Minecraft error: Java Runtime Environment
Minime98
12 jan 2013
Hallo allemaal,
Ik wil graag Minecraft spelen. Eerst heb ik het gedownload en daarna logde ik in. Toen kwam er 'Downloading packages'. Toen die bij 100% was, viel opeens Minecraft weg en kwam er op mijn bureaublad een snelkoppeling naar een LOG-bestand. Als ik die opende met kladblok kreeg ik deze error:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006767f5bf, pid=7476, tid=7632
# JRE version: 7.0_17-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.7-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [aticfx64.dll+0x2f5bf]  GetKtProcAddress+0xfaf
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   [url]http://bugreport.sun.com/bugreport/crash.jsp[/url]
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x00000000087f0000):  JavaThread "Minecraft main thread" daemon [_thread_in_native, id=7632, stack(0x000000000d680000,0x000000000d780000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000144
Registers:
RAX=0x00000000676d7200, RBX=0x000000000fad12f0, RCX=0x0000000000000000, RDX=0x000000000000000a
RSP=0x000000000d77dfa0, RBP=0x000000000d77eb10, RSI=0x000000000fad12f0, RDI=0x000000000fad53f0
R8 =0x0000000000000000, R9 =0x0000000000000000, R10=0x00000000000001af, R11=0x0000000000000001
R12=0x0000000000000028, R13=0x000000000d77ef40, R14=0x0000000000000001, R15=0x00000000ffffffff
RIP=0x000000006767f5bf, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x000000000d77dfa0)
0x000000000d77dfa0:   0000000000000003 000000000fad12f0
0x000000000d77dfb0:   000000000fad12f0 0000000000040bf0
0x000000000d77dfc0:   0000000000000000 000000006767d2ab
0x000000000d77dfd0:   00000000400000c0 000000000fad12f0
0x000000000d77dfe0:   0000000000000000 000000000d77eb10
0x000000000d77dff0:   000000000d77e020 0000000000000960
0x000000000d77e000:   000000000d77e008 00000000400000c0
0x000000000d77e010:   000000000d77e020 0000000000000960
0x000000000d77e020:   088d000000000001 000000000000000a
0x000000000d77e030:   0000000700000008 0000073b0000027c
0x000000000d77e040:   0000000100000001 0000000100008bc3
0x000000000d77e050:   000007fc00001f9d e2f3210700000001
0x000000000d77e060:   00f7ff3f000001ba 0a43f76d90eef8e8
0x000000000d77e070:   8406240000000000 000000000000000b
0x000000000d77e080:   4000000404000000 0000068300024081
0x000000000d77e090:   0000406053480901 1886000070000000
Instructions: (pc=0x000000006767f5bf)
0x000000006767f59f:   15 ac 8c 02 00 48 8b f8 48 85 c0 74 7d 48 8b 4e
0x000000006767f5af:   28 8b 56 18 48 8d 05 46 7c 05 00 48 89 5c 24 38
0x000000006767f5bf:   8b 99 44 01 00 00 48 89 77 10 48 89 07 89 57 08
0x000000006767f5cf:   48 8b 46 28 8b 88 50 01 00 00 33 f6 89 4f 6c 48
Register to memory mapping:
RAX=0x00000000676d7200 is an unknown value
RBX=0x000000000fad12f0 is an unknown value
RCX=0x0000000000000000 is an unknown value
RDX=0x000000000000000a is an unknown value
RSP=0x000000000d77dfa0 is pointing into the stack for thread: 0x00000000087f0000
RBP=0x000000000d77eb10 is pointing into the stack for thread: 0x00000000087f0000
RSI=0x000000000fad12f0 is an unknown value
RDI=0x000000000fad53f0 is an unknown value
R8 =0x0000000000000000 is an unknown value
R9 =0x0000000000000000 is an unknown value
R10=0x00000000000001af is an unknown value
R11=0x0000000000000001 is an unknown value
R12=0x0000000000000028 is an unknown value
R13=0x000000000d77ef40 is pointing into the stack for thread: 0x00000000087f0000
R14=0x0000000000000001 is an unknown value
