ciske de rat
Verenigingslid
- 10 jun 2003
map images
je moet nog mapje aan maken met images daar zet je een map je met profile neer
</div>
<?php include 'includes/footer.php'; ?>
</body>
</html>
<!doctype html>
<html>
<?php include'includes/head.php';?>
<body>
<?php include 'includes/header.php'; ?>
<div id="container">
<?php include 'includes/aside.php'; ?>
<div class="widget">
<h2>Hallo, <?php echo $user_data['first_name']; ?>!</h2>
<div class="inner">
<div class="profile">
<?php
if (isset($_FILES['profile']) === true) {
if (empty($_FILES['profile']['name']) === true) {
echo 'Selecteer een bestand!!';
} else {
$allowed = array('jpg', 'jpeg', 'gif', 'png');
$file_name = $_FILES['profile']['name'];
$file_extn = strtolower(end(explode('.', $file_name)));
$file_temp = $_FILES['profile']['tmp_name'];
if (in_array($file_extn, $allowed) === true) {
change_profile_image($session_user_id, $file_temp, $file_extn);
exit();
} else {
echo 'Onjuist bestandstype.: ';
echo implode(', ', $allowed);
if (empty($user_data['profile']) === false) {
echo '<img src="', $user_data['profile'], '" alt="', $user_data['first_name'], '\'s Profile Image">';
<form action="" method="post" enctype="multipart/form-data">
<input type="file" name="profile"> <input type="submit">
</form>
</div>
<ul>
<li>
<a href="logout.php">Uit loggen</a>
</li>
<li>
<a href="<?php echo $user_data['username']; ?>">Profiel</a>
</li>
<li>
<a href="changepassword.php">Verander u wachtwoord</a>
</li>
<li>
<a href="settings.php">Settings</a>
</li>
</ul>
</div>
</div>
<h2>Inloggen / Registreren.</h2>
<div class="inner">
<form action="login.php" method="post">
<ul id="login">
<li>
Gebruikersnaam:<br>
<input type="text" name="username">
</li>
<li>
Wachtwoord:<br>
<input type="password" name="password">
</li>
<li>
<input type="submit" value="Log in">
</li>
<li>
<a href="register.php">Register</a>
</li>
<li>
U<a href="recover.php?mode=username"> Gebruikersnaam.</a> of u <a href="recover.php?mode=password">Wachtwoord.</a> vergeten?
</li>
</ul>
</form>
</div>
</div>
<h2>Gebruikers</h2>
<div class="inner">
<?php
$user_count = user_count();
$suffix = ($user_count != 1) ? 's' : '';
Momenteel hebben wij <?php echo $user_count; ?> geregistreerde gebruikers<?php echo $suffix; ?>.
</div>
</div>
<aside>
<?php
if (logged_in() === true) {
include 'includes/widgets/loggedin.php';
} else {
include 'includes/widgets/login.php';
include 'includes/widgets/user_count.php';
</aside>
<footer>
© moffia.nl 2013. © Alle rechten voorbehouden..
</footer>
<head>
<title>JE WEBSITE URL OF JE NAAM </title>
<meta charset="UTF-8">
<link rel="stylesheet" href="css/screen.css">
<!--[if lt IE 9]>
<script src="js/html5shiv.js"></script>
<![endif]-->
</head>
<header>
<h1 class="logo">Logo</h1>
<?php include 'includes/menu.php'; ?>
<div class="clear"></div>
</header>
<nav>
<ul>
<li><a href="index.php">Home</a></li>
<li><a href="downloads.php">Downloads</a></li>
<li><a href="forum.php">Forum</a></li>
<li><a href="contact.php">Contact us</a></li>
</ul>
</nav>
/*! HTML5 Shiv v3.6 | @afarkas @jdalton @jon_neal @rem | MIT/GPL2 Licensed */
;(function(window, document) {
/*jshint evil:true */
/** Preset options */
var options = window.html5 || {};
/** Used to skip problem elements */
var reSkip = /^<|^(?:button|map|select|textarea|object|iframe|option|optgroup)$/i;
/** Not all elements can be cloned in IE (this list can be shortend) **/
var saveClones = /^<|^(?:a|b|button|code|div|fieldset|form|h1|h2|h3|h4|h5|h6|i|iframe|img|input|label|li|link|ol|option|p|param|q|script|select|span|strong|style|table|tbody|td|textarea|tfoot|th|thead|tr|ul)$/i;
/** Detect whether the browser supports default html5 styles */
var supportsHtml5Styles;
/** Name of the expando, to work with multiple documents or to re-shiv one document */
var expando = '_html5shiv';
/** The id for the the documents expando */
var expanID = 0;
/** Cached data for each document */
var expandoData = {};
/** Detect whether the browser supports unknown elements */
var supportsUnknownElements;
(function() {
try {
var a = document.createElement('a');
a.innerHTML = '<xyz></xyz>';
//if the hidden property is implemented we can assume, that the browser supports basic HTML5 Styles
supportsHtml5Styles = ('hidden' in a);
supportsUnknownElements = a.childNodes.length == 1 || (function() {
// assign a false positive if unable to shiv
(document.createElement)('a');
var frag = document.createDocumentFragment();
return (
typeof frag.cloneNode == 'undefined' ||
typeof frag.createDocumentFragment == 'undefined' ||
typeof frag.createElement == 'undefined'
} catch(e) {
supportsHtml5Styles = true;
supportsUnknownElements = true;
* Creates a style sheet with the given CSS text and adds it to the document.
