Java Runtime Environment Fatal Error
Virusbeatbox
18 dec 2007
Beste,
telkens bij het opstarten van mn laptop (Dell Vostro 1520) krijg ik op m'n bureaublad een notepad document met volgende mededeling:
[COLOR="Red"]#
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x10019b99, pid=1156, tid=2288
# JRE version: 6.0_16-b01
# Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode, sharing windows-x86 )
# Problematic frame:
# C  [SRLProxy_srl_4_1_13_0_a.dll+0x19b99]
# If you would like to submit a bug report, please visit:
#   [url]http://java.sun.com/webapps/bugreport/crash.jsp[/url]
---------------  T H R E A D  ---------------
Current thread (0x01cd0800):  VMThread [stack: 0x00a90000,0x00ae0000] [id=2288]
siginfo: ExceptionCode=0xc0000005, reading address 0x04c72dd0
Registers:
EAX=0x04c72dd0, EBX=0x00000001, ECX=0x4688afa4, EDX=0x77969a94
ESP=0x00adfa54, EBP=0x00adfa94, ESI=0x045609f8, EDI=0x10019b90
EIP=0x10019b99, EFLAGS=0x00010202
Top of Stack: (sp=0x00adfa54)
0x00adfa54:   1000f8ef 10019b90 96a6bb2a 00000000
0x00adfa64:   00000000 10000000 045609e8 045609f8
0x00adfa74:   04560a14 045609e8 00adfa5c 00adf668
0x00adfa84:   00adfae4 1000b430 860a9a5e 00000000
0x00adfa94:   00adfab4 1000f9a8 00000000 00000000
0x00adfaa4:   00000001 1000b0d2 00000001 00000000
0x00adfab4:   00adfaf4 1000b204 10000000 00000000
0x00adfac4:   00000001 96a6bb4a 00000001 00adfb14
Instructions: (pc=0x10019b99)
0x10019b89:   e8 81 14 ff ff 59 c3 a1 e0 04 02 10 85 c0 74 06
0x10019b99:   8b 08 50 ff 51 08 c3 6a 00 6a 01 b9 54 f0 01 10
Stack: [0x00a90000,0x00ae0000],  sp=0x00adfa54,  free space=318k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [SRLProxy_srl_4_1_13_0_a.dll+0xf9a8]
C  [SRLProxy_srl_4_1_13_0_a.dll+0xb204]
C  [SRLProxy_srl_4_1_13_0_a.dll+0xb26f]
C  [ntdll.dll+0x3e1c4]
C  [ntdll.dll+0x2a8dd]
C  [ntdll.dll+0x2a85f]
C  [kernel32.dll+0x23b69]
C  [msvcr71.dll+0x8d04]
C  [msvcr71.dll+0x8d11]
V  [jvm.dll+0x1e925d]
V  [jvm.dll+0x1e853e]
V  [jvm.dll+0x1e888c]
V  [jvm.dll+0x1e8cb2]
V  [jvm.dll+0x173e5c]
C  [msvcr71.dll+0x9565]
C  [kernel32.dll+0x44911]
C  [ntdll.dll+0x3e4b6]
C  [ntdll.dll+0x3e489]
VM_Operation (0x04b6f6c0): Exit, mode: safepoint, requested by thread 0x04165800
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x04164000 JavaThread "AWT-Shutdown" [_thread_blocked, id=4048, stack(0x046b0000,0x04700000)]
  0x04165800 JavaThread "Timer-3" [_thread_blocked, id=5764, stack(0x04b20000,0x04b70000)]
  0x04163000 JavaThread "Browser Side Object Cleanup Thread" [_thread_blocked, id=3872, stack(0x04a30000,0x04a80000)]
  0x04162800 JavaThread "Windows Tray Icon Thread" [_thread_in_native, id=880, stack(0x049e0000,0x04a30000)]
  0x04162400 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=4804, stack(0x04990000,0x049e0000)]
  0x041a2000 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=4392, stack(0x04940000,0x04990000)]
  0x04136800 JavaThread "Java Plug-In Heartbeat Thread" [_thread_blocked, id=4756, stack(0x040d0000,0x04120000)]
  0x0414d400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=224, stack(0x04660000,0x046b0000)]