R15=0x00000000ffffffff is an unallocated location in the heap
Stack: [0x000000000d680000,0x000000000d780000],  sp=0x000000000d77dfa0,  free space=1015k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(JIILorg/lwjgl/opengl/PixelFormat;Ljava/nio/IntBuffer;ZZZZ)I+0
j  org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(JIILorg/lwjgl/opengl/PixelFormat;Ljava/nio/IntBuffer;ZZZZ)I+15
j  org.lwjgl.opengl.WindowsDisplay.createWindow(Lorg/lwjgl/opengl/DisplayMode;Ljava/awt/Canvas;II)V+176
j  org.lwjgl.opengl.Display.createWindow()V+68
j  org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+63
j  org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+9
j  net.minecraft.client.Minecraft.a()V+177
j  avv.a()V+94
j  net.minecraft.client.Minecraft.run()V+6
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
=>0x00000000087f0000 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=7632, stack(0x000000000d680000,0x000000000d780000)]
  0x00000000087ed800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=588, stack(0x000000000d050000,0x000000000d150000)]
  0x00000000087ef800 JavaThread "Snooper Timer" daemon [_thread_blocked, id=6632, stack(0x000000000d7c0000,0x000000000d8c0000)]
  0x000000000aace000 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=5496, stack(0x000000000d270000,0x000000000d370000)]
  0x0000000001e8c000 JavaThread "DestroyJavaVM" [_thread_blocked, id=5580, stack(0x00000000021a0000,0x00000000022a0000)]
  0x000000000a96b800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=5784, stack(0x000000000c250000,0x000000000c350000)]
  0x000000000a882000 JavaThread "TimerQueue" daemon [_thread_blocked, id=3020, stack(0x000000000b740000,0x000000000b840000)]
  0x000000000a87d000 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=7616, stack(0x000000000bc30000,0x000000000bd30000)]
  0x000000000a730000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1456, stack(0x000000000b5c0000,0x000000000b6c0000)]
  0x000000000a72f000 JavaThread "AWT-Shutdown" [_thread_blocked, id=8072, stack(0x000000000b310000,0x000000000b410000)]
  0x000000000a7af800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=7076, stack(0x000000000b160000,0x000000000b260000)]
  0x00000000087fd000 JavaThread "Service Thread" daemon [_thread_blocked, id=8168, stack(0x0000000009bd0000,0x0000000009cd0000)]
  0x00000000087ed000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=7832, stack(0x000000000a1e0000,0x000000000a2e0000)]
  0x00000000087d9800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=7684, stack(0x0000000009ff0000,0x000000000a0f0000)]
  0x00000000087d8000 JavaThread "Attach Listener" daemon [_thread_blocked, id=2172, stack(0x0000000009ec0000,0x0000000009fc0000)]
  0x00000000087d1000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6408, stack(0x0000000009cd0000,0x0000000009dd0000)]
  0x0000000001e78000 JavaThread "Finalizer" daemon [_thread_blocked, id=5224, stack(0x0000000009a90000,0x0000000009b90000)]
  0x0000000001e71800 JavaThread "Reference Handler" daemon [_thread_blocked, id=7800, stack(0x0000000009990000,0x0000000009a90000)]
Other Threads:
  0x0000000008753000 VMThread [stack: 0x0000000009730000,0x0000000009830000] [id=7252]
  0x0000000008810000 WatcherThread [stack: 0x000000000a3a0000,0x000000000a4a0000] [id=6376]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 PSYoungGen      total 152896K, used 103979K [0x00000000eaab0000, 0x00000000f5550000, 0x0000000100000000)
