PHP foutmelding
RickGAE
6 apr 2012
Mijn wordpress site geeft een foutmelding op alle losse pagina's, op de homepage dus niet.
Dit is de melding:
Warning: call_user_func_array() expects parameter 1 to be a valid callback, function 'prefix_add_my_stylesheet' not found or invalid function name in /home/*********/*******/fifa-nederland.nl/public_html/wp-includes/plugin.php on line 406
Dit is plugin.php:
PHP:
<?php
 * The plugin API is located in this file, which allows for creating actions
 * and filters and hooking functions, and methods. The functions or methods will
 * then be run when the action or filter is called.
 * The API callback examples reference functions, but can be methods of classes.
 * To hook methods, you'll need to pass an array one of two ways.
 * Any of the syntaxes explained in the PHP documentation for the
 * {@link http://us2.php.net/manual/en/language.pseudo-types.php#language.types.callback 'callback'}
 * type are valid.
 * Also see the {@link http://codex.wordpress.org/Plugin_API Plugin API} for
 * more information and examples on how to use a lot of these functions.
 * @package WordPress
 * @subpackage Plugin
 * @since 1.5
 * Hooks a function or method to a specific filter action.
 * Filters are the hooks that WordPress launches to modify text of various types
 * before adding it to the database or sending it to the browser screen. Plugins
 * can specify that one or more of its PHP functions is executed to
 * modify specific types of text at these times, using the Filter API.
 * To use the API, the following code should be used to bind a callback to the
 * filter.
 * <code>
 * function example_hook($example) { echo $example; }
 * add_filter('example_filter', 'example_hook');
 * </code>
 * In WordPress 1.5.1+, hooked functions can take extra arguments that are set
 * when the matching do_action() or apply_filters() call is run. The
 * $accepted_args allow for calling functions only when the number of args
 * match. Hooked functions can take extra arguments that are set when the
 * matching do_action() or apply_filters() call is run. For example, the action
 * comment_id_not_found will pass any functions that hook onto it the ID of the
 * requested comment.
 * <strong>Note:</strong> the function will return true no matter if the
 * function was hooked fails or not. There are no checks for whether the
 * function exists beforehand and no checks to whether the <tt>$function_to_add
 * is even a string. It is up to you to take care and this is done for
 * optimization purposes, so everything is as quick as possible.
 * @since 0.71
 * @global array $wp_filter Stores all of the filters added in the form of
 *	wp_filter['tag']['array of priorities']['array of functions serialized']['array of ['array (functions, accepted_args)']']
 * @global array $merged_filters Tracks the tags that need to be merged for later. If the hook is added, it doesn't need to run through that process.
 * @param string $tag The name of the filter to hook the $function_to_add to.
 * @param callback $function_to_add The name of the function to be called when the filter is applied.
 * @param int $priority optional. Used to specify the order in which the functions associated with a particular action are executed (default: 10). Lower numbers correspond with earlier execution, and functions with the same priority are executed in the order in which they were added to the action.
 * @param int $accepted_args optional. The number of arguments the function accept (default 1).
 * @return boolean true
function add_filter($tag, $function_to_add, $priority = 10, $accepted_args = 1) {
	global $wp_filter, $merged_filters;
	$idx = _wp_filter_build_unique_id($tag, $function_to_add, $priority);
	$wp_filter[$tag][$priority][$idx] = array('function' => $function_to_add, 'accepted_args' => $accepted_args);
	unset( $merged_filters[ $tag ] );
	return true;
 * Check if any filter has been registered for a hook.
 * @since 2.5
 * @param string $tag The name of the filter hook.
 * @param callback $function_to_check optional.
 * @return mixed If $function_to_check is omitted, returns boolean for whether the hook has anything registered.
 * 	When checking a specific function, the priority of that hook is returned, or false if the function is not attached.
 * 	When using the $function_to_check argument, this function may return a non-boolean value that evaluates to false
 * 	(e.g.) 0, so use the === operator for testing the return value.
function has_filter($tag, $function_to_check = false) {
	global $wp_filter;
	$has = !empty($wp_filter[$tag]);
	if ( false === $function_to_check || false == $has )
		return $has;
	if ( !$idx = _wp_filter_build_unique_id($tag, $function_to_check, false) )
		return false;
	foreach ( (array) array_keys($wp_filter[$tag]) as $priority ) {
		if ( isset($wp_filter[$tag][$priority][$idx]) )
			return $priority;
	return false;
 * Call the functions added to a filter hook.