  0x0413e400 JavaThread "Java Plug-In Pipe Worker Thread (Client-Side)" daemon [_thread_in_native, id=1932, stack(0x044e0000,0x04530000)]
  0x04133c00 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=4200, stack(0x04080000,0x040d0000)]
  0x04131400 JavaThread "Timer-0" [_thread_blocked, id=4988, stack(0x04030000,0x04080000)]
  0x01d28000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3820, stack(0x03e90000,0x03ee0000)]
  0x01d23c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=4256, stack(0x03e40000,0x03e90000)]
  0x01d22400 JavaThread "Attach Listener" daemon [_thread_blocked, id=3132, stack(0x03df0000,0x03e40000)]
  0x01d17800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4060, stack(0x03da0000,0x03df0000)]
  0x01cd6800 JavaThread "Finalizer" daemon [_thread_blocked, id=2436, stack(0x00b90000,0x00be0000)]
  0x01cd2000 JavaThread "Reference Handler" daemon [_thread_blocked, id=5304, stack(0x00b00000,0x00b50000)]
  0x00af9c00 JavaThread "main" [_thread_blocked, id=1268, stack(0x007b0000,0x00800000)]
Other Threads:
=>0x01cd0800 VMThread [stack: 0x00a90000,0x00ae0000] [id=2288]
VM state:at safepoint (shutting down)
VM Mutex/Monitor currently owned by a thread:  ([mutex/lock_event])
[0x00af7680] Threads_lock - owner thread: 0x01cd0800
Heap
 def new generation   total 960K, used 164K [0x23b30000, 0x23c30000, 0x24010000)
  eden space 896K,  11% used [0x23b30000, 0x23b49048, 0x23c10000)
  from space 64K, 100% used [0x23c20000, 0x23c30000, 0x23c30000)
  to   space 64K,   0% used [0x23c10000, 0x23c10000, 0x23c20000)
 tenured generation   total 4096K, used 1513K [0x24010000, 0x24410000, 0x27b30000)
   the space 4096K,  36% used [0x24010000, 0x2418a528, 0x2418a600, 0x24410000)
 compacting perm gen  total 12288K, used 3536K [0x27b30000, 0x28730000, 0x2bb30000)
   the space 12288K,  28% used [0x27b30000, 0x27ea40a8, 0x27ea4200, 0x28730000)
    ro space 8192K,  63% used [0x2bb30000, 0x2c049920, 0x2c049a00, 0x2c330000)
    rw space 12288K,  53% used [0x2c330000, 0x2c9a4dd0, 0x2c9a4e00, 0x2cf30000)
Dynamic libraries:
0x00400000 - 0x00424000 	C:\Program Files\Java\jre6\bin\java.exe
0x77910000 - 0x77a37000 	C:\Windows\system32\ntdll.dll
0x76820000 - 0x768fb000 	C:\Windows\system32\kernel32.dll
0x76950000 - 0x76a16000 	C:\Windows\system32\ADVAPI32.dll
0x76190000 - 0x76252000 	C:\Windows\system32\RPCRT4.dll
0x6c3a0000 - 0x6c3be000 	C:\Windows\system32\ShimEng.dll
0x75fc0000 - 0x75fec000 	C:\Windows\system32\apphelp.dll
0x6a790000 - 0x6a818000 	C:\Windows\AppPatch\AcLayers.DLL
0x76260000 - 0x762fd000 	C:\Windows\system32\USER32.dll
0x76c60000 - 0x76cab000 	C:\Windows\system32\GDI32.dll
0x76e00000 - 0x77910000 	C:\Windows\system32\SHELL32.dll
0x763f0000 - 0x7649a000 	C:\Windows\system32\msvcrt.dll
0x767c0000 - 0x76818000 	C:\Windows\system32\SHLWAPI.dll
0x76cb0000 - 0x76df4000 	C:\Windows\system32\ole32.dll
0x76730000 - 0x767bd000 	C:\Windows\system32\OLEAUT32.dll
0x76040000 - 0x7605e000 	C:\Windows\system32\USERENV.dll
0x76020000 - 0x76034000 	C:\Windows\system32\Secur32.dll
0x701b0000 - 0x701f2000 	C:\Windows\system32\WINSPOOL.DRV
