[ 18.623] (II) RADEON(0): Supported established timings:
[ 18.623] (II) RADEON(0): 720x400@70Hz
[ 18.623] (II) RADEON(0): 640x480@60Hz
[ 18.623] (II) RADEON(0): 640x480@67Hz
[ 18.623] (II) RADEON(0): 640x480@72Hz
[ 18.623] (II) RADEON(0): 640x480@75Hz
[ 18.623] (II) RADEON(0): 800x600@56Hz
[ 18.623] (II) RADEON(0): 800x600@60Hz
[ 18.623] (II) RADEON(0): 800x600@72Hz
[ 18.623] (II) RADEON(0): 800x600@75Hz
[ 18.623] (II) RADEON(0): 832x624@75Hz
[ 18.623] (II) RADEON(0): 1024x768@60Hz
[ 18.623] (II) RADEON(0): 1024x768@70Hz
[ 18.623] (II) RADEON(0): 1024x768@75Hz
[ 18.623] (II) RADEON(0): 1280x1024@75Hz
[ 18.623] (II) RADEON(0): Manufacturer's mask: 0
[ 18.623] (II) RADEON(0): Supported standard timings:
[ 18.623] (II) RADEON(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 18.623] (II) RADEON(0): Supported detailed timing:
[ 18.623] (II) RADEON(0): clock: 108.0 MHz Image Size: 337 x 270 mm
[ 18.623] (II) RADEON(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 18.623] (II) RADEON(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 18.623] (II) RADEON(0): Monitor name: NECCI CT700pm
[ 18.623] (II) RADEON(0): Ranges: V min: 60 V max: 75 Hz, H min: 30 H max: 80 kHz, PixClock max 145 MHz
[ 18.623] (II) RADEON(0): Serial No: 101730133188
[ 18.623] (II) RADEON(0): EDID (in hex):
[ 18.623] (II) RADEON(0): 00ffffffffffff003869415044080200
[ 18.623] (II) RADEON(0): 0c0f010368221b962a6e06a1544c9926
[ 18.623] (II) RADEON(0): 194f54bfef0001010101010101018180
[ 18.623] (II) RADEON(0): 000000000000302a009851002a403070
[ 18.623] (II) RADEON(0): 1300510e1100001e000000fc004e4543
[ 18.623] (II) RADEON(0): 4349204354373030706d000000fd003c
[ 18.623] (II) RADEON(0): 4b1e500e000a202020202020000000ff
[ 18.623] (II) RADEON(0): 003130313733303133333138380a006d
[ 18.623] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 18.623] (II) RADEON(0): Using EDID range info for horizontal sync
[ 18.623] (II) RADEON(0): Using EDID range info for vertical refresh
[ 18.623] (II) RADEON(0): Printing DDC gathered Modelines:
[ 18.623] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 18.623] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 18.623] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 18.623] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 18.623] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 18.623] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 18.623] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 18.623] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 18.623] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 18.623] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 18.623] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 18.623] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 18.624] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 18.624] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 18.624] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 18.624] (II) RADEON(0): Printing probed modes for output VGA-0
[ 18.624] (II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 18.624] (II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 18.624] (II) RADEON(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
[ 18.624] (II) RADEON(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 18.624] (II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 18.624] (II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 18.624] (II) RADEON(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 18.624] (II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 18.624] (II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 18.624] (II) RADEON(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 18.624] (II) RADEON(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
[ 18.624] (II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 18.624] (II) RADEON(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 18.624] (II) RADEON(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 18.624] (II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 18.645] (II) RADEON(0): EDID for output S-video
[ 18.645] (II) RADEON(0): Output VGA-0 connected