 * The callback functions attached to filter hook $tag are invoked by calling
 * this function. This function can be used to create a new filter hook by
 * simply calling this function with the name of the new hook specified using
 * the $tag parameter.
 * The function allows for additional arguments to be added and passed to hooks.
 * <code>
 * function example_hook($string, $arg1, $arg2)
 *		//Do stuff
 *		return $string;
 * $value = apply_filters('example_filter', 'filter me', 'arg1', 'arg2');
 * </code>
 * @since 0.71
 * @global array $merged_filters Merges the filter hooks using this function.
 * @global array $wp_current_filter stores the list of current filters with the current one last
 * @param mixed $value The value on which the filters hooked to <tt>$tag</tt> are applied on.
 * @param mixed $var,... Additional variables passed to the functions hooked to <tt>$tag</tt>.
 * @return mixed The filtered value after all hooked functions are applied to it.
function apply_filters($tag, $value) {
	global $wp_filter, $merged_filters, $wp_current_filter;
	$args = array();
	// Do 'all' actions first
	if ( isset($wp_filter['all']) ) {
		$wp_current_filter[] = $tag;
		$args = func_get_args();
		_wp_call_all_hook($args);
	if ( !isset($wp_filter[$tag]) ) {
			array_pop($wp_current_filter);
		return $value;
	if ( !isset($wp_filter['all']) )
	// Sort
	if ( !isset( $merged_filters[ $tag ] ) ) {
		ksort($wp_filter[$tag]);
		$merged_filters[ $tag ] = true;
	reset( $wp_filter[ $tag ] );
	if ( empty($args) )
	do {
		foreach( (array) current($wp_filter[$tag]) as $the_ )
			if ( !is_null($the_['function']) ){
				$args[1] = $value;
				$value = call_user_func_array($the_['function'], array_slice($args, 1, (int) $the_['accepted_args']));
	} while ( next($wp_filter[$tag]) !== false );
	array_pop( $wp_current_filter );
	return $value;
 * Execute functions hooked on a specific filter hook, specifying arguments in an array.
 * @see apply_filters() This function is identical, but the arguments passed to the
 * functions hooked to <tt>$tag</tt> are supplied using an array.
 * @since 3.0.0
 * @param array $args The arguments supplied to the functions hooked to <tt>$tag</tt>
function apply_filters_ref_array($tag, $args) {
		$all_args = func_get_args();
		_wp_call_all_hook($all_args);
		return $args[0];
	// Sort
	do {
				$args[0] = call_user_func_array($the_['function'], array_slice($args, 0, (int) $the_['accepted_args']));
	return $args[0];
 * Removes a function from a specified filter hook.
 * This function removes a function attached to a specified filter hook. This
 * method can be used to remove default functions attached to a specific filter
 * hook and possibly replace them with a substitute.
 * To remove a hook, the $function_to_remove and $priority arguments must match
 * when the hook was added. This goes for both filters and actions. No warning
 * will be given on removal failure.
 * @since 1.2
 * @param string $tag The filter hook to which the function to be removed is hooked.
 * @param callback $function_to_remove The name of the function which should be removed.
 * @param int $priority optional. The priority of the function (default: 10).
 * @param int $accepted_args optional. The number of arguments the function accepts (default: 1).
 * @return boolean Whether the function existed before it was removed.
function remove_filter( $tag, $function_to_remove, $priority = 10 ) {
	$function_to_remove = _wp_filter_build_unique_id($tag, $function_to_remove, $priority);
	$r = isset($GLOBALS['wp_filter'][$tag][$priority][$function_to_remove]);
	if ( true === $r) {
		unset($GLOBALS['wp_filter'][$tag][$priority][$function_to_remove]);
		if ( empty($GLOBALS['wp_filter'][$tag][$priority]) )
			unset($GLOBALS['wp_filter'][$tag][$priority]);
		unset($GLOBALS['merged_filters'][$tag]);
	return $r;
 * Remove all of the hooks from a filter.
 * @since 2.7
 * @param string $tag The filter to remove hooks from.
 * @param int $priority The priority number to remove.
 * @return bool True when finished.
function remove_all_filters($tag, $priority = false) {
	if( isset($wp_filter[$tag]) ) {
		if( false !== $priority && isset($wp_filter[$tag][$priority]) )
			unset($wp_filter[$tag][$priority]);
		else
			unset($wp_filter[$tag]);
	if( isset($merged_filters[$tag]) )
		unset($merged_filters[$tag]);
	return true;
 * Retrieve the name of the current filter or action.