  eden space 131072K, 79% used [0x00000000eaab0000,0x00000000f103ac68,0x00000000f2ab0000)
  from space 21824K, 0% used [0x00000000f4000000,0x00000000f4000000,0x00000000f5550000)
  to   space 21824K, 0% used [0x00000000f2ab0000,0x00000000f2ab0000,0x00000000f4000000)
 ParOldGen       total 349568K, used 0K [0x00000000c0000000, 0x00000000d5560000, 0x00000000eaab0000)
  object space 349568K, 0% used [0x00000000c0000000,0x00000000c0000000,0x00000000d5560000)
 PSPermGen       total 21248K, used 20540K [0x00000000bae00000, 0x00000000bc2c0000, 0x00000000c0000000)
  object space 21248K, 96% used [0x00000000bae00000,0x00000000bc20f368,0x00000000bc2c0000)
Card table byte_map: [0x00000000052a0000,0x00000000054d0000] byte_map_base: 0x0000000004cc9000
Polling page: 0x0000000000400000
Code Cache  [0x00000000022a0000, 0x0000000002510000, 0x00000000052a0000)
 total_blobs=914 nmethods=347 adapters=518 free_code_cache=47818Kb largest_free_block=48932288
Compilation events (10 events):
Event: 7.434 Thread 0x00000000087d9800  336             kf::b (98 bytes)
Event: 7.442 Thread 0x00000000087d9800 nmethod 336 0x00000000023e6b10 code [0x00000000023e6cc0, 0x00000000023e70a0]
Event: 7.451 Thread 0x00000000087ed000 nmethod 333 0x00000000023ee010 code [0x00000000023ee1e0, 0x00000000023ef008]
Event: 7.456 Thread 0x00000000087d9800  337             java.util.Formatter$Flags::valueOf (5 bytes)
Event: 7.456 Thread 0x00000000087d9800 nmethod 337 0x00000000023ec910 code [0x00000000023eca40, 0x00000000023eca98]
Event: 7.457 Thread 0x00000000087ed000  338             java.lang.Character::toLowerCase (9 bytes)
Event: 7.457 Thread 0x00000000087d9800  339             java.util.regex.Pattern$BmpCharProperty::match (50 bytes)
Event: 7.458 Thread 0x00000000087ed000 nmethod 338 0x00000000023e4a10 code [0x00000000023e4b60, 0x00000000023e4cd8]
Event: 7.459 Thread 0x00000000087d9800 nmethod 339 0x00000000023e4510 code [0x00000000023e4660, 0x00000000023e47f8]
Event: 7.568 Thread 0x00000000087ed000  340             sun.net.[url]www.ParseUtil::encodePath[/url] (336 bytes)
GC Heap History (0 events):
No events
Deoptimization events (10 events):
Event: 7.376 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x00000000023e69d8
Event: 7.378 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x000000000236f018
Event: 7.394 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x0000000002373698
Event: 7.396 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x00000000023e6698
Event: 7.398 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x00000000023e6358
Event: 7.400 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x00000000023e6018
Event: 7.403 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x00000000023e5cd8
Event: 7.417 Thread 0x00000000087ee800 Uncommon trap -83 fr.pc 0x000000000239ea6c
Event: 7.417 Thread 0x00000000087ee800 Uncommon trap -83 fr.pc 0x00000000023805ac
Event: 7.424 Thread 0x00000000087ee800 Uncommon trap -75 fr.pc 0x00000000023e5998
Internal exceptions (10 events):
