BSOD: 0x7A
CalviN13
22 nov 2009
ik heb een probleempje ong elke 2 dagen krijg ik een BSOD met de error code:
0x7A (0xFFFFFFFFC0414E78, 0xFFFFFFFFC0000185, 0x5B621860, 0xFFFFFFFF829CFDDB)
ik heb een crash dump file en even gekeken met programma: WhoCrashed en dit was het resultaat:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 7/30/2011 10:30:34 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\073111-77111-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0xDEEEC)
Bugcheck code: 0x7A (0xFFFFFFFFC0414E78, 0xFFFFFFFFC0000185, 0x5B621860, 0xFFFFFFFF829CFDDB)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\Windows\system32\ntkrnlpa.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrpamp.exe (nt+0xDEEEC)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: ntkrpamp.exe .
Google query: ntkrpamp.exe KERNEL_DATA_INPAGE_ERROR
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
ntkrpamp.exe
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
maar ntkrpamp.exe is een windows kernel driver als ik het goed heb dus kan het niet hebben gedaan?
heb ook wat screenshots van de event log net voor die crashte ong:
[url]http://imageshack.us/photo/my-images/829/errorcr.png/[/url]
[url]http://imageshack.us/photo/my-images/36/error2zi.png/[/url]
System specs:
	Operating System
			MS Windows 7 Ultimate 32-bit SP1
		CPU
			AMD Athlon II M320	58 °C
			Caspian 45nm Technology
		RAM
			2.00 GB Single-Channel DDR2 @ 402MHz (6-6-6-18)
		Motherboard
			Hewlett-Packard 363F (Socket S1G3)	60 °C
		Graphics
			Generic PnP Monitor (1366x768@60Hz)
			ATI Mobility Radeon HD 4200 Series
		Hard Drives
			488GB Hitachi Hitachi HTS725050A9A364 ATA Device (SATA)
		Optical Drives
			hp DVD RW AD-7581S ATA Device
		Audio
			IDT High Definition Audio CODEC
Als je meer informatie nodig hebt zeg het
Alvast Bedankt!
Wellicht word je wat wijzer door gebruik te maken v/h volgende hulpprogramma:
AppCrashview Hiermee kun je informatie bekijken over elke applicatie die de computer crasht (Nederlands taalbestand)
Ik ken 7A meldingen (als ik me goed herinner) als er bestandssysteemfouten op het systeem staan.
Doe dus een schijfcontrole met automatisch problemen verhelpen aangevinkt. Zal wel gevraagd worden of je dat bij de volgende herstart van Windows wilt laten doorvoeren. Bevestig dat en dan herstarten.
Tijs.
Tijs.
Er zijn geen problemen gevonden maar heb tot nu toe geen BSOD meer gehad
maar dat komt denk ik wel weer :\
