lijn in koptekst
JEPEDEWE
14 jun 2006
Sta aan de vooravond van het afleveren van mijn Batchelor-thesis en worstel met een verveelende zaak
In mijn koptekst staat een lijn die ik er neit wil hebben en niet kwijt raak:
als ik op "koptekst" klik koos ik voor optie 1: "Leeg" en daar staat de lijn...
Ik gebruik word2007
wie kan helpen?
Van harte
Dubbelklik in de koptekst
Toetscombinatie Ctrl-A
en nu op DEL drukken
...... en nu?
dit was uiteindelijk de oplossing... na uren googelen
Removing the HR Line from Word
It was an annoying bugger that I couldn’t figure out – I was having a problem removing what I thought was the horizontal rule <hr> tag from Microsoft Word. Try as I would… I couldn’t get it to go away; I couldn’t delete it with the delete key nor the backspace key, I couldn’t select it with the cursor… it was driving me mad.
The Problem:
I was using some auto-correct (actually auto-format) feature of Microsoft Word that I really didn’t understand, I would type three underscores (_) and then hit the enter key – the ensuing output seemed to be a horizontal rule.
I’ve come to find out that this auto-format feature actually creates a border for the document, not just a mere horizontal line. I have also come to find out that the instant horizontal line (border) will show up if you use 3 hyphens (-), 3 tildes (~), 3 pound signs (#) or 3 equal signs (=) in a row followed by the enter key. At the time, I was just trying to get rid of it.
The Fix
In earlier versions of Word (maybe 2003 or earlier), several websites state that you must:
Place your cursor right above the horizontal line
From your menu choose Format >> Borders and Shading >> None >> Ok
I personally have Word 2007 – and it’s not quite the same… so I cannot verify that the above is 100% correct – but I would imagine it’s spot-on.
Here’s how to do this when you have Microsoft Office Word 2007 (or Word 2007) screenshots:
Place your cursor directly above the offending line
From your menu, choose Page Layout
Once you click on Page Layout, click on Page Borders
Choose the Borders Tab, in the upper left select None, then hit Ok
The line should disappear
@JEPEDEWE Na enkele minuten 'Helpmijen' had je mogelijk dit gevonden :
Zie ook Klik en dan met name het bericht van 13 mei van 20.20 uur.
In gewoon oerhollands had je dus simpelweg een lijntje ingesteld met randen en kaders en moest je dat verwijderen middels het selecteren van de optie 'geen randen'. Dolle pret!
Er zijn ook meelezers die geen Engels begrijpen, dus een Nederlandse vertaling van je bericht zou wel handig zijn. (Vandaar mijnkort door de bocht / eenvoudige 'vertaling')