Event: 7.568 Thread 0x00000000087f0000 Threw 0x00000000f0e3aea8 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.568 Thread 0x00000000087f0000 Threw 0x00000000f0e3b388 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.568 Thread 0x00000000087f0000 Threw 0x00000000f0e3ea48 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.568 Thread 0x00000000087f0000 Threw 0x00000000f0e3ef38 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.571 Thread 0x00000000087f0000 Threw 0x00000000f0e41f20 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.571 Thread 0x00000000087f0000 Threw 0x00000000f0e42380 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.572 Thread 0x00000000087f0000 Threw 0x00000000f0e45e40 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.572 Thread 0x00000000087f0000 Threw 0x00000000f0e462b0 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.573 Thread 0x00000000087f0000 Threw 0x00000000f0e48e50 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 7.573 Thread 0x00000000087f0000 Threw 0x00000000f0e49270 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Events (10 events):
Event: 7.568 loading class 0x000000000af7d640
Event: 7.568 loading class 0x000000000af7d640 done
Event: 7.568 loading class 0x000000000a50c530
Event: 7.568 loading class 0x000000000a50c530 done
Event: 7.571 loading class 0x000000000af7d740
Event: 7.571 loading class 0x000000000af7d740 done
Event: 7.572 loading class 0x000000000af7d580
Event: 7.572 loading class 0x000000000af7d580 done
Event: 7.573 loading class 0x000000000b0244d0
Event: 7.573 loading class 0x000000000b0244d0 done
Dynamic libraries:
0x000000013f980000 - 0x000000013f9b3000 	C:\Program Files\Java\jre7\bin\javaw.exe
0x00000000773a0000 - 0x0000000077549000 	C:\Windows\SYSTEM32\ntdll.dll
0x0000000077280000 - 0x000000007739f000 	C:\Windows\system32\kernel32.dll
0x000007fefd270000 - 0x000007fefd2db000 	C:\Windows\system32\KERNELBASE.dll
0x000007fefd740000 - 0x000007fefd81b000 	C:\Windows\system32\ADVAPI32.dll
0x000007fefd820000 - 0x000007fefd8bf000 	C:\Windows\system32\msvcrt.dll
0x000007fefd720000 - 0x000007fefd73f000 	C:\Windows\SYSTEM32\sechost.dll
0x000007fefdad0000 - 0x000007fefdbfd000 	C:\Windows\system32\RPCRT4.dll
0x0000000077180000 - 0x000000007727a000 	C:\Windows\system32\USER32.dll
0x000007fefd5e0000 - 0x000007fefd647000 	C:\Windows\system32\GDI32.dll
0x000007feff0e0000 - 0x000007feff0ee000 	C:\Windows\system32\LPK.dll
0x000007feff0f0000 - 0x000007feff1b9000 	C:\Windows\system32\USP10.dll
0x000007fefb620000 - 0x000007fefb814000 	C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll
0x000007fefec90000 - 0x000007fefed01000 	C:\Windows\system32\SHLWAPI.dll
0x000007feff0b0000 - 0x000007feff0de000 	C:\Windows\system32\IMM32.DLL
0x000007fefefa0000 - 0x000007feff0a9000 	C:\Windows\system32\MSCTF.dll
0x0000000069f10000 - 0x0000000069fe1000 	C:\Program Files\Java\jre7\bin\msvcr100.dll
0x00000000697f0000 - 0x0000000069f0f000 	C:\Program Files\Java\jre7\bin\server\jvm.dll
0x000007fefa660000 - 0x000007fefa669000 	C:\Windows\system32\WSOCK32.dll
0x000007fefd650000 - 0x000007fefd69d000 	C:\Windows\system32\WS2_32.dll
0x000007fefd5b0000 - 0x000007fefd5b8000 	C:\Windows\system32\NSI.dll
0x000007fefaaa0000 - 0x000007fefaadb000 	C:\Windows\system32\WINMM.dll
0x0000000077560000 - 0x0000000077567000 	C:\Windows\system32\PSAPI.DLL
0x00000000697e0000 - 0x00000000697ef000 	C:\Program Files\Java\jre7\bin\verify.dll
0x00000000697b0000 - 0x00000000697d8000 	C:\Program Files\Java\jre7\bin\java.dll
0x0000000069790000 - 0x00000000697a5000 	C:\Program Files\Java\jre7\bin\zip.dll
0x00000000673b0000 - 0x0000000067543000 	C:\Program Files\Java\jre7\bin\awt.dll
0x000007feff5d0000 - 0x000007feff6a7000 	C:\Windows\system32\OLEAUT32.dll
0x000007fefd8c0000 - 0x000007fefdac3000 	C:\Windows\system32\ole32.dll
0x000007fefb570000 - 0x000007fefb5c6000 	C:\Windows\system32\uxtheme.dll
0x000007fefb190000 - 0x000007fefb1a8000 	C:\Windows\system32\dwmapi.dll