 * @since 2.5
 * @return string Hook name of the current filter or action.
function current_filter() {
	global $wp_current_filter;
	return end( $wp_current_filter );
 * Hooks a function on to a specific action.
 * Actions are the hooks that the WordPress core launches at specific points
 * during execution, or when specific events occur. Plugins can specify that
 * one or more of its PHP functions are executed at these points, using the
 * Action API.
 * @uses add_filter() Adds an action. Parameter list and functionality are the same.
 * @since 1.2
 * @param string $tag The name of the action to which the $function_to_add is hooked.
 * @param callback $function_to_add The name of the function you wish to be called.
function add_action($tag, $function_to_add, $priority = 10, $accepted_args = 1) {
	return add_filter($tag, $function_to_add, $priority, $accepted_args);
 * Execute functions hooked on a specific action hook.
 * This function invokes all functions attached to action hook $tag. It is
 * possible to create new action hooks by simply calling this function,
 * specifying the name of the new hook using the <tt>$tag</tt> parameter.
 * You can pass extra arguments to the hooks, much like you can with
 * apply_filters().
 * @see apply_filters() This function works similar with the exception that
 * nothing is returned and only the functions or methods are called.
 * @since 1.2
 * @global array $wp_actions Increments the amount of times action was triggered.
 * @param string $tag The name of the action to be executed.
 * @param mixed $arg,... Optional additional arguments which are passed on to the functions hooked to the action.
 * @return null Will return null if $tag does not exist in $wp_filter array
function do_action($tag, $arg = '') {
	global $wp_filter, $wp_actions, $merged_filters, $wp_current_filter;
	if ( ! isset($wp_actions) )
		$wp_actions = array();
	if ( ! isset($wp_actions[$tag]) )
		$wp_actions[$tag] = 1;
	else
		++$wp_actions[$tag];
		return;
	$args = array();
	if ( is_array($arg) && 1 == count($arg) && isset($arg[0]) && is_object($arg[0]) ) // array(&$this)
		$args[] =& $arg[0];
	else
		$args[] = $arg;
	for ( $a = 2; $a < func_num_args(); $a++ )
		$args[] = func_get_arg($a);
	// Sort
	do {
		foreach ( (array) current($wp_filter[$tag]) as $the_ )
 * Retrieve the number of times an action is fired.
 * @since 2.1
 * @param string $tag The name of the action hook.
 * @return int The number of times action hook <tt>$tag</tt> is fired
function did_action($tag) {
	global $wp_actions;
	if ( ! isset( $wp_actions ) || ! isset( $wp_actions[$tag] ) )
		return 0;
	return $wp_actions[$tag];
 * Execute functions hooked on a specific action hook, specifying arguments in an array.
 * @see do_action() This function is identical, but the arguments passed to the
 * @since 2.1
function do_action_ref_array($tag, $args) {
	else
		return;
	// Sort
	do {
 * Check if any action has been registered for a hook.
 * @since 2.5
 * @see has_filter() has_action() is an alias of has_filter().
function has_action($tag, $function_to_check = false) {
	return has_filter($tag, $function_to_check);
 * Removes a function from a specified action hook.
 * This function removes a function attached to a specified action hook. This
 * @since 1.2
 * @param string $tag The action hook to which the function to be removed is hooked.
 * @param int $priority optional The priority of the function (default: 10).
 * @return boolean Whether the function is removed.
function remove_action( $tag, $function_to_remove, $priority = 10 ) {
	return remove_filter( $tag, $function_to_remove, $priority );
 * Remove all of the hooks from an action.
 * @since 2.7
 * @param string $tag The action to remove hooks from.
 * @param int $priority The priority number to remove them from.
function remove_all_actions($tag, $priority = false) {
	return remove_all_filters($tag, $priority);
// Functions for handling plugins.
 * Gets the basename of a plugin.
 * This method extracts the name of a plugin from its filename.
 * @since 1.5
 * @access private
 * @param string $file The filename of plugin.
 * @return string The name of a plugin.
