Branden met Nero foutmelding
oma sare
16 sep 2004
Ik heb al een paar keer geprobeerd om te branden met Nero( ik dacht dat het 9 is) maar krijg steeds een foutmelding.
Ik ben niet super in computers maar misschien dat iemand een oplossing weet.
Hier een logje.
1K22-1867-0795-66M4-5322-0164-****
Windows Vista 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
 (Nero Express)
Recorder:             <HL-DT-ST DVDRAM GSA-T40N>Version: JT03 - HA 1 TA 0 - 8.3.2.1
 Adapter driver:      <Serial ATA>              HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default
CD-ROM:               <HL-DT-ST DVDRAM GSA-T40N >Version: JT03 - HA 1 TA 0 - 8.3.2.1
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-T40N   E:   CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE           : 0
Physical memory     : 2037MB (2086252kB)
Free physical memory: 852MB (873180kB)
Memory in use       : 58 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.6.2009
UDF/ISO-compilatie
19:04:44	#1 Text 0 File SCSIPTICommands.cpp, Line 450
	LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
19:04:44	#2 Phase 112 File dlgbrnst.cpp, Line 1767
	DVD-Video files reallocation started
19:04:44	#3 Phase 114 File dlgbrnst.cpp, Line 1767
	DVD-Video files reallocation completed (no file modified)
19:04:44	#4 Text 0 File Isodoc.cpp, Line 6713
	UDF document burn settings
	Determine maximum speed : FALSE
	Simulate                : FALSE
	Write                   : TRUE
	Finalize CD             : TRUE
	Multisession            : FALSE
	Burning mode            : DAO
	Mode                    : 1
	UDF Mode                : UDF/ISO bridge
	UDF Options             : automatic
	UDF Revision            : 1.02
	UDF Partition Type      : physical
	ISO Level               : 1 (Max. of 11 = 8 + 3 char)
	Character set           : ISO 9660
	Joliet                  : FALSE
	Allow pathdepth more than 8 directories : FALSE
	Allow more than 255 characters in path  : FALSE
	Write ISO9660 ;1 file extensions        : TRUE
19:04:44	#5 Phase 111 File dlgbrnst.cpp, Line 1767
	DVD-Video files sorted
19:04:45	#6 ISO9660GEN -11 File Geniso.cpp, Line 3349
	First writeable address = 0 (0x00000000)
19:04:45	#7 ISO9660GEN -11 File Geniso.cpp, Line 3349
19:04:45	#8 Text 0 File Burncd.cpp, Line 3568
	Turn on Disc-At-Once, using DVD media
19:04:45	#9 Text 0 File FilesystemSettingsValidator.cpp, Line 142
	FS Settings: using validator 'CUDFSettingsValidatorDVD'
	ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
	Changing UDF revision from '1.02' to '1.02'
19:04:45	#10 ISO9660GEN -11 File Geniso.cpp, Line 3349
19:04:45	#11 ISO9660GEN -11 File Geniso.cpp, Line 3349
19:04:45	#12 Text 0 File DlgWaitCD.cpp, Line 311
	Last possible write address on media:  2295103 (510:01.28, 4482MB)
	Last address to be written:            1595855 (354:38.05, 3116MB)
19:04:45	#13 Text 0 File DlgWaitCD.cpp, Line 323
	Write in overburning mode: NO (enabled: CD)
19:04:45	#14 Text 0 File DlgWaitCD.cpp, Line 2932
	Recorder: HL-DT-ST DVDRAM GSA-T40N, Media type: DVD+R
	 Disc Manufacturer ID: <CMC MAG>, Media Type ID: <M01>, Product revision number: 0
	 Disc Application Code: 0, Extended Information Indicators: 7
19:04:45	#15 Text 0 File DlgWaitCD.cpp, Line 497
	>>> Protocol of DlgWaitCD activities: <<<
19:04:45	#16 Text 0 File ThreadedTransferInterface.cpp, Line 754
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 ()
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 1595856 (1595856) = #1595856/354:38.6
	    relocatable, disc pos for caching/writing not required/ required
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1595856 blocks [E: HL-DT-ST DVDRAM GSA-T40N]
19:04:45	#17 Text 0 File ThreadedTransferInterface.cpp, Line 956
	Prepare [E: HL-DT-ST DVDRAM GSA-T40N] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc fixated
	 Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    3268313088, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	        0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
	        0 |        1 |   0 |    0x41 |        0 |        0 | 0x00
	        0 |        1 |   1 |    0x41 |  1595856 |        0 | 0x00
	  1595856 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
19:05:02	#18 Text 0 File SCSIPTICommands.cpp, Line 240
	SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
19:05:02	#19 Text 0 File Burncd.cpp, Line 4359
	Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
19:05:02	#20 Phase 24 File dlgbrnst.cpp, Line 1767
	Caching of files started
19:05:02	#21 Text 0 File Burncd.cpp, Line 4481
	Cache writing successful.
19:05:02	#22 Phase 25 File dlgbrnst.cpp, Line 1767
	Caching of files completed
19:05:02	#23 Phase 36 File dlgbrnst.cpp, Line 1767
	Burn process started at 8x (11.080 kB/sec)
19:05:02	#24 Text 0 File ThreadedTransferInterface.cpp, Line 2673
	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:05:02	#25 Text 0 File Cdrdrv.cpp, Line 10164
	---- Disc Structure: Physical Format Information (00h) ----
	Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD+R (10), Part Version: 1.0x (1)
	 Disc Size: 120 mm,      Maximum Transfer Rate: <not specified> (F h)
	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
	 End Physical Sector Number of Data Area:          26053F h
	 Data in Burst Cutting Area (BCA) does not exist
	  Disc Application Code: 0 / 0 h
	  Extended Information indicators: 7 h
	  Disc Manufacturer ID: CMC.MAG.
