smiley probleem vreemd !?
Biirra
25 dec 2009
[CPP]// hangman showt in functions
// classic game of hangman
#include <iostream>
#include <string>
#include <vector>
#include <algorithm>
#include <ctime>
#include <cctype>
using namespace std;
char playerGuess();
const int MAX_WRONG = 8;// maximale fouten
vector<string> words;
int wrong = 0;
string used = " ";
char guess;
int main(char guess)
words.push_back("HANGMAN");
words.push_back("GUESS");
words.push_back("DIFFICULT");
srand(time(0));
random_shuffle(words.begin(),words.end());
const string THE_WORD = words[0];
string soFar(THE_WORD.size(), '-');
cout << "Welcome to hangman. Good Luck!\n";
//main loop
while ((wrong < MAX_WRONG) && (soFar != THE_WORD))
cout << "\nYou have " << (MAX_WRONG - wrong) << " incorrect guesses left.\n";
cout << "\nYou've used the following letters:\n" << used << endl;
cout << "\nSo far, the word is:\n" << soFar << endl;
playerGuess();
if (THE_WORD.find(guess) != string::npos)
cout << "That's right! " << guess << "is in the word.\n";
// update soFar om nieuwe letter toe te voegen.
for(int i = 0; i < THE_WORD.length(); ++i)
if(THE_WORD == guess)
soFar = guess;
else
cout << "Sorry, " << guess << "isn't in the word.\n";
++wrong;
//afsluiten
if (wrong == MAX_WRONG)
cout << "\nYou've been hanged!";
else
cout << "\nYou guessed it!";
cout << "\nThe word whas " << THE_WORD << endl;
return 0;
char playerGuess() // vraagt player vor een gok.
cout << "\n\nEnter your guess: ";
cin >> guess;
guess = toupper(guess);// maakt hoofdletter omdat het woord erin is gespelt
while(used.find(guess) != string::npos)
cout << "\nYou've alredy guessed " << guess << endl;
cout << "enter your guess: ";
cin >> guess;
used += guess;
return guess;
}[/CPP]
als je dit programmatje start komt er een smiley in voor, kan iemand me vertellen wat dat dingetje daar doet en hoe die er komt enzo :S ? ik snap er niks van namelijk.
verder werkt spel wel maar dat smiley is heel vaag.
Waar zie jij dan die smiley? Ik zie hem niet als ik het programma start:
frank@darkstar:~$ ./hangman
You have 8 incorrect guesses left.
Enter your guess:
Ik kreeg wel deze fouten bij het compileren:
hangman.cpp:22: error: first argument of 'int main(char)' should be 'int'
hangman.cpp:22: error: 'int main(char)' takes only zero or two arguments
hangman.cpp: In function 'int main(char)':
hangman.cpp:55: warning: comparison between signed and unsigned integer expressions
[cpp]int main(char guess)[/cpp]
Dit kan en mag niet. Je moet of [cpp]int main()[/cpp] of (als je parameters wilt kunnen meegeven) [cpp]int main(int argc, char *argv[])[/cpp] gebuiken.
De waarschuwing mag je negeren, maar als je hem wilt oplossen moet je [cpp]for(int i = 0; i < THE_WORD.length(); ++i)[/cpp] vervangen door [cpp]for(unsigned int i = 0; i < THE_WORD.length(); ++i)[/cpp]
hmm.... ik krijg nie die compile errors, nog geen waarschuwing van een foutje, gebruik je dev c++ ? btw zodra je een letter invuld krijg ik die smiley, ik zal is kijken of ik een screensht kan poste.
heej je hat gelijk :P
[CPP]int main(char guess)[/CPP]
was fout :P moes gewoon int main zijn, van de anderre error krijg ik geen melding en ook geen zichtbare fout in het spel. maar tog bedankt :P vond smile beetje raar
:thumb:
Ook als ik een letter invul krijg ik geen smiley te zien.
Enter your guess: a
That's right! Ais in the word.
A
-A---A-
Enter your guess: q
Sorry, Qisn't in the word.
You have 7 incorrect guesses left.
AQ
-A---A-
Enter your guess:
Als compiler gebruik ik GCC (in Linux).