[ 18.645] (II) RADEON(0): Output S-video disconnected
[ 18.645] (II) RADEON(0): Using exact sizes for initial modes
[ 18.649] (II) RADEON(0): Output VGA-0 using initial mode 1280x1024
[ 18.650] (II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 18.650] (II) RADEON(0): mem size init: gart size :1fdff000 vram size: s:2000000 visible:1e80000
[ 18.650] (II) RADEON(0): EXA: Driver will not allow EXA pixmaps in VRAM
[ 18.650] (**) RADEON(0): Display dimensions: (340, 270) mm
[ 18.650] (**) RADEON(0): DPI set to (95, 96)
[ 18.650] (II) Loading sub module "fb"
[ 18.650] (II) LoadModule: "fb"
[ 18.650] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 18.691] (II) Module fb: vendor="X.Org Foundation"
[ 18.691] compiled for 1.10.4, module version = 1.0.0
[ 18.691] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.691] (II) Loading sub module "ramdac"
[ 18.691] (II) LoadModule: "ramdac"
[ 18.691] (II) Module "ramdac" already built-in
[ 18.691] (II) UnloadModule: "vesa"
[ 18.692] (II) Unloading vesa
[ 18.692] (II) UnloadModule: "fbdev"
[ 18.692] (II) Unloading fbdev
[ 18.692] (II) UnloadModule: "fbdevhw"
[ 18.692] (II) Unloading fbdevhw
[ 18.692] (--) Depth 24 pixmap format is 32 bpp
[ 18.692] (II) RADEON(0): [DRI2] Setup complete
[ 18.692] (II) RADEON(0): [DRI2] DRI driver: r300
[ 18.692] (II) RADEON(0): Front buffer size: 5120K
[ 18.692] (II) RADEON(0): VRAM usage limit set to 23500K
[ 18.820] (==) RADEON(0): Backing store disabled
[ 18.820] (II) RADEON(0): Direct rendering enabled
[ 18.870] (II) RADEON(0): Render acceleration enabled for R300/R400/R500 type cards.
[ 18.870] (II) RADEON(0): Setting EXA maxPitchBytes
[ 18.870] (II) EXA(0): Driver allocated offscreen pixmaps
[ 18.870] (II) EXA(0): Driver registered support for the following operations:
[ 18.870] (II) Solid
[ 18.870] (II) Copy
[ 18.870] (II) Composite (RENDER acceleration)
[ 18.870] (II) UploadToScreen
[ 18.870] (II) DownloadFromScreen
[ 18.891] (II) RADEON(0): Acceleration enabled
[ 18.891] (==) RADEON(0): DPMS enabled
[ 18.891] (==) RADEON(0): Silken mouse enabled
[ 18.937] (II) RADEON(0): Set up textured video
[ 18.937] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
[ 18.937] (II) RADEON(0): [XvMC] Extension initialized.
[ 18.937] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 18.937] (--) RandR disabled
[ 18.937] (II) Initializing built-in extension Generic Event Extension
[ 18.937] (II) Initializing built-in extension SHAPE
[ 18.937] (II) Initializing built-in extension MIT-SHM
[ 18.937] (II) Initializing built-in extension XInputExtension
[ 18.937] (II) Initializing built-in extension XTEST
[ 18.937] (II) Initializing built-in extension BIG-REQUESTS
[ 18.937] (II) Initializing built-in extension SYNC
[ 18.937] (II) Initializing built-in extension XKEYBOARD
[ 18.937] (II) Initializing built-in extension XC-MISC
[ 18.937] (II) Initializing built-in extension SECURITY
[ 18.937] (II) Initializing built-in extension XINERAMA
[ 18.937] (II) Initializing built-in extension XFIXES
[ 18.937] (II) Initializing built-in extension RENDER
[ 18.937] (II) Initializing built-in extension RANDR
[ 18.937] (II) Initializing built-in extension COMPOSITE
[ 18.937] (II) Initializing built-in extension DAMAGE
[ 18.937] (II) Initializing built-in extension GESTURE
[ 19.074] (II) AIGLX: Trying DRI driver /usr/lib/i386-linux-gnu/dri/r300_dri.so
[ 21.952] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 22.480] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 22.480] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 22.480] (II) AIGLX: enabled GLX_SGI_make_current_read
[ 22.480] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 22.481] (II) AIGLX: Loaded and initialized r300
[ 22.481] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 22.482] (II) RADEON(0): Setting screen physical size to 338 x 270
[ 23.052] (II) XKB: generating xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 24.939] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 24.939] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 24.939] (II) LoadModule: "evdev"
[ 24.939] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.230] (II) Module evdev: vendor="X.Org Foundation"
[ 25.230] compiled for 1.10.2, module version = 2.6.0
[ 25.230] Module class: X.Org XInput Driver
[ 25.230] ABI class: X.Org XInput driver, version 12.3
[ 25.230] (II) Using input driver 'evdev' for 'Power Button'
[ 25.230] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.230] (**) Power Button: always reports core events
[ 25.230] (**) Power Button: Device: "/dev/input/event1"
[ 25.230] (--) Power Button: Found keys
[ 25.230] (II) Power Button: Configuring as keyboard
[ 25.230] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 25.230] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 25.230] (**) Option "xkb_rules" "evdev"
[ 25.230] (**) Option "xkb_model" "pc105"
[ 25.230] (**) Option "xkb_layout" "us"
[ 25.230] (**) Option "xkb_variant" "intl"
[ 25.234] (II) XKB: generating xkmfile /var/lib/xkb/server-A5431D4A34463C892C9E905E2E421B30A3CC30DD.xkm
[ 25.323] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 25.323] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 25.323] (II) Using input driver 'evdev' for 'Power Button'
[ 25.323] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.324] (**) Power Button: always reports core events
[ 25.324] (**) Power Button: Device: "/dev/input/event0"
[ 25.324] (--) Power Button: Found keys
[ 25.324] (II) Power Button: Configuring as keyboard
[ 25.324] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[ 25.324] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 25.324] (**) Option "xkb_rules" "evdev"
[ 25.324] (**) Option "xkb_model" "pc105"
[ 25.324] (**) Option "xkb_layout" "us"
[ 25.324] (**) Option "xkb_variant" "intl"
[ 25.344] (II) config/udev: Adding input device Trust Gamer Mouse (/dev/input/event3)
[ 25.344] (**) Trust Gamer Mouse: Applying InputClass "evdev keyboard catchall"
[ 25.344] (II) Using input driver 'evdev' for 'Trust Gamer Mouse'
[ 25.344] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.344] (**) Trust Gamer Mouse: always reports core events
[ 25.344] (**) Trust Gamer Mouse: Device: "/dev/input/event3"
[ 25.344] (--) Trust Gamer Mouse: Found keys
[ 25.344] (II) Trust Gamer Mouse: Configuring as keyboard
[ 25.344] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.3/usb5/5-1/5-1:1.0/input/input3/event3"
[ 25.344] (II) XINPUT: Adding extended input device "Trust Gamer Mouse" (type: KEYBOARD)
[ 25.344] (**) Option "xkb_rules" "evdev"
[ 25.344] (**) Option "xkb_model" "pc105"
[ 25.344] (**) Option "xkb_layout" "us"
[ 25.344] (**) Option "xkb_variant" "intl"
[ 25.346] (II) config/udev: Adding input device Trust Gamer Mouse (/dev/input/event4)
[ 25.346] (**) Trust Gamer Mouse: Applying InputClass "evdev pointer catchall"
[ 25.346] (**) Trust Gamer Mouse: Applying InputClass "evdev keyboard catchall"
[ 25.346] (II) Using input driver 'evdev' for 'Trust Gamer Mouse'
[ 25.346] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.346] (**) Trust Gamer Mouse: always reports core events
[ 25.346] (**) Trust Gamer Mouse: Device: "/dev/input/event4"
[ 25.346] (--) Trust Gamer Mouse: Found 9 mouse buttons
[ 25.346] (--) Trust Gamer Mouse: Found scroll wheel(s)
[ 25.346] (--) Trust Gamer Mouse: Found relative axes
[ 25.346] (--) Trust Gamer Mouse: Found x and y relative axes
[ 25.346] (--) Trust Gamer Mouse: Found absolute axes
[ 25.346] (II) evdev-grail: failed to open grail, no gesture support
[ 25.346] (--) Trust Gamer Mouse: Found keys
[ 25.346] (II) Trust Gamer Mouse: Configuring as mouse
[ 25.346] (II) Trust Gamer Mouse: Configuring as keyboard
[ 25.346] (II) Trust Gamer Mouse: Adding scrollwheel support
[ 25.346] (**) Trust Gamer Mouse: YAxisMapping: buttons 4 and 5
[ 25.346] (**) Trust Gamer Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 25.346] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.3/usb5/5-1/5-1:1.1/input/input4/event4"
[ 25.346] (II) XINPUT: Adding extended input device "Trust Gamer Mouse" (type: KEYBOARD)
[ 25.346] (**) Option "xkb_rules" "evdev"
[ 25.346] (**) Option "xkb_model" "pc105"
[ 25.346] (**) Option "xkb_layout" "us"
[ 25.346] (**) Option "xkb_variant" "intl"
[ 25.351] (II) Trust Gamer Mouse: initialized for relative axes.
[ 25.351] (WW) Trust Gamer Mouse: ignoring absolute axes.
[ 25.351] (**) Trust Gamer Mouse: (accel) keeping acceleration scheme 1
[ 25.351] (**) Trust Gamer Mouse: (accel) acceleration profile 0
[ 25.351] (**) Trust Gamer Mouse: (accel) acceleration factor: 2.000
[ 25.351] (**) Trust Gamer Mouse: (accel) acceleration threshold: 4
[ 25.352] (II) config/udev: Adding input device Trust Gamer Mouse (/dev/input/mouse0)
[ 25.352] (II) No input driver/identifier specified (ignoring)
[ 25.369] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 25.369] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.369] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 25.369] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.369] (**) AT Translated Set 2 keyboard: always reports core events
[ 25.369] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[ 25.369] (--) AT Translated Set 2 keyboard: Found keys
[ 25.369] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[ 25.369] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 25.369] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[ 25.369] (**) Option "xkb_rules" "evdev"
[ 25.369] (**) Option "xkb_model" "pc105"
[ 25.369] (**) Option "xkb_layout" "us"
[ 25.369] (**) Option "xkb_variant" "intl"
[ 33.067] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 33.067] (II) RADEON(0): Using hsync ranges from config file
[ 33.067] (II) RADEON(0): Using vrefresh ranges from config file
[ 33.067] (II) RADEON(0): Printing DDC gathered Modelines:
[ 33.068] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 33.068] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 33.068] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 33.068] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 33.068] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 33.068] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 33.068] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 33.068] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 33.068] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 33.068] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 33.068] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 33.068] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 33.068] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 33.068] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 33.068] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 40.554] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 40.554] (II) RADEON(0): Using hsync ranges from config file
[ 40.554] (II) RADEON(0): Using vrefresh ranges from config file
[ 40.554] (II) RADEON(0): Printing DDC gathered Modelines:
[ 40.554] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 40.554] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 40.554] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 40.554] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 40.554] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 40.554] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 40.554] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 40.554] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 40.554] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 40.554] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 40.554] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 40.554] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 40.554] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 40.554] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 40.554] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 57.715] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 57.715] (II) RADEON(0): Using hsync ranges from config file
[ 57.715] (II) RADEON(0): Using vrefresh ranges from config file
[ 57.715] (II) RADEON(0): Printing DDC gathered Modelines:
[ 57.715] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 57.715] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 57.715] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 57.715] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 57.715] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 57.715] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 57.715] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 57.715] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 57.715] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 57.715] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 57.715] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 57.715] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 57.715] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 57.715] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 57.715] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 58.930] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 58.930] (II) RADEON(0): Using hsync ranges from config file
[ 58.930] (II) RADEON(0): Using vrefresh ranges from config file
[ 58.930] (II) RADEON(0): Printing DDC gathered Modelines:
[ 58.930] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 58.930] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 58.930] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 58.930] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 58.930] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 58.930] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 58.930] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 58.930] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 58.930] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 58.930] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 58.930] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 58.930] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 58.930] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 58.930] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 58.930] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 59.233] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 59.233] (II) RADEON(0): Using hsync ranges from config file
[ 59.233] (II) RADEON(0): Using vrefresh ranges from config file
[ 59.233] (II) RADEON(0): Printing DDC gathered Modelines:
[ 59.233] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 59.233] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 59.233] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 59.233] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 59.233] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 59.233] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 59.233] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 59.233] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 59.233] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 59.234] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 59.234] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 59.234] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 59.234] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 59.234] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 59.234] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 69.920] (II) RADEON(0): EDID vendor "NCI", prod id 20545
[ 69.920] (II) RADEON(0): Using hsync ranges from config file
[ 69.920] (II) RADEON(0): Using vrefresh ranges from config file
[ 69.920] (II) RADEON(0): Printing DDC gathered Modelines:
[ 69.920] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 69.920] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 69.920] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 69.920] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 69.920] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 69.920] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 69.920] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 69.920] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 69.920] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 69.920] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 69.920] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 69.920] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 69.920] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 69.920] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 69.921] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 76.779] (II) XKB: generating xkmfile /var/lib/xkb/server-CA82093D38BFEAEF36BB4318AC0909BE2F4873AE.xkm
