<!-- TWO STEPS TO INSTALL SELECT AND AUTO COPY:
1. Copy the coding into the HEAD of your HTML document
2. Add the last code into the BODY of your HTML document -->
<!-- STEP ONE: Paste this code into the HEAD of your HTML document -->
<HEAD>
<SCRIPT LANGUAGE="JavaScript">
<!-- This script and many more are available free online at -->
<!-- The JavaScript Source!! http://javascript.internet.com -->
<!-- Original: Russ (NewXS3@aol.com) -->
<!-- Web Site: http://dblast.cjb.net -->
<!-- Begin
function copyit(theField) {
var tempval=eval("document."+theField)
tempval.focus()
tempval.select()
therange=tempval.createTextRange()
therange.execCommand("Copy")
// End -->
</script>
</HEAD>
<!-- STEP TWO: Copy this code into the BODY of your HTML document -->
<BODY>
<form name="it">
<div align="center">
<input onclick="copyit('it.select1')" type="button" value="Press to Copy the Text" name="cpy">
<p>
<textarea name="select1" rows="3" cols="25">
If this is highlighted, then it has been copied.
</textarea>
</div>
</form>
<p><center>
<font face="arial, helvetica" size"-2">Free JavaScripts provided<br>
by <a href="http://javascriptsource.com">The JavaScript Source</a></font>
</center><p>
<!-- Script Size: 1.21 KB -->
meer als een FORM
Mijn vermoeden is een knopje die de inhoud van het veld verplaatst naar je klembord, alsof de user het veld geselecteerd heeft en "control+C" gedaan heeft?
Klinkt als javascript.
form is van javascriptjavascript...
met html kan je geen aanvink hokje maken wel met javascriptForm is in html
document.getElementById("Source").value = editorpanelname.innerHTML;
<script >
var editorpanelname = document.getElementById("Editorpanel");//(-- W3C correction OK! --)
doWYSIWYG('underline')
function doWYSIWYG(command, condition, arg){
//editorpanelname.focus();
if(!condition) condition=false;
document.execCommand(command, condition, arg);
function doWYSIWYG2(command, condition, arg){
addPTag(editorpanelname, command);
function doWYSIWYG3(){
function getselectedtext(){
var txt = '';
if (window.getSelection){
txt = window.getSelection();
}else if (document.getSelection){
txt = document.getSelection();
}else if (document.selection){
txt = document.selection.createRange().text;
}else
return;
return txt;
var issource =false;
function tosource(){
if (!issource){
issource = true;
//switch to other vieuw
setclass("Editorpanel",'hidden Apanel');
setclass("Sourcepanel",'Apanel');
function totexteditor(){
if (issource){
editorpanelname.innerHTML = document.getElementById("Source").value;
issource = false;
setclass("Editorpanel",'Apanel');
setclass("Sourcepanel",'hidden Apanel');
function senddata(Field){
tosource();
document.getElementById("editor").submit();
function doselect(){
if(window.getSelection) {
s.removeAllRanges();
s.addRange(rng);
} else {
rng.select();
function doresize(){
var Y = document.getElementById('height').value;
var X = document.getElementById('width').value;
if(issize(X,Y)) {
alert("One or more of the dimensions entered cannot be supported. Setting defaults.");
X="98%"; Y="350";
replacevalue("width",X);
replacevalue("height",Y);
editorpanelname.width=X;
editorpanelname.height=Y;
//todo delete _moz_dirty if mozila
function isbrowserok(){
if (navigator.userAgent.indexOf("Firefox")!=-1){
return true;
}else if(window.navigator.appName == "Microsoft Internet Explorer"){//you must use a better browser
var IEversion = window.navigator.appVersion;
alert(window.navigator.appName + "you must use a better browser for this function");
return (IEversion.substring(IEversion.indexOf("MSIE") + 5, IEversion.indexOf("MSIE") + 8) >= 5.5)
}else if(window.navigator.appName == "Netscape"){//&&(parseInt(appVersion)==4
return true;
}else{//geen ondersteunde browser
return false;
function issize(X,Y){
var xlen = X.length;
var xsub = X.substring(0,xlen-1);
//-- take last char and lie %--&&-- max100 min50
if((X.substring(xlen-1,xlen))=="%"&&(xsub>100||xsub<50)||X>screen.width||X<200||isNaN(xsub-1)){
return false;
var ylen = Y.length;
if((Y.substring(ylen-1,ylen))=="%"||Y<200||isNaN(Y.substring(0,ylen-1))) {
return false;
return true;
function replacevalue(id,value){
document.getElementById(id).value=value;
function setclass(id,value){
document.getElementById(id).className=value;
var oldpanel;
var selection ="";
if (isbrowserok()){
setclass("editERROR",'ERROR hidden');
}else {
setclass("editor",'');
</script>
