Sub Werkbalken_weg()
'alle werkbalken verbergen
Dim wbBook As Workbook
Dim wsSheet As Worksheet
Set wbBook = ThisWorkbook
For Each wsSheet In wbBook.Worksheets
wsSheet.Activate
With ActiveWindow
.DisplayHeadings = False
Next wsSheet
Sheets("TK WEV").Select
Application.OnKey "{f11}", "" 'F11 uitschakelen (grafiek)
On Error Resume Next
If ("TK WEV!AT3") >= 12 Then 'Office 2007 of later, ribbon uitschakelen
Application.DisplayFullScreen = True 'Office 2007 of later, ribbon uitschakelen
End If 'Office 2007 of later, ribbon uitschakelen
Application.CommandBars("worksheet menu bar").Enabled = False
Application.CommandBars("Standard").Controls("Cut").Visible = False
Application.CommandBars("Standard").Controls("Knippen").Visible = False
Application.CommandBars("Standard").Controls("Copy").Visible = False
Application.CommandBars("Standard").Controls("Kopiëren").Visible = False
Application.CommandBars("Standard").Controls("Paste").Visible = False
Application.CommandBars("Standard").Controls("Plakken").Visible = False
Application.CommandBars("Standard").Controls("Opmaak kopiëren/plakken").Visible = False
For n = 30 To 0 Step -1
Application.CommandBars(n).Visible = False
Next n
CommandBars("eigenbalk").Delete
Application.DisplayFormulaBar = False
Application.DisplayHeadings = False
Application.EnableAutoComplete = False
ActiveWindow.WindowState = xlMaximized
Set mijnbalk = CommandBars.Add("eigenbalk", msoBarTop, True, True)
mijnbalk.Controls.Add Type:=msoControlButton, ID:=3 'Save
mijnbalk.Controls.Add Type:=msoControlButton, ID:=23 'Open
mijnbalk.Controls.Add Type:=msoControlButton, ID:=1849 'Zoeken
mijnbalk.Controls.Add Type:=msoControlButton, ID:=109 'Afdrukvoorbeeld
mijnbalk.Controls.Add Type:=msoControlButton, ID:=4 'Afdrukken
mijnbalk.Controls.Add Type:=msoControlButton, ID:=47 'inhoud wissen
mijnbalk.Controls.Add Type:=msoControlSplitDropdown, ID:=128 'ongedaan maken
mijnbalk.Controls.Add Type:=msoControlSplitDropdown, ID:=129 'opnieuw
mijnbalk.Controls.Add Type:=msoControlComboBox, ID:=1733 'Zoom %
mijnbalk.Controls.Add Type:=msoControlButton, ID:=1605 'Design mode
mijnbalk.Controls.Add Type:=msoControlButton, ID:=106 'Close
mijnbalk.Controls.Add Type:=msoControlButton, ID:=752 'Exit
mijnbalk.Visible = True
Run "DisableAllShortcutMenus"
