brownmouse
- 6 jul 2007
Windows 7 is vele malen beter!!
jaa dan kan ik die denk beter gebruiken?
dan download ik die wel even
toch bedankt
Kort antwoord, Ja.
Lang antwoord:
From the out side, the all new Windows 7 closely resembles its predecessor Windows Vista. The major change that you will be able to see at first, in terms of UI, is the new taskbar also known as superbar, which now sports a battery of features.
There are sheer amount of features and tweaks under the hood. In terms of features and usability Windows 7 is the un-challenged OS till date. If you have been running Vista, then obviously you want to know difference between Vista and Windows 7, before making the wise decision.
The list below takes you through a list of major Windows 7 features that are not available in Vista.
Simply put, Windows 7 is much faster, safer and better than any OS out there including its predecessor Vista.
Apart from all the changes that we have mentioned in the above list, there are many small, new features exist in Windows 7, which can only be experienced by installing Windows 7.
