Lightbox
stonechest
25 sep 2006
Als ik het goed zag heb je de aanroep van de JS-bestanden in de marker pas gedefineerd.
Zorg er eens voor dat die binnen <head> komen te staan.
Probeer het daarna nog eens.
Ik heb ze ook in de head geplaats maar dat doet ook niks.
Waar kan dit aan liggen? Hieronder staat het html bestand
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
    <title>Mijn omgeving op de kaart</title>
<link rel="stylesheet" href="css/slimbox.css" type="text/css" media="screen" />
<script type="text/javascript" src="js/mootools.js"></script>
<script type="text/javascript" src="js/slimbox.js"></script>
<script src="http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAOfchazHtZZ37S17QAZJnYhR8YNf7e9Sy3GXJ36ojijArf7NSHhQRVadDlax182XHXxxJAhV9QPeMZg&amp;sensor=false" type="text/javascript"></script>
<script src="http://www.google-analytics.com/urchin.js" type="text/javascript"></script>
<script type="text/javascript">_uacct = "UA-162157-1";urchinTracker();</script>
  </head>
<body>
<div id="map" style="width: 550px; height: 450px"></div>
<div id="sidebar"></div>
    //<![CDATA[
    if (GBrowserIsCompatible()) {
      // this variable will collect the html which will eventualkly be placed in the sidebar
      var sidebar_html = "";
      // arrays to hold copies of the markers and html used by the sidebar
      // because the function closure trick doesnt work there
      var gmarkers = [];
      // A function to create a tabbed marker and set up the event window
      // This version accepts a variable number of tabs, passed in the arrays htmls[] and labels[]
      function createTabbedMarker(point,label,tabs,icon) {
        var marker = new GMarker(point,icon);
        var marker_num = gmarkers.length;
        marker.marker_num = marker_num;
        marker.tabs = tabs;
        gmarkers[marker_num] = marker;
        GEvent.addListener(gmarkers[marker_num], "click", function() {
          marker.openInfoWindowTabsHtml(gmarkers[marker_num].tabs);
        // add a line to the sidebar html
        sidebar_html += '<a href="javascript:myclick(' + marker_num + ')">' + label + '</a><br>';
        return marker;
      // This function picks up the click and opens the corresponding info window
      function myclick(i) {
         GEvent.trigger(gmarkers[i], "click");
      // create the map
      // var map = new GMap2(document.getElementById("map"));
      var map = new GMap(document.getElementById("map"));
      map.addControl(new GLargeMapControl());
      map.addControl(new GMapTypeControl());
	  map.setCenter(new GLatLng(47.614495, -122.341861), 13);
      // Read the data from example.xml
      var request = GXmlHttp.create();
      var filename = "testxml.php";
      request.open("GET", filename, true);
      request.onreadystatechange = function() {
        if (request.readyState == 4) {
if ((request.status != 200) && (request.status != 304)) {
alert("file not found: "+filename);
return;
          var xmlDoc = request.responseXML;
          // obtain the array of markers and loop through it
          var markers = xmlDoc.documentElement.getElementsByTagName("marker");
          // alert("processing "+markers.length+" markers");
          for (var i = 0; i < markers.length; i++) {
            // obtain the attributes of each marker
            var lat = parseFloat(markers[i].getAttribute("lat"));
            var lng = parseFloat(markers[i].getAttribute("lng"));
            var label = markers[i].getAttribute("label");
            // alert("point["+i+"] label="+label+":("+lat+", "+lng+")");
            if (isNaN(lat) || isNaN(lng)) {
               alert("bad point "+i);
               continue;
            var point = new GLatLng(lat,lng);
            // get the tab info
            tabInfo = markers[i].getElementsByTagName("tab");
            tabs = new Array();
            if (tabInfo.length > 0) {
               // alert("processing "+tabInfo.length+" tabs");
               for (var j = 0; j < tabInfo.length; j++) {
                  var tabLabel = GXml.value(tabInfo[j].getElementsByTagName("label")[0]);
                  var tabHtml = GXml.value(tabInfo[j].getElementsByTagName("content")[0]);
                  // alert("point["+i+"] tab["+j+"] label="+tabLabel+", content="+tabHtml);
                  if ((j==0) && (tabInfo.length > 2)){ //  adjust the width so that the info window is large enough for this many tabs
                      tabHtml = '<div style="width:'+tabInfo.length*88+'px">' + tabHtml + '</div>';
                  tabs.push(new GInfoWindowTab(tabLabel,tabHtml));
            } else { alert("no tabs point "+i); }
            // create the marker
            var marker = createTabbedMarker(point,label,tabs);
            map.addOverlay(marker);
          // put the assembled sidebar_html content into the sidebar div
          document.getElementById("sidebar").innerHTML = sidebar_html;
      request.send(null);
    else {
      alert("Sorry, the Google Maps API is not compatible with this browser");
    </script>
</body>
</html>
Plaats hetzelfde stukje code vanuit de marker eens gewoon in je HTML.
Werkt dat wel?