 * @uses WP_PLUGIN_DIR
function plugin_basename($file) {
	$file = str_replace('\\','/',$file); // sanitize for Win32 installs
	$file = preg_replace('|/+|','/', $file); // remove any duplicate slash
	$plugin_dir = str_replace('\\','/',WP_PLUGIN_DIR); // sanitize for Win32 installs
	$plugin_dir = preg_replace('|/+|','/', $plugin_dir); // remove any duplicate slash
	$mu_plugin_dir = str_replace('\\','/',WPMU_PLUGIN_DIR); // sanitize for Win32 installs
	$mu_plugin_dir = preg_replace('|/+|','/', $mu_plugin_dir); // remove any duplicate slash
	$file = preg_replace('#^' . preg_quote($plugin_dir, '#') . '/|^' . preg_quote($mu_plugin_dir, '#') . '/#','',$file); // get relative path from plugins dir
	$file = trim($file, '/');
	return $file;
 * Gets the filesystem directory path (with trailing slash) for the plugin __FILE__ passed in
 * @since 2.8
 * @param string $file The filename of the plugin (__FILE__)
 * @return string the filesystem path of the directory that contains the plugin
function plugin_dir_path( $file ) {
	return trailingsla****( dirname( $file ) );
 * Gets the URL directory path (with trailing slash) for the plugin __FILE__ passed in
 * @since 2.8
 * @return string the URL path of the directory that contains the plugin
function plugin_dir_url( $file ) {
	return trailingsla****( plugins_url( '', $file ) );
 * Set the activation hook for a plugin.
 * When a plugin is activated, the action 'activate_PLUGINNAME' hook is
 * activated. In the name of this hook, PLUGINNAME is replaced with the name of
 * the plugin, including the optional subdirectory. For example, when the plugin
 * is located in wp-content/plugin/sampleplugin/sample.php, then the name of
 * this hook will become 'activate_sampleplugin/sample.php'. When the plugin
 * consists of only one file and is (as by default) located at
 * wp-content/plugin/sample.php the name of this hook will be
 * 'activate_sample.php'.
 * @since 2.0
 * @param string $file The filename of the plugin including the path.
 * @param callback $function the function hooked to the 'activate_PLUGIN' action.
function register_activation_hook($file, $function) {
	$file = plugin_basename($file);
	add_action('activate_' . $file, $function);
 * Set the deactivation hook for a plugin.
 * When a plugin is deactivated, the action 'deactivate_PLUGINNAME' hook is
 * deactivated. In the name of this hook, PLUGINNAME is replaced with the name
 * of the plugin, including the optional subdirectory. For example, when the
 * plugin is located in wp-content/plugin/sampleplugin/sample.php, then
 * the name of this hook will become 'activate_sampleplugin/sample.php'.
 * When the plugin consists of only one file and is (as by default) located at
 * @since 2.0
function register_deactivation_hook($file, $function) {
	add_action('deactivate_' . $file, $function);
 * Set the uninstallation hook for a plugin.
 * Registers the uninstall hook that will be called when the user clicks on the
 * uninstall link that calls for the plugin to uninstall itself. The link won't
 * be active unless the plugin hooks into the action.
 * The plugin should not run arbitrary code outside of functions, when
 * registering the uninstall hook. In order to run using the hook, the plugin
 * will have to be included, which means that any code laying outside of a
 * function will be run during the uninstall process. The plugin should not
 * hinder the uninstall process.
 * If the plugin can not be written without running code within the plugin, then
 * the plugin should create a file named 'uninstall.php' in the base plugin
 * folder. This file will be called, if it exists, during the uninstall process
 * bypassing the uninstall hook. The plugin, when using the 'uninstall.php'
 * should always check for the 'WP_UNINSTALL_PLUGIN' constant, before
 * executing.
 * @since 2.7
 * @param callback $callback The callback to run when the hook is called. Must be a static method or function.
function register_uninstall_hook( $file, $callback ) {
	if ( is_array( $callback ) && is_object( $callback[0] ) ) {
		_doing_it_wrong( __FUNCTION__, __( 'Only a static class method or function can be used in an uninstall hook.' ), '3.1' );
		return;
	// The option should not be autoloaded, because it is not needed in most
	// cases. Emphasis should be put on using the 'uninstall.php' way of
	// uninstalling the plugin.
	$uninstallable_plugins = (array) get_option('uninstall_plugins');
	$uninstallable_plugins[plugin_basename($file)] = $callback;
	update_option('uninstall_plugins', $uninstallable_plugins);
 * Calls the 'all' hook, which will process the functions hooked into it.
 * The 'all' hook passes all of the arguments or parameters that were used for
 * the hook, which this function was called for.
 * This function is used internally for apply_filters(), do_action(), and
 * do_action_ref_array() and is not meant to be used from outside those
 * functions. This function does not check for the existence of the all hook, so
 * it will fail unless the all hook exists prior to this function call.
