windows media encoder frame drop 50%
alsido
25 mrt 2002
hallo,
ik stream hier met windows media encoder en heb de instellingen allemaal op 25 frames per seconde staan en ook op pal maar ik heb toch een frame drop van 50% wie kan mij helpen met dit probleempje?
mvg alsido
hallo,
mvg alsido
Is de invoer wel 25 frames? anders verlaagd media encoder hem vanzelf.
Hoeveel CPU gebruik je?
Waar heb je frame drop? invoer/uitvoer?
Geef eens wat meer info
2.1 I'm not getting the frame rate or bit rate I requested from the encoder. What should I do? What affects these settings?
The setting you specify represents the maximum value; if you are encoding low-motion video, the frame rate or bit rate of the encoded content might be lower. Other factors that may reduce the frame rate or bit rate include a high video quality setting, insufficient network bandwidth, a large frame size, and a system that is not sufficiently powerful. Check that you are using capture cards that have been tested for use with Windows Media Encoder 9 Series and that the current drivers for the cards are installed. If the encoding system is not sufficiently powerful, try optimizing the system by closing all other applications while encoding, turning off video preview and postview, and adjusting the performance settings. For more information about achieving optimal system performance, see Windows Media Encoder Help.
2.3 Why are frames being dropped during encoding?
Try increasing the bandwidth for the session and reducing the frame rate and frame size. In addition, if you are sourcing from devices, check that you are using capture cards that have been tested for use with Windows Media Encoder 9 Series and that the current drivers for the cards are installed. Finally, the encoding system may not be sufficiently powerful. Try optimizing the system by closing all other applications while encoding, turning off video preview and postview, and adjusting the performance settings. For more information about achieving optimal system performance, see Windows Media Encoder Help.
http://www.microsoft.com/windows/windowsmedia/forpros/encoder/faq.aspx#2_1
http://on10.net/blogs/benwagg/Best-practices-for-Windows-Media-Encoder-in-2009/
http://alexzambelli.com/WMV/#WMV9PowerToy
de invoer is 25
30%
en ik gebruik een matrox rtx100
invoer framedrop van 45% en een paar drops bij uitvoer
je kan kijken op www.johanvlemmix.tv in de player wat de statistieken zijn
de invoer is 25
30%
Bij invoer....
Ik heb even gekeken bij http://forum.matrox.com/rtx100/index.php
Daar geven ze vooral standaard oplossingen zoals 30% disk vrij, programmas uitschaken die je niet gebruikt en de laatste drivers installeren.
Normaal geproken test je het kaartje dan in een andere pc om te testen of de kaart goed werkt, zo ja ligt het aan de pc.
Verder is er weinig te vinden over frame drop helaas. (behalve de instellingen)
