Robertusje
- 11 nov 2007
Als ik nu de piratebay van Mininova open op mijn laptop krijg ik echter een pagina in het Engels.
Kan iemand mij vertellen wat dit is en wat ik moet doen.
Als ik Mininova van de piratebay openen op de PC is het gewoon in orde.
Dit is de pagina dus als er iemand weet wat dit is en hoe ik het kan herstellen .... heel graag:
Placeholder page
The owner of this web site has not put up any web pages yet. Please come back later.
You should replace this page with your own web pages as soon as possible.
Unless you changed its configuration, your new server is configured as follows:
Configuration files can be found in /etc/lighttpd. Please read /etc/lighttpd/conf-available/README file.
The DocumentRoot, which is the directory under which all your HTML files should exist, is set to /var/www.
CGI scripts are looked for in /usr/lib/cgi-bin, which is where Ubuntu packages will place their scripts. You can enable cgi module by using command "lighty-enable-mod cgi".
Log files are placed in /var/log/lighttpd, and will be rotated weekly. The frequency of rotation can be easily changed by editing /etc/logrotate.d/lighttpd.
The default directory index is index.html, meaning that requests for a directory /foo/bar/ will give the contents of the file /var/www/foo/bar/index.html if it exists (assuming that /var/www is your DocumentRoot).
You can enable user directories by using command "lighty-enable-mod userdir"
About this page
This is a placeholder page installed by the Ubuntu release of the Lighttpd server package.
This computer has installed the Ubuntu operating system, but it has nothing to do with the Ubuntu Project. Please do not contact the Ubuntu Project about it.
If you find a bug in this Lighttpd package, or in Lighttpd itself, please file a bug report on it. Instructions on doing this, and the list of known bugs of this package, can be found in the Ubuntu Bug Tracking System.
Placeholder pagina
De eigenaar van deze website is niet opgemaakt alle webpagina's nog niet. Please come back later.
U dient ter vervanging van deze pagina door uw eigen webpagina's zo spoedig mogelijk.
Tenzij je veranderd zijn configuratie, uw nieuwe server is geconfigureerd als volgt:
Configuratie-bestanden kunnen worden gevonden in / etc / lighttpd. Lees / etc / lighttpd / conf-available / README bestand.
De DocumentRoot, dat is de map waarin alle uw HTML-bestanden moet bestaan, is ingesteld op / var / www.
CGI-scripts worden gekeken in / usr / lib / cgi-bin, dat is waar Ubuntu pakketten zullen hun scripts. U kunt cgi module met behulp van commando "lighty-enable-mod-cgi".
Log bestanden worden geplaatst in / var / log / lighttpd en worden wekelijks gerouleerd. De frequentie van de rotatie kunnen gemakkelijk worden veranderd door het bestand / etc / logrotate.d / lighttpd.
De standaard directory index index.html, wat betekent dat de aanvragen voor een directory / foo / bar / geeft de inhoud van het bestand / var / www / foo / bar / index.html als het bestaat (in de veronderstelling dat / var / www is uw DocumentRoot).
U kunt mappen gebruiker met behulp van commando "lighty inschakelen USERDIR-mod"
Over deze pagina
Dit is een tijdelijke pagina geïnstalleerd door de Ubuntu release van de lighttpd server pakket.
Deze computer heeft geïnstalleerd, het Ubuntu besturingssysteem, maar het heeft niets te maken met de Ubuntu Project. Gelieve geen contact op met de Ubuntu Project over.
Als je een bug in dit pakket lighttpd of in lighttpd zelf, kunt u een bug report op. Instructies op dit te doen, en de lijst van bekende bugs van dit pakket, kan worden gevonden in de Ubuntu Bug Tracking Systeem.
Placeholder page
About this page
Placeholder pagina
Over deze pagina