0x75bc0000 - 0x75bd4000 	C:\Windows\system32\MPR.dll
0x763d0000 - 0x763ee000 	C:\Windows\system32\IMM32.DLL
0x77a70000 - 0x77b38000 	C:\Windows\system32\MSCTF.dll
0x77a40000 - 0x77a49000 	C:\Windows\system32\LPK.DLL
0x764a0000 - 0x7651d000 	C:\Windows\system32\USP10.dll
0x74ea0000 - 0x7503e000 	C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_5cdbaa5a083979cc\comctl32.dll
0x7c340000 - 0x7c396000 	C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da8b000 	C:\Program Files\Java\jre6\bin\client\jvm.dll
0x746d0000 - 0x74702000 	C:\Windows\system32\WINMM.dll
0x74650000 - 0x74689000 	C:\Windows\system32\OLEACC.dll
0x6d7b0000 - 0x6d7bc000 	C:\Program Files\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 	C:\Program Files\Java\jre6\bin\java.dll
0x6d290000 - 0x6d298000 	C:\Program Files\Java\jre6\bin\hpi.dll
0x76180000 - 0x76187000 	C:\Windows\system32\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000 	C:\Program Files\Java\jre6\bin\zip.dll
0x6d430000 - 0x6d436000 	C:\Program Files\Java\jre6\bin\jp2native.dll
0x6d1d0000 - 0x6d1e3000 	C:\Program Files\Java\jre6\bin\deploy.dll
0x75ac0000 - 0x75bb1000 	C:\Windows\system32\CRYPT32.dll
0x75c20000 - 0x75c32000 	C:\Windows\system32\MSASN1.dll
0x76300000 - 0x763d0000 	C:\Windows\system32\WININET.dll
0x77a60000 - 0x77a63000 	C:\Windows\system32\Normaliz.dll
0x76520000 - 0x76566000 	C:\Windows\system32\iertutil.dll
0x76ab0000 - 0x76bd9000 	C:\Windows\system32\urlmon.dll
0x6d6b0000 - 0x6d6f3000 	C:\Program Files\Java\jre6\bin\regutils.dll
0x75820000 - 0x75828000 	C:\Windows\system32\VERSION.dll
0x6fc80000 - 0x6fe82000 	C:\Windows\system32\msi.dll
0x6d610000 - 0x6d623000 	C:\Program Files\Java\jre6\bin\net.dll
0x76700000 - 0x7672d000 	C:\Windows\system32\WS2_32.dll
0x77a50000 - 0x77a56000 	C:\Windows\system32\NSI.dll
0x757e0000 - 0x7581b000 	C:\Windows\system32\mswsock.dll
0x757d0000 - 0x757d5000 	C:\Windows\System32\wship6.dll
0x6d630000 - 0x6d639000 	C:\Program Files\Java\jre6\bin\nio.dll
0x6d000000 - 0x6d14a000 	C:\Program Files\Java\jre6\bin\awt.dll
0x6f730000 - 0x6f73c000 	C:\Windows\system32\DWMAPI.DLL
0x751a0000 - 0x751df000 	C:\Windows\system32\uxtheme.dll
0x6d230000 - 0x6d284000 	C:\Program Files\Java\jre6\bin\fontmanager.dll
0x75490000 - 0x75495000 	C:\Windows\System32\wshtcpip.dll
0x74630000 - 0x7463f000 	C:\Windows\system32\NLAapi.dll
0x75a20000 - 0x75a39000 	C:\Windows\system32\IPHLPAPI.DLL
0x759e0000 - 0x75a15000 	C:\Windows\system32\dhcpcsvc.DLL
0x75c60000 - 0x75c8c000 	C:\Windows\system32\DNSAPI.dll
0x759d0000 - 0x759d7000 	C:\Windows\system32\WINNSI.DLL
0x759a0000 - 0x759c1000 	C:\Windows\system32\dhcpcsvc6.DLL
0x70500000 - 0x7050f000 	C:\Windows\system32\napinsp.dll
0x702c0000 - 0x702d2000 	C:\Windows\system32\pnrpnsp.dll
0x704f0000 - 0x704f8000 	C:\Windows\System32\winrnr.dll
0x76900000 - 0x7694a000 	C:\Windows\system32\WLDAP32.dll
0x70540000 - 0x70546000 	C:\Windows\system32\rasadhlp.dll
0x75580000 - 0x755bb000 	C:\Windows\system32\rsaenh.dll
0x10000000 - 0x10028000 	C:\Users\Glenn Boudaer1\Application Data\SystemRequirementsLab\SRLProxy_srl_4_1_13_0_a.dll