	  Media type ID: M01
	  Number of Physical format information bytes in use in ADIP up to byte 63: 56
	 Media Specific [16..783]:
	    00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38    ...CMC.MAG.M01.8
	    23 54 37 18 00 3E 6E 00 - 70 62 15 15 0B 0B 08 08    #T7..>n.pb......
	    01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00    ................
	    01 00 38 38 00 1D 62 35 - 07 30 22 10 08 20 1C 01    ..88..b5.0".....
	    00 00 00 1D 62 35 07 30 - 22 10 08 20 1C 01 00 00    ....b5.0".......
	    02 00 54 70 02 38 5F 56 - 20 14 0B 0B 01 18 00 00    ..Tp.8_V........
	    00 00 02 3D 5D 7A 20 14 - 0C 0A 01 18 00 00 00 10    ...=]z..........
	    03 00 54 DF 02 1F 65 5A - 20 14 0C 0A 01 18 00 00    ..T...eZ........
	    00 00 02 06 67 86 20 14 - 0C 0A 01 18 00 00 00 89    ....g...........
	    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
19:05:02	#26 Text 0 File DVDPlusRW.cpp, Line 675
	Start write address at LBA 0
	DVD high compatibility mode: Yes
19:05:02	#27 Text 0 File ThreadedTransfer.cpp, Line 269
	Pipe memory size 83836800
19:10:14	#28 WINPFILE 1117 File winpfile.cpp, Line 348
	Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
	C:\Users\Sarien\Downloads\GrabIt Downloads\Guus Meeuwis[1]\VIDEO_TS\VTS_03_1.VOB
19:10:14	#29 TRANSFER 4 File TransferWriteFileItem.cpp, Line 169
19:10:14	#30 TRANSFER -25 File Reader.cpp, Line 253
	Error reading data
19:10:14	#31 Text 0 File Reader.cpp, Line 255
	Exception value: -1
19:10:37	#32 Text 0 File DVDPlusRW.cpp, Line 935
	EndDAO: Last written address 278048
19:10:37	#33 Phase 38 File dlgbrnst.cpp, Line 1767
	Burn process failed at 8x (11.080 kB/sec)
19:10:37	#34 Text 0 File SCSIPTICommands.cpp, Line 287
	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
19:10:39	#35 Text 0 File Cdrdrv.cpp, Line 11420
	DriveLocker: UnLockVolume completed
19:10:39	#36 Text 0 File SCSIPTICommands.cpp, Line 450
	UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Wat heb je geprobeerd te branden: een tekst, foto, muziek, ander bestand......? Waarop heb je het geprobeerd te branden, een CD of een DVD?
Welke opties heb je achtereenvolgens in Nero gekozen voordat het branden begon?
Svp alle vragen beantwoorden, anders wordt het ietwat lastig om zinvolle antwoorden terug te geven.
Met name de stappen (keuzes en muisklikken) die je hebt gemaakt vanaf het moment van het openen van Nero tot de feitelijke laatste muisklik waarna het branden begon, zijn belangrijk.
Schrijf ze svp stap-voor-stap op en post ze hier.
Heb geprobeerd om een muziek DVD te branden.
Ik ga naar Nero StartSmart
Rippen en branden
Videschijf branden
DVD-Video bestanden
Toevoegen
Video_TS
Vanonder bij bestanden en mappen toevoegen staat
DVD-Video bestandstypes (*.bup; *.vob; *.ifo)
Dan toevoegen in menu van bestanden en mappen toevoegen.
Kom ik weer in scherm bestanden en mappen toevoegen die ik dan wegklik op kruisje
Dan volgende dan branden en ik kan maar tot 17% branden.
Ik hoop genoeg info
@pasja: Staat eigenlijk al in het log-bestand: een of andere DVD van Guus Meeuwis, die wordt gebrand als een video-dvd, met als instelling Disc-at-once.
Lijkt erop dat bij het lezen van bronbestand VIDEO_TS\VTS_03_1.VOB een leesfout optreedt. Lijkt mij dat dat bestand corrupt is.
Tijs.
Ik wilde net beginnen te schrijven of jij de computer van oma sare kon 'zien' of dat jij dingen wist die ik niet wist, toen ik iets ontdekte wat ik nog niet eerder had ontdekt / gezien:
de 'afbeelding' van oma sare bevat een verticale schuif .............. :o :D
Verticale schuif?
Wat nu?
Hele bestand maar verwijderen en opnieuw proberen te downloaden?
Je eerste vraag, zie plaatje, (ik was zo gefocust op de inhoud van je bericht, dat ik die hele schuif gemist heb. Achteraf stom, want als ik nú naar je startbericht kijk, dan zie ik die schuif simpelweg loeigroot in beeld staan), je 2e vraag, ja, idd. opnieuw downloaden maar dan het liefst vanaf een andere bron.
    47,2 KB · Weergaven: 65
Heb em er al af gegooid.
Kan de DVD ook kopen natuurlijk:D
Bedankt toch voor het meedenken.
Probleem opgelost
:D Crash had de posting leesbaarder gemaakt door de log van een code-tag te voorzien (zie zijn opmerking onderaan de startposting).
Natuurlijk had ik liever een universele 'glazen bol' gehad, want die had ik dan ook bij andere vragen kunnen gebruiken! :D
@oma sare: Fijn dat u het allemaal zo sportief opneemt, en bedankt voor de terugmeldingen.
Tijs.
