Software voor bestands typen
leukme05
5 nov 2009
Hallo iedereen
Ik zoek sofware voor het openen van CLI en TAG bestanden
Alvast bedankt:D
CLI
Use Notepad or another text editor to open the CLI file. Many files are text-only files meaning no matter the file extension, a text editor may be able to properly display the file's contents. This may or may not be the case with CLI files but it's worth a try.
TAG
The .TAG file extension identifies DataFlex search string files: where DataFlex is a database application developed by Data Access Corporation.. Incorrect associations are the cause of many file extension errors. Scan your system to prevent, identify and repair TAG file extension association errors.
kdenk dat je voor tag dataflex kan gebruiken
Byee VRC
