Heb je een installatie CD van XP? Anders eentje van iemand lenen en op een gegeven moment jouw product nummer invullen. De partitie aan het begin met de letter D deleten en XP op een nieuwe partitie installeren.
En anders...
zie ik in het Dell Dimension 5150/E510 Owner’s Manual blz 55 een verhaal over Dell PC Restore.
Use Dell PC Restore by Symantec only as the last method to restore your operating system.
PC Restore restores your hard drive to the operating state it was in when you purchased the computer.
Any programs or files added since you received your computer -including data files- are permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail messages, digital photos, music files, and so on. If possible, back up all data before using PC Restore.
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with
www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
7 Click Next. The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
