Email merge
sjobbels
11 dec 2008
ik heb in mijn database een mailmerge gebouwd, die via een selectie in een formulier (zie bijlage) en een .dot file een normale mailmerge in word genereerd. Op basis van deze code wordt de mailmerge gestart:
Option Compare Database
Option Explicit
Private Const conTemplate As String = "CSMailMerge.dot"
Private Const conQuery As String = "qryMailmerge"
Private Const conTabel As String = "tmp"
Dim strSQl As String
Private Sub cmdClear_Click()
    strSQl = "UPDATE " & conQuery & vbCrLf
    strSQl = strSQl & "SET Mailmerge = Null " & vbCrLf
    strSQl = strSQl & "WHERE Mailmerge=True"
    DoCmd.RunSQL strSQl
    Me.Form.Requery
Private Sub cmdSelect_Click()
    strSQl = strSQl & "SET Mailmerge = 1 " & vbCrLf
    strSQl = strSQl & "WHERE Mailmerge=False"
    DoCmd.RunSQL strSQl
    Me.Form.Requery
Private Sub cmdGo_Click()
DoCmd.SetWarnings False
    strSQl = "SELECT NaamBedrijf, NaamLocatieDochter, CPAanhef, Aan, CPVoorletters, CPAchternaam, Adres, Postcode, Plaats, SalesManager, Telefoonnr, Mailmerge "
    strSQl = strSQl & "INTO tmp " & vbCrLf
    strSQl = strSQl & "FROM qryMailmerge " & vbCrLf
    strSQl = strSQl & "WHERE (Mailmerge = True) " & vbCrLf
    strSQl = strSQl & "ORDER BY NaamBedrijf;"
    DoCmd.RunSQL strSQl
    DoCmd.SetWarnings True
    Call Samenvoegen
Public Sub Samenvoegen()
Dim rs As ADODB.Recordset
    Dim strPath As String
    Dim strDataSource As String
    Dim doc As Word.Document
    Dim wrdApp As Word.Application
    On Error GoTo HandleErrors
    ' Delete the rtf file, if it already exists.
    strPath = FixPath(CurrentProject.Path)
    strDataSource = strPath & conQuery & ".doc"
    Set rs = New ADODB.Recordset
    rs.Open "SELECT * FROM tmp", CurrentProject.Connection, adOpenStatic, adLockPessimistic
    MsgBox "Aantal records: " & rs.RecordCount, vbOKOnly
    If rs.RecordCount = 0 Then Exit Sub
    ' Export the data to rtf format
    DoCmd.OutputTo acOutputTable, conTabel, acFormatRTF, strDataSource, False
    ' Start Word using mailmerge template
    Set wrdApp = New Word.Application
    Set doc = wrdApp.Documents.Add(strPath & conTemplate)
    ' Do the mail merge to a new document.
    With doc.Mailmerge
        .OpenDataSource Name:=strDataSource
        .Destination = wdSendToNewDocument
        .SuppressBlankLines = True
        With .DataSource
            .FirstRecord = wdDefaultFirstRecord
            .LastRecord = wdDefaultLastRecord
        If .State = wdMainAndDataSource Then
            .Execute
    ' Display the mail merge document
    wrdApp.Visible = True
ExitHere:
    Set doc = Nothing
    Set wrdApp = Nothing
    Exit Sub
HandleErrors:
    Select Case Err.Number
        Case 53         ' File not found
            Resume Next
        Case Else
            MsgBox Err.Number & ": " & Err.Description
            Resume ExitHere
    End Select
Private Function FixPath(strPath As String) As String
    If Right(strPath, 1) = "\" Then
        FixPath = strPath
    Else
        FixPath = strPath & "\"
End Function
Private Sub Form_Current()
    Me.txtsubMail.Requery
    If Me.txtsubMail.Value > 0 Then
        Me.cmdGo.Enabled = True
    Else
        Me.cmdGo.Enabled = False
    Me.Form.Recalc
''    Me.Form.Requery
    Me.Form.Refresh
    Me.Form.Repaint
Private Sub chkMailmerge_AfterUpdate()
    If Me.Dirty Then
        Me.Dirty = False
    Else
''    Me.Form.Requery
    Me.Form.Refresh
    Me.Form.Repaint
Nu is er de vraag gekomen om op basis van deze form of een nieuw form een E-mail merge te maken. Dus dat de geselecteerde emailadressen in de 'To' balk van outlook komen. Hoe krijg ik dit voorelkaar?
thanks
    90,2 KB · Weergaven: 70
je kunt dat zowiezo vanuit Word doen, door een sjabloon te maken die een Email merge doet i.p.v. een merge naar printer. Je moet dan wel het emailveld meegeven, maar dat lijkt mij niet zo'n probleem.
Anders kun je een HTML mail genereren, of een rapport mailen vanuit Access, dan heb je heel Word niet meer nodig.
Ok maar er hoeft in dit geval geen bijlage bij. Het is de bedoeling dat alleen de geselecteerde mailadressen in de to-balk komen.
Wat wil je precies doen met de email? En wat moet er worden gemaild? En moeten alle adressen in één keer in één mail?
Ik wil alleen dat de geselecteerde emailadressen in de to- balk komen te staan. Verder hoef er geen attachment of tekst bij te komen. Dit mag door de gebruiker zelf toegevoegd worden. De mail mag dus niet meteen verstuurd worden.
Dus je wilt een string opbouwen met de emailadressen, gescheiden door een puntkomma?
Dan krijg je denk ik iets als dit:
strSQL = "SELECT NaamBedrijf, NaamLocatieDochter, CPAanhef, Aan, CPVoorletters, CPAchternaam, Email, SalesManager, Telefoonnr, Mailmerge "
With CurrentDb.OpenRecordset("SELECT * FROM tmp")
     .MoveFirst
     Do While Not .EOF
         If Not .Fields("Email").Value = "" Then
             stEmail = stEmail & .Fields("Email").Value & ";"
         .MoveNext
     Loop
Do While Right(stEmail, 1) = ";"
    stEmail = Left(stEmail, Len(stEmail) - 1)
Loop
De rest van de samenvoeging zal denk ik wel lukken?
thanks, ik ga het zo even proberen.
Ik krijg nu een runtime error 3265 bij: If Not .Fields("Email").Value = "" Then
Octafish,
Ik heb nog vanalles geprobeerd, heb ook nog een aantal andere voorbeelden gevonden, maar deze werken alleen met een listbox.
Kun jij aan onderstaande codering zien waar het mis gaat??
Option Explicit
Private Const conquery As String = "qryEmailgroep"
Dim strSQL As String
    strSQL = "UPDATE " & conquery & vbCrLf
    strSQL = strSQL & "SET Emailgroep = Null " & vbCrLf
    strSQL = strSQL & "WHERE Emailgroep=True"
    DoCmd.RunSQL strSQL
    Me.Form.Requery
    strSQL = strSQL & "SET Emailgroep = 1 " & vbCrLf
    strSQL = strSQL & "WHERE Emailgroep=False"
    DoCmd.RunSQL strSQL
    Me.Form.Requery
    strSQL = "SELECT NaamBedrijf, NaamLocatieDochter, CPAanhef, Aan, CPVoorletters, CPAchternaam, SalesManager,Email, Emailgroep "
    strSQL = strSQL & "INTO tmp " & vbCrLf
    strSQL = strSQL & "FROM qryEmailgroep " & vbCrLf
    strSQL = strSQL & "WHERE (Emailgroep = True) " & vbCrLf
    strSQL = strSQL & "ORDER BY NaamBedrijf;"
    DoCmd.RunSQL strSQL
    Call Samenvoegen
Dim r As Recordset
Dim Email As String
Dim stLinkCriteria As String
Dim stSubject As String
Dim Message As String
    .MoveFirst
Do While Not r.EOF
    stLinkCriteria = Email & r(2) & ";"
    stSubject = "Test"
    r.MoveNext
    Loop
        r.Close
        DoCmd.SendObject acSendNoObject, , , stLinkCriteria, , , stSubject
    Else
    Me.Form.Recalc
''    Me.Form.Requery
    Me.Form.Refresh
    Me.Form.Repaint
Private Sub chkEmailgroep_AfterUpdate()
    If Me.Dirty Then
        Me.Dirty = False
    Else
''    Me.Form.Requery
    Me.Form.Refresh
    Me.Form.Repaint
Ik hoop dat je me verder kunt helpen
Bedankt alvast
Ik zie vooral problemen met de hoofdroutine; ik neem aan dat daar ook de foutmelding vandaan komt?
Probeer 'm eens zo:
Dim rs As Recordset
Dim Email As String
        If .RecordCount > 0 Then
            .MoveFirst
            Do While Not .EOF
                stLinkCriteria = Email & .Fields(2).Value & ";"
                stSubject = "Test"
                .MoveNext
            Loop
        .Close
Zoals je ziet, heb ik nogal wat weggehaald:
Hier open je de tabel...
En hier nog een keer....
Maar de tabel is al open!
.MoveFirst
Waar komt de r vandaan? Je hebt geen SET gebruikt om hem toe te wijzen...
Do While Not r.EOF
stSubject = "Test"
r.MoveNext
Loop
r.Close
Kortom: niet te moeilijk denken!
thanks voor de snelle reactie.:thumb:
zo ziet het er idd ook een stuk overzichtelijker uit. En het begint me nu ook allemaal wat duidelijker te worden.
Als ik de code uitvoer loop ik tegen 2 problemen aan:
1) bij de msgbox krijg ik de volgende foutmelding--> Fout 91 tijdens uitvoering: Objectvariabele of blokvariabele With is niet ingesteld.
2) als ik de msgbox verwijder (liever niet) dan werkt de uitvoering naar outlook wel, maar hij pakt iedere keer maar 1 emailadres ook al heb ik er meerdere aangevinkt.
Nou Michel, het is wel grappig dat we zo'n beetje op dezelfde golflengte zitten :)
En ik weet dat je maar even snel de code opgeschoond hebt, want jij zou dit zelf volgens mij nooit zo oplossen:
Do While Not .EOF
stSubject = "Test"
.MoveNext
Loop
End Sub[/CODE]
Betekent dat je voor ieder record het subject van de mail opnieuw gaat instellen.
@Ren'e: Ik heb me inderdaad gefocused op de oplossing van het probleem, niet de Subject code ;)
De foutmelding kan worden veroorzaakt doordat de bibliotheken niet helemaal goed geladen zijn: in het vba scherm: <Extra>, <Verwijzingen>. Waarschijnlijk heb je een ADO 2.# bibliotheek en een DAO 3.6 bibliotheek geladen. Controleer of de DAO bibliotheek als laatste wordt geladen, dan zou het probleem al weg kunnen zijn.
Het probleem van de enkele mail is ook wel logisch; de SendObject wordt nu één keer uitgevoerd. Je zou hem denk ik vóór de Movenext moeten zetten.
Effe testen dus! Ik zie zo snel ook niet wat-ie allemaal moet ophalen...
Hoi Octafish en Rene,
Het lukt nog steeds niet:
Dim rs As Recordset
Dim Email As String
            .MoveFirst
            Do While Not .EOF
                stLinkCriteria = Email & .Fields(7).Value & ";"
                stSubject = "Test"
                .MoveNext
            Loop
        .Close
Ik krijg nog steeds alleen het eerste emailadres in outlook te zien en niet de andere aangevinkte emails......
Ik ben een beetje verward door deze regel:
En dan met name door: & ";"
Ik vermoed, dat je één string wilt maken voor de emailadressen, en dat je dus ook maar één verzendactie wilt uitvoeren. Als dat zo is, gaat dit niet werken, omdat je bij elk record het criterium vervangt door een volgend record, en dus uiteindelijk maar één mailadres (het laatste) overhoudt.
Je moet het criterium uitbreiden, niet vervangen. Dus:
stLinkCriteria = stLinkCriteria & Email & .Fields(7).Value & ";"
Als dit de bedoeling is, kan de Docmd.Sendobject ook weer uit de loop, anders blijft-ie toch mailen.... Wat dacht ik toch zou moeten gebeuren, maar dan voor alle aparte records. Maar dit terzijde...
Maar 'Email' krijgt dan weer nergens een waarde toegewezen en zal dus een lege string zijn. Waarschijnlijk is de code samengevoegd uit meerdere stukjes en is dat een overblijfsel.
Daar vanuit gaande, zou het zou kunnen zijn?
stLinkCriteria = stLinkCriteria & .Fields(7).Value & ";"
helaas... het werkt niet. Hij pakt nog steeds maar 1 emailadres. Mijn database is te groot (en te vertrouwelijk) om hier te plaatsen.
Ja idd
Ik heb wel een voorbeeld gevonden adh van een listbox, maar dit wil ik liever niet, omdat er aan mijn formulier een zoekfunctie gekoppeld zit (zie plaatje eerste post).
Misschien hebben jullie hier iets aan?
Kun je wel controleren of de emailadressen in één variabele worden gezet? Bijvoorbeeld met een Msgbox?
