Blocken
tedjansen11
Verenigingslid
8 mei 2009
Hoi allemaal!
Ik heb hier een .htacces file staan, Die wil ik zo instellen dat ik 3 IP adressen kan allowen om in de directory te gaan.
Hieronder mijn file , let wel op de andere regels moeten blijven! ( onderaan staat mijn stukje )
Nu als ik naar de site ga wordt ik ook geblockt ook al ga ik vanaf die IP's
# Apache/PHP/Drupal settings:
# Protect files and directories from prying eyes.
<FilesMatch "\.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl|svn-base)$|^(code-style\.pl|Entries.*|Repository|Root|Tag|Template|all-wcprops|entries|format)$">
  Order allow,deny
</FilesMatch>
# Don't show directory listings for URLs which map to a directory.
Options -Indexes
# Follow symbolic links in this directory.
Options +FollowSymLinks
# Make Drupal handle any 404 errors.
ErrorDocument 404 /index.php
# Force simple error message for requests for non-existent favicon.ico.
<Files favicon.ico>
  # There is no end quote below, for compatibility with Apache 1.3.
  ErrorDocument 404 "The requested file favicon.ico was not found.
</Files>
# Set the default handler.
DirectoryIndex index.php
# Override PHP settings. More in sites/default/settings.php
# but the following cannot be changed at runtime.
# PHP 4, Apache 1.
<IfModule mod_php4.c>
  php_value magic_quotes_gpc                0
  php_value register_globals                0
  php_value session.auto_start              0
  php_value mbstring.http_input             pass
  php_value mbstring.http_output            pass
  php_value mbstring.encoding_translation   0
</IfModule>
# PHP 4, Apache 2.
<IfModule sapi_apache2.c>
</IfModule>
# PHP 5, Apache 1 and 2.
<IfModule mod_php5.c>
</IfModule>
# Requires mod_expires to be enabled.
<IfModule mod_expires.c>
  # Enable expirations.
  ExpiresActive On
  # Cache all files for 2 weeks after access (A).
  ExpiresDefault A1209600
  <FilesMatch \.php$>
    # Do not allow PHP scripts to be cached unless they explicitly send cache
    # headers themselves. Otherwise all scripts would have to overwrite the
    # headers set by mod_expires if they want another caching behavior. This may
    # fail if an error occurs early in the bootstrap process, and it may cause
    # problems if a non-Drupal PHP file is installed in a subdirectory.
    ExpiresActive Off
  </FilesMatch>
</IfModule>
# Various rewrite rules.
<IfModule mod_rewrite.c>
  RewriteEngine on
  # If your site can be accessed both with and without the 'www.' prefix, you
  # can use one of the following settings to redirect users to your preferred
  # URL, either WITH or WITHOUT the 'www.' prefix. Choose ONLY one option:
  # To redirect all users to access the site WITH the 'www.' prefix,
  # (http://example.com/... will be redirected to http://www.example.com/...)
  # adapt and uncomment the following:
  # RewriteCond %{HTTP_HOST} ^example\.com$ [NC]
  # RewriteRule ^(.*)$ http://www.example.com/$1 [L,R=301]
  # To redirect all users to access the site WITHOUT the 'www.' prefix,
  # (http://www.example.com/... will be redirected to http://example.com/...)
  # uncomment and adapt the following:
  # RewriteCond %{HTTP_HOST} ^www\.example\.com$ [NC]
  # RewriteRule ^(.*)$ http://example.com/$1 [L,R=301]
  # Modify the RewriteBase if you are using Drupal in a subdirectory or in a
  # VirtualDocumentRoot and the rewrite rules are not working properly.
  # For example if your site is at http://example.com/drupal uncomment and
  # modify the following line:
  # RewriteBase /drupal
  # If your site is running in a VirtualDocumentRoot at http://example.com/,
  # uncomment the following line:
  # RewriteBase /
  # Rewrite URLs of the form 'x' to the form 'index.php?q=x'.
  RewriteCond %{REQUEST_FILENAME} !-f
  RewriteCond %{REQUEST_FILENAME} !-d
  RewriteCond %{REQUEST_URI} !=/favicon.ico
  RewriteRule ^(.*)$ index.php?q=$1 [L,QSA]
</IfModule>
# $Id$
Order allow,Deny
allow from IP1;IP2;IP3
Deny from all
side note: is het niet makkelijker om mac adressen in te stellen? ip's die willen nogal eens veranderen.
MAC-adressen kun je niet instellen voor een website. Dat verkeer loopt over HTTP, en dat functioneert middels het TCP-protocol. En TCP = IP (of beter gezegd: TCP is one of the two original components of the suite, complementing the Internet Protocol (IP), and therefore the entire suite is commonly referred to as TCP/IP) en geen MAC. Dat zit een niveau lager.
Over het internet worden alleen IP-adressen verzonden.
