more details.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4x/8x slot
• Three PCI 32-bit Master PCI Bus slots. (support 3.3v / 5v PCI bus interface)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
On-Board IDE
• An IDE controller on the VT8237R chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 66/100/133 operation modes. It can connect 4 Ultra ATA drives.
• Serial ATA/150 controller integrated in VT8237R
- Up to 150MB/s transfer speed
- Can connect up to 2 Serial ATA drives
- Support RAID 0, RAID 1
Audio
• 6 Channel software audio codec VIA VT1617A
• Compliance with AC97' v2.3 Spec
• Meet PC2001 audio performance requirement
LAN
• VIA VT6103L 10/100 Mb/s PHY
• Supports 10/100 Mb/s auto-negotiation operation.
• Compliant with PCI v2.2 and PC99 standard .
• Compliance with ACPI Power Management
On-Board Peripherals
- 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial ports COM1
- 1 VGA port
- 1 parallel port supports SPP/EPP/ECP mode
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 3 audio ports in vertical (Line-out, Line-in, MIC)
- 1 RJ-45 jack
- 1 IrDA connector for SIR/ASKIR/HPSIR
Dimension
9.44in.(L) x 7.68in.(W) Micro-ATX Form Factor
Hopelijk kunnen jullie me helpen. :love:
WELKOM OP HELPMIJ
Wat er mogelijk is dat al in het overzicht.
Main Memory
Je kunt max 2gb kwijt met een mem max van pc3200
Hey Frank,
Bedankt voor je antwoord maar zover was ik zelf ook al :o
Wat ik echter niet snap is bijvoorbeeld het DDR of DDR1 etc etc.
Ik heb wat gezocht en kom dan op verschillende geheugens terecht maar met een enorm prijsverschil als je naar DDR of DDR2 kijk.
Zou bijvoorbeeld deze passen:"
KINGSTON 400MHz DDR2 PC2-3200 DIMM
Je moet dus DDR1 (oftewel gewoon DDR) geheugen hebben.
Oke jammer want die zijn veel duurder :(
Die ik net aangaf kost 25 euro en dezelfde maar dan DDR is 74 euro dus vandaar dat ik me af vroeg of DDR1 ook mogelijk zou zijn.
Topic bijgelezen......
en al voorstellen gedaan zie ik....
succes:thumb:
Het is nooit te laat :D
Maar thanx heren, inmiddels is het geheugen besteld en draait het lekker :cool:
