Gta iv
Mastaglazy
24 mei 2009
Kan mij pc wel GTA IV aan?
Dit is mijn pc:
Intel Pentium 4, 2.93Ghz
2gb Ram
Ati Radeon HD 4350, 512mb
Minimum systeemeisen
* Besturingssysteem: Windows Vista SP 1 / XP SP 3
* Processor: Intel Core 2 Duo 1,8 Ghz / AMD Athlon X2 64 2,4 Ghz
* Geheugen: 1,5 GB
* Harde schijf: 16 GB vrije ruimte
* Videokaart: 256MB NVIDIA 7900 / 256MB ATI X1900
Aanbevolen systeemeisen
* Besturingssysteem: Windows Vista - SP 1 / XP - SP 3
* Processor: Intel Core 2 Quad 2,4 Ghz / AMD Phenom X3 2,1Ghz
* Geheugen: 2 GB (Windows XP) / 2,5 GB (Windows Vista)
* Harde schijf: 18 GB vrije ruimte
* Videokaart: 512MB NVIDIA 8600 / 512MB ATI 3870
Bron;
http://www.pcgamespecial.nl/?itemid=8065
Oke maar mijn processor is die dan nog wel snel genoeg?
Dit is mijn results van de System Requirtments test:
CPU
Minimum: Intel Core 2 Duo 1.8GHz, AMD Athlon X2 64 2.4GHz
You Have: 2 processors running - Intel(R) Pentium(R) 4 CPU 2.93GHz FAIL: Sorry, your CPU does not meet this minimum requirement. It may be time to purchase a more powerful computer to make your life easier. Click the 'We Recommend' button to discover how you can.
CPU Speed
Minimum: 1.8 GHz
You Have: 2.93 GHz PASS
System RAM
Minimum: 1 GB for Windows XP / 1.5 GB for Windows Vista)
You Have: 2.0 GB PASS
Operating System
Minimum: Windows Vista - Service Pack 1 / XP - Service Pack 3
You Have: Microsoft Windows XP Home Edition (Build Service Pack 32600) PASS
Video Card
Minimum: 256MB NVIDIA 7900+ / 256MB ATI X1900+
You Have: ATI Radeon HD 4350 (ATI Radeon Graphics Processor (0x954F)) PASS
Video Card Features - Minimum attributes of your Video Card Video RAM: Required - 256 MB , You have - 1.0 GB
Video Card 3D Acceleration: Required - Yes , You have - Yes
Video HW Transform & Lighting: Required - Yes , You have - Yes
Vertex Shader Ver.: Required - 3.0 , You have - 3.0
Pixel Shader Ver.: Required - 3.0 , You have - 3.0
Video Card Driver Version (DirectX)
Your driver version number is: 6.14.10.6947 FYI: Your video card driver version is provided for your information, but it is not part of this analysis. But proper video card driver versions are important to the proper operation of your product.
Sound Card
Minimum: Yes
You Have: Realtek HD Audio rear output PASS
Sound Card Driver Version
Your driver version number is: 5.10 FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
Free Disk Space
Minimum: 16 GB
You Have: 32.8 GB
Oke ik zie zelf ook wel dat mijn processor net niet snel genoeg is. maar is er een kans dat hij hem mischien met alles op laag aankan?
Het programma kan nog niet zo goed overweg met dual cores, maar je zou geen probleem mogen hebben. Je kan de boel hooguit niet op het allerhoogst zetten.
Alles behalve de processor hoor, ik heb een Pentium 4, 3.0ghz
en je hebt een Intel Core 2 Duo 1.8GHz, AMD Athlon X2 64 2.4GHz nodig.
kan hij het wel aan?
ik hoop het wel, men videokaart en ram gaan zelfs dik over de Recommended heen.
Zou het gewoon testen als ik jou was. Volgens mij gaat het wel lukken, maar niet op zijn allerhoogst.
Oke want ik was al helemaal in paniek xD, omdat er dual core nogwatwhatever stond.
en ik heb een pentium 4 xD
ik kan farcry 2 ook makkerlijk spelen, maar heb wel maar 20-30fps maar daar heb ik geen problemen mee xD
kan farcry 2 hoogste resolutie en alles op high behalve shading en shadows, dat zuigt toch xD
CPU
@ stefan
Hoe goed heb jij gelezen?
Waar denk je dat ts de testresultaten die hij post vandaan heeft?
@ Mastaglazy
Ik weet niet of je in de gelegenheid bent om het spel te lenen van iemand om te testen of het werkt.
Het resultaat van de processor is namelijk toch een beetje vreemd. Dus testen lijkt me een goed plan voor je daadwerkelijk gaat kopen.
ik heb een pc die op jouwens lijkt en daar past gta iv wel op
ik heb
Windwos Vista
Geheugen : 3070
Video kaart : Nividia Geforce : 8400 GS
Processor : Duo Core 2.66 / 2.7
past prima
Dual core met Single core vergelijken lijkt mij niet het juiste advies.:rolleyes:
