barendrecht82
- 24 mrt 2013
Option Compare Database
Private Sub Form_Current()
DoCmd.SetWarnings False
Dim Connectie As ADODB.Connection
Dim rs_Query As ADODB.Recordset
Dim Excel As Excel.Application
Dim Workbook As Workbook
Dim Mail As Outlook.Application
Dim Mail_Item As Outlook.MailItem
Dim t As Integer
Dim Query_Name As String
Dim Output_File_Name As String
Dim Mail_To As String
Dim Mail_CC As String
Dim Mail_BCC As String
Dim Mail_Subject As String
Dim Mail_Body As String
Dim Datum As String
Datum = Format(Now, "d mmm yyyy")
'* Vullen van variabelen *
Query_Name = "qry_stadswandeling"
Output_File_Name = "C:\wandels.xls"
Mail_To = Mail_To & "test@test.nl"
Mail_Subject = "wandeling " & Datum
Mail_Body = "This is an automatically generated E-mail message. Please do not reply"
'* Recordset opbouwen, Excel sheet vullen, .CSV file aanmaken en via E-mail versturen *
Set Connectie = CurrentProject.Connection
Set rs_Query = New ADODB.Recordset
rs_Query.Open Query_Name, Connectie, adOpenKeyset, adLockOptimistic, adCmdTable
If rs_Query.RecordCount = 0 Then
Set Excel = New Excel.Application
Excel.Visible = False
Set Workbook = GetObject("C:\wandels - Blanco.xls")
t = 8
Workbook.Worksheets(1).Range("A2").Value = "Orders on Hold, " & Datum
While rs_Query.EOF = False
Workbook.Worksheets(1).Range("A" & t).Value = rs_Query!Account
Workbook.Worksheets(1).Range("B" & t).Value = rs_Query!Debiteur
Workbook.Worksheets(1).Range("C" & t).Value = rs_Query!Verkooporder
Workbook.Worksheets(1).Range("D" & t).Value = rs_Query!cddeb
Workbook.Worksheets(1).Range("E" & t).Value = rs_Query!ordersoort
Workbook.Worksheets(1).Range("F" & t).Value = rs_Query!omschrijving
Workbook.Worksheets(1).Range("G" & t).Value = rs_Query!orderbedrag
Workbook.Worksheets(1).Range("H" & t).Value = rs_Query!cdstatus
t = t + 1
rs_Query.MoveNext
Wend
Kill Output_File_Name
Workbook.SaveAs FileName:=Output_File_Name, FileFormat:=xlWorkbookNormal, CreateBackup:=False, Local:=True
Workbook.Close SaveChanges:=False
Excel.Quit
Debug.Print Mail_Subject
Set Mail = New Outlook.Application
Set Mail_Item = Mail.CreateItem(olMailItem)
With Mail_Item
.To = Mail_To
.CC = Mail_CC
.BCC = Mail_BCC
.Subject = Mail_Subject
.Body = Mail_Body
.Importance = olImportanceNormal
.Attachments.Add Output_File_Name
.Send
rs_Query.Close 'Afsluiten objecten
Connectie.Close
Set rs_Query = Nothing
Set Connectie = Nothing
DoCmd.Quit 'Afsluiten MS Access
Ik ben namelijk bezig om een mail uit te sturen uit het systeem om die vervolgens in excel te krijgen. Alleen ik krijg nu elke keer Blok IF problemen...
Wat doe ik fout?
Dim t As Integer
Dim Datum As String
t = 8
t = t + 1
rs_Query.MoveNext
Wend
Excel.Quit
With Mail_Item
.To = Mail_To
.CC = Mail_CC
.BCC = Mail_BCC
.Body = Mail_Body
.Send
Connectie.Close
Wat doe ik fout?