 * @since 2.5
 * @access private
 * @uses $wp_filter Used to process all of the functions in the 'all' hook
 * @param array $args The collected parameters from the hook that was called.
 * @param string $hook Optional. The hook name that was used to call the 'all' hook.
function _wp_call_all_hook($args) {
	global $wp_filter;
	reset( $wp_filter['all'] );
	do {
		foreach( (array) current($wp_filter['all']) as $the_ )
				call_user_func_array($the_['function'], $args);
	} while ( next($wp_filter['all']) !== false );
 * Build Unique ID for storage and retrieval.
 * The old way to serialize the callback caused issues and this function is the
 * solution. It works by checking for objects and creating an a new property in
 * the class to keep track of the object and new objects of the same class that
 * need to be added.
 * It also allows for the removal of actions and filters for objects after they
 * change class properties. It is possible to include the property $wp_filter_id
 * in your class and set it to "null" or a number to bypass the workaround.
 * However this will prevent you from adding new classes and any new classes
 * will overwrite the previous hook by the same class.
 * Functions and static method callbacks are just returned as strings and
 * shouldn't have any speed penalty.
 * @access private
 * @since 2.2.3
 * @link http://trac.wordpress.org/ticket/3875
 * @global array $wp_filter Storage for all of the filters and actions
 * @param string $tag Used in counting how many hooks were applied
 * @param callback $function Used for creating unique id
 * @param int|bool $priority Used in counting how many hooks were applied. If === false and $function is an object reference, we return the unique id only if it already has one, false otherwise.
 * @return string|bool Unique ID for usage as array key or false if $priority === false and $function is an object reference, and it does not already have a unique id.
function _wp_filter_build_unique_id($tag, $function, $priority) {
	global $wp_filter;
	static $filter_id_count = 0;
	if ( is_string($function) )
		return $function;
	if ( is_object($function) ) {
		// Closures are currently implemented as objects
		$function = array( $function, '' );
	} else {
		$function = (array) $function;
	if (is_object($function[0]) ) {
		// Object Class Calling
		if ( function_exists('spl_object_hash') ) {
			return spl_object_hash($function[0]) . $function[1];
		} else {
			$obj_idx = get_class($function[0]).$function[1];
			if ( !isset($function[0]->wp_filter_id) ) {
				if ( false === $priority )
					return false;
				$obj_idx .= isset($wp_filter[$tag][$priority]) ? count((array)$wp_filter[$tag][$priority]) : $filter_id_count;
				$function[0]->wp_filter_id = $filter_id_count;
				++$filter_id_count;
			} else {
				$obj_idx .= $function[0]->wp_filter_id;
			return $obj_idx;
	} else if ( is_string($function[0]) ) {
		// Static Calling
		return $function[0].$function[1];
Iemand de oplossing?
Bovenstaande vraag is opgelost, maar nu staan er steeds van deze:
Fatal error: Out of memory (allocated 37486592) (tried to allocate 122880 bytes) in /home/*********/domains/fifa-nederland.nl/public_html/wp-admin/custom-header.php on line 732
Simpel, het script probeert iets te doen waarvoor het meer geheugen nodig heeft dan het krijgt. Dat is niet ongewoon bij de goedkopere hosts.
Het is geen goedkope host, ik host mijn site bij iemand hier op het forum...
Wat is de oplossing?
Aan degene bij wie je host vragen of hij je meer geheugen toe wil wijzen. Of in het script duiken om te kijken of je het wat zuiniger kunt maken. Maar dat is verre van makkelijk.
Ik vraag het hem wel even, dank je.
Geheugen is volgens mij meer dan genoeg? Ik maak wel even een screenshot.
Hoeveel je uitendelijk nodg hebt is moeilijk te zeggen. Wij weten immers niet wat je gaat doen. Maar, in de regel moet 128MB voldoende zijn (misschien zelfs 64). Je kunt er achter komen hoeveel je hebt door op de server een PHP bestand aan te maken met daarin de volgende code.
PHP:
<?php phpinfo(); ?>
Als je dan met de browser naar dat bestand toe gaat krijg e een hele waslijst met instellingen te zien. Onder memory_limit vind je hoeveel geheugen je mag gebruiken.
Heeft de plugin toevallig een grote afbeelding nodig? Een out of memory error krijg je vaak wanneer een afbeelding omgezet moet worden(watermerk etc.)?