0x000007fefd0b0000 - 0x000007fefd0bf000 	C:\Windows\system32\CRYPTBASE.dll
0x000007fefdca0000 - 0x000007fefea28000 	C:\Windows\system32\SHELL32.dll
0x0000000069750000 - 0x0000000069784000 	C:\Program Files\Java\jre7\bin\fontmanager.dll
0x0000000068c20000 - 0x0000000068c39000 	C:\Program Files\Java\jre7\bin\net.dll
0x000007fefc9f0000 - 0x000007fefca45000 	C:\Windows\system32\mswsock.dll
0x000007fefc9e0000 - 0x000007fefc9e7000 	C:\Windows\System32\wship6.dll
0x0000000068c00000 - 0x0000000068c11000 	C:\Program Files\Java\jre7\bin\nio.dll
0x000007fefbbb0000 - 0x000007fefbbc5000 	C:\Windows\system32\NLAapi.dll
0x000007fef9fc0000 - 0x000007fef9fd5000 	C:\Windows\system32\napinsp.dll
0x000007fef4420000 - 0x000007fef4439000 	C:\Windows\system32\pnrpnsp.dll
0x000007fef93a0000 - 0x000007fef93ce000 	C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x000007fefc870000 - 0x000007fefc8cb000 	C:\Windows\system32\DNSAPI.dll
0x000007fef4410000 - 0x000007fef441b000 	C:\Windows\System32\winrnr.dll
0x000007fefa910000 - 0x000007fefa937000 	C:\Windows\system32\IPHLPAPI.DLL
0x000007fefa900000 - 0x000007fefa90b000 	C:\Windows\system32\WINNSI.DLL
0x000007fefa400000 - 0x000007fefa453000 	C:\Windows\System32\fwpuclnt.dll
0x000007fef9390000 - 0x000007fef9398000 	C:\Windows\system32\rasadhlp.dll
0x000007fefc360000 - 0x000007fefc367000 	C:\Windows\System32\wshtcpip.dll
0x000007fefca50000 - 0x000007fefca67000 	C:\Windows\system32\CRYPTSP.dll
0x000007fefc750000 - 0x000007fefc797000 	C:\Windows\system32\rsaenh.dll
0x000007fefc480000 - 0x000007fefc49e000 	C:\Windows\system32\USERENV.dll
0x000007fefd180000 - 0x000007fefd18f000 	C:\Windows\system32\profapi.dll
0x0000000068bd0000 - 0x0000000068bf4000 	C:\Program Files\Java\jre7\bin\sunec.dll
0x0000000068b80000 - 0x0000000068bc1000 	C:\Program Files\Java\jre7\bin\t2k.dll
0x000007fefdc00000 - 0x000007fefdc99000 	C:\Windows\system32\CLBCatQ.DLL
0x000007fefafe0000 - 0x000007fefb141000 	C:\Windows\system32\WindowsCodecs.dll
0x000007fefd050000 - 0x000007fefd0a7000 	C:\Windows\system32\apphelp.dll
0x000007fef9020000 - 0x000007fef9055000 	C:\Windows\system32\EhStorShell.dll
0x000007feff1c0000 - 0x000007feff397000 	C:\Windows\system32\SETUPAPI.dll
0x000007fefd3b0000 - 0x000007fefd3e6000 	C:\Windows\system32\CFGMGR32.dll
0x000007fefd400000 - 0x000007fefd41a000 	C:\Windows\system32\DEVOBJ.dll
0x000007fefbe90000 - 0x000007fefbfbc000 	C:\Windows\system32\PROPSYS.dll
0x000007fef8cc0000 - 0x000007fef8d40000 	C:\Windows\system32\ntshrui.dll
0x000007fefccd0000 - 0x000007fefccf3000 	C:\Windows\system32\srvcli.dll
0x000007fef8c90000 - 0x000007fef8c9f000 	C:\Windows\system32\cscapi.dll
0x000007fefbb10000 - 0x000007fefbb1b000 	C:\Windows\system32\slc.dll
0x0000000069740000 - 0x000000006974b000 	C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x000007fefd440000 - 0x000007fefd5aa000 	C:\Windows\system32\CRYPT32.dll
0x000007fefd220000 - 0x000007fefd22f000 	C:\Windows\system32\MSASN1.dll
0x0000000180000000 - 0x0000000180048000 	C:\Users\Thijmen\AppData\Roaming\.minecraft\bin\natives\lwjgl64.dll
0x000007fef45b0000 - 0x000007fef46cd000 	C:\Windows\system32\OPENGL32.dll
0x000007fef4580000 - 0x000007fef45ad000 	C:\Windows\system32\GLU32.dll
0x000007fef4480000 - 0x000007fef4571000 	C:\Windows\system32\DDRAW.dll
0x000007fef4220000 - 0x000007fef4228000 	C:\Windows\system32\DCIMAN32.dll
0x000007fefc290000 - 0x000007fefc29c000 	C:\Windows\system32\VERSION.dll
0x0000000068b70000 - 0x0000000068b77000 	C:\Program Files\Java\jre7\bin\jawt.dll
0x000000000ead0000 - 0x000000000f948000 	C:\Windows\system32\ig4icd64.dll
0x000007feedc30000 - 0x000007feedc3a000 	C:\Windows\system32\atig6txx.dll
0x0000000067650000 - 0x00000000676ef000 	C:\Windows\system32\aticfx64.dll
0x000007feef290000 - 0x000007feef3b5000 	C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\Thijmen\Desktop\Minecraft.exe
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\PROGRAM FILES\COMMON FILES\MICROSOFT SHARED\WINDOWS LIVE;C:\PROGRAM FILES (X86)\COMMON FILES\MICROSOFT SHARED\WINDOWS LIVE;C:\Windows\SYSTEM32;C:\Windows;C:\Windows\SYSTEM32\WBEM;C:\Windows\SYSTEM32\WINDOWSPOWERSHELL\V1.0\;C:\PROGRAM FILES (X86)\WINDOWS LIVE\SHARED;C:\Program Files (x86)\Panda Security\Panda Global Protection 2012;C:\Program Files\Java\jre7\bin
USERNAME=Thijmen
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 5, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 37 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht, tsc, tscinvbit
Memory: 4k page, physical 3984048k(1767700k free), swap 7966236k(4576088k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (23.7-b01) for windows-amd64 JRE (1.7.0_17-b02), built on Mar  1 2013 03:38:30 by "java_re" with unknown MS VC++:1600
time: Mon May 20 17:24:17 2013
elapsed time: 7 seconds
Ik hoop dat iemand weet wat dit betekent en dat die mij kan helpen om dit probleem op te lossen.
Alvast bedankt,
Minime98
hee, is het dus met de launcher gelukt?
heb je java geprobeerd opnieuw te installeren?
#fix1
Als je wilt kan je gehele mc verwijderen (qua bestanden).
1. Druk op je windows knop + r ,je ziet dat er iets opend.
2. Type daarin %appdata% ,er opend een map
3. Je ziet (als het goed is) helemaal bovenin een map .minecraft staan, verwijder die. *als hij niet verwijderd, moet je eerst je minecraft afsluiten
4. Open je minecraft, login en hij download weer en dan (als het goed is) doet hij het gewoon
Vertel maar of het werkt of niet
Na wat zoeken ben ik erachter dat je je jvm moet upgrade, met andere woorden: update java naar de nieuwste versie (maar wel java 6!)
De kans dat fix 1 van je werkt schat ik op 0,01%
Hij faalt juist op het downloaden...
Ik stuur mijn .minecraft wel op, over een uur of 2 (niet op computer)
Dan is het eigenlijk al gedownload dus dan slaat hij dat over en moet het gewoon werken.
Heb je cracked?
wat is cracked?
ik heb hem gedownload van de Minecraft site
maar volgens mij maakt hij het mapje als Minecraft downloading packages doet
dus...
ik weet niet wat het beste is mij maakt het niet uit.
wat is fix 1?
hoe gaat je het mapje sturen als je het niet via de computer doet?
Dat is fix1,
minecraft maakt een map aan waar hij alle save-files, texturepacks en bestanden die hij nodig heeft opslaat. Soms doet hij iets verkeerd bij die installatie, vandaar fix1, maar probeer eerst maar fix2.
En cracked is anjocaido, dan hoef je niet te betalen, maar dan kan je ook niet op officele servers, en heb je ook geen skin.
Dan stuur ik het niet hè :P
Daarom, ik ben op een iPad waardoor ik het niet dan versturen.
Ben zo op een computer
Is de map .minecraft aangemaakt?
stuur dan het bestand log.lgk ofzo
niet helemaal, probeer eerst java te verwijderen en dan opnieuw te instaleren via java.com
Dat heb ik al heel vaak geprobeerd maar helaas heeft dat niet geholpen
Ga naar %appdata% en verwijder het mapje .minecraft
Start minecraft opnieuw.
Hopen dat het lukt
@ryantje
Breek niet in andermans topic in en maak zelf een topic aan.
@mcfreak
Gebruik de knop "Meld misbruik".
