Hoe krijg ik Flashplayer aan de praat onder Windows7 64 bit met 64 bits browser
ja en dus ...
Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
To participate in pre-release testing of 64-bit Flash Players, visit Adobe Labs.
daar zie ik dan ook de flash 10.1 staan
zoals ik dat verhaal van adobe gelezen heb moet je die hebben:thumb:
Flash Player 10.1 Release Candidate 2
The following downloads will install Flash Player 10.1 release candidate for Windows, Macintosh and Linux desktop operating systems.
Download plug-in for Windows (EXE, 2.4 MB)
Download active-x for Windows (EXE, 2.5 MB)
Download plug-in for Macintosh (DMG, 7.4 MB)
Download plug-in for Linux (TAR.GZ, 4.5 MB)
Bron: http://labs.adobe.com/downloads/flashplayer10.html
ik heb de release note bekeken en deze zou gewoon moeten werken op jou systeem :(
System Requirements
System requirements for platforms supported by Flash Player 10 are available at http://www.adobe.com/products/flashplayer/productinfo/systemreqs/.
Note: The Adobe Flash Player 10.1 release, expected in the first half of 2010, will be the last version to support Macintosh PowerPC-based G3 computers. Adobe will be discontinuing support of PowerPC-based G3 computers and will no longer provide security updates after the Flash Player 10.1 release. This unavailability is due to performance enhancements that cannot be supported on the older PowerPC architecture.
H.264 Video Hardware Acceleration Support
Flash Player 10.1 supports hardware decoding of H.264 video on Windows platforms when running with supported hardware. Use the following recommended hardware and driver combinations to experience hardware acceleration of H.264 videos in Flash Player 10.1. Unless otherwise noted, the following hardware will support H.264 hardware decoding with supported drivers under Windows XP 32-bit, Windows Vista (32/64-bit), and Windows 7 (32/64-bit).
Please note that, because some mobile and notebook systems require customized drivers, driver updates for some systems must be obtained directly from OEMs rather than from the chipset vendor websites below.
Ik heb hem gedownload en geinstalleerd, maar ik geloof niet dat Flashplayer werkt zoals hij het zou moeten doen zoals de 32-bits versie.
De filmpjes starten gewoon niet zoals het hoort.
Flahsplayer werkt, volgens de website van Adobe, alleen nog maar op een 64 bits OS, in een 32 bits Internet browser. Ze zijn geloof ik wel bezig met een versie voor de 64 bits browers ;)
Dat las ik ook, jammer. We wachten dus maar gewoon af.