0x76a20000 - 0x76aa4000 	C:\Windows\system32\CLBCatQ.DLL
0x76570000 - 0x766fa000 	C:\Windows\system32\SETUPAPI.dll
0x754a0000 - 0x754ba000 	C:\Windows\system32\POWRPROF.dll
0x752a0000 - 0x752cd000 	C:\Windows\system32\WINTRUST.dll
0x77b40000 - 0x77b69000 	C:\Windows\system32\imagehlp.dll
0x6c920000 - 0x6ca05000 	C:\Windows\system32\ddraw.dll
0x6e5d0000 - 0x6e5d6000 	C:\Windows\system32\DCIMAN32.dll
0x04fd0000 - 0x05055000 	C:\Windows\system32\igdumdx32.dll
0x052a0000 - 0x055f1000 	C:\Windows\system32\igdumd32.dll
0x6a270000 - 0x6a376000 	C:\Windows\system32\d3d8.dll
0x6ea00000 - 0x6ea06000 	C:\Windows\system32\d3d8thk.dll
0x6dad0000 - 0x6dc8a000 	C:\Windows\system32\d3d9.dll
0x69200000 - 0x69302000 	C:\Windows\system32\d3d10.dll
0x71b70000 - 0x71ba3000 	C:\Windows\system32\d3d10core.dll
0x6e430000 - 0x6e461000 	C:\Windows\system32\dxgi.dll
0x06bc0000 - 0x06df1000 	C:\Windows\system32\igd10umd32.dll
0x75610000 - 0x756e7000 	C:\Windows\system32\winbrand.dll
0x74710000 - 0x74780000 	C:\Windows\system32\dsound.dll
VM Arguments:
jvm_args: -D__jvm_launched=5082785345 -Xbootclasspath/a:C:\\PROGRA~1\\Java\\jre6\\lib\\deploy.jar;C:\\PROGRA~1\\Java\\jre6\\lib\\javaws.jar;C:\\PROGRA~1\\Java\\jre6\\lib\\plugin.jar -Dsun.plugin2.jvm.args=-D__jvm_launched=5082785345 "-Xbootclasspath/a:C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\lib\\\\deploy.jar;C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\lib\\\\javaws.jar;C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\lib\\\\plugin.jar" "-Djava.class.path=C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\classes" --- --
java_command: sun.plugin2.main.client.PluginMain write_pipe_name=jpi2_pid2248_pipe5,read_pipe_name=jpi2_pid2248_pipe4
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Mozilla Firefox;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;c:\Program Files\Common Files\Roxio Shared\DLLShared\;c:\Program Files\Common Files\Roxio Shared\10.0\DLLShared\
USERNAME=Glenn Boudaer1
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows Vista Build 6001 Service Pack 1
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1
Memory: 4k page, physical 2097151k(1839080k free), swap 4194303k(4194303k free)
vm_info: Java HotSpot(TM) Client VM (14.2-b01) for windows-x86 JRE (1.6.0_16-b01), built on Jul 31 2009 11:26:58 by "java_re" with MS VC++ 7.1
time: Tue Oct 06 09:42:29 2009
elapsed time: 74 seconds[/COLOR]
Wat kan ik hieraan doen???
Alvast bedankt!!
Een collega moderator heeft vanmiddag jou tweede bericht verwijderd. Iets wat met een reden is gebeurt, ik heb nu jou vorige bericht verwijderd om dezelfde reden. Het is niet toegestaan om binnen een paar uur je topic omhoog te kicken.
Mensen helpen hier vrijwillig en er moet maar net iemand online zijn, die jou kan helpen. Heb je na een dag geen reactie gehad, dan kun je een berichtje achterlaten, zodat je topic weer onder de aandacht komt.
graag had ik dan wel een melding gekregen dat m'n tweede bericht was verwijderd! ik dacht dat m'n bericht niet was geplaatst waardoor ik een nieuw bericht plaatste :) hopelijk van jou hier ook wel wat begrip voor!!!