* @private
* @param {Document} ownerDocument The document.
* @param {String} cssText The CSS text.
* @returns {StyleSheet} The style element.
function addStyleSheet(ownerDocument, cssText) {
var p = ownerDocument.createElement('p'),
parent = ownerDocument.getElementsByTagName('head')[0] || ownerDocument.documentElement;
p.innerHTML = 'x<style>' + cssText + '</style>';
return parent.insertBefore(p.lastChild, parent.firstChild);
* Returns the value of `html5.elements` as an array.
* @private
* @returns {Array} An array of shived element node names.
function getElements() {
var elements = html5.elements;
return typeof elements == 'string' ? elements.split(' ') : elements;
* Returns the data associated to the given document
* @private
* @returns {Object} An object of data.
function getExpandoData(ownerDocument) {
var data = expandoData[ownerDocument[expando]];
if (!data) {
data = {};
expanID++;
ownerDocument[expando] = expanID;
expandoData[expanID] = data;
return data;
* returns a shived element for the given nodeName and document
* @memberOf html5
* @param {String} nodeName name of the element
* @param {Document} ownerDocument The context document.
* @returns {Object} The shived element.
function createElement(nodeName, ownerDocument, data){
if (!ownerDocument) {
ownerDocument = document;
if(supportsUnknownElements){
return ownerDocument.createElement(nodeName);
if (!data) {
data = getExpandoData(ownerDocument);
var node;
if (data.cache[nodeName]) {
node = data.cache[nodeName].cloneNode();
} else if (saveClones.test(nodeName)) {
node = (data.cache[nodeName] = data.createElem(nodeName)).cloneNode();
} else {
node = data.createElem(nodeName);
// Avoid adding some elements to fragments in IE < 9 because
// * Attributes like `name` or `type` cannot be set/changed once an element
// is inserted into a document/fragment
// * Link elements with `src` attributes that are inaccessible, as with
// a 403 response, will cause the tab/window to crash
// * Script elements appended to fragments will execute when their `src`
// or `text` property is set
return node.canHaveChildren && !reSkip.test(nodeName) ? data.frag.appendChild(node) : node;
* returns a shived DocumentFragment for the given document
* @memberOf html5
* @returns {Object} The shived DocumentFragment.
function createDocumentFragment(ownerDocument, data){
return ownerDocument.createDocumentFragment();
data = data || getExpandoData(ownerDocument);
var clone = data.frag.cloneNode(),
i = 0,
elems = getElements(),
l = elems.length;
for(;i<l;i++){
clone.createElement(elems[i]);
return clone;
* Shivs the `createElement` and `createDocumentFragment` methods of the document.
* @private
* @param {Document|DocumentFragment} ownerDocument The document.
* @param {Object} data of the document.
function shivMethods(ownerDocument, data) {
if (!data.cache) {
data.cache = {};
data.createElem = ownerDocument.createElement;
data.createFrag = ownerDocument.createDocumentFragment;
data.frag = data.createFrag();
ownerDocument.createElement = function(nodeName) {
//abort shiv
if (!html5.shivMethods) {
return data.createElem(nodeName);
return createElement(nodeName, ownerDocument, data);
ownerDocument.createDocumentFragment = Function('h,f', 'return function(){' +
'var n=f.cloneNode(),c=n.createElement;' +
'h.shivMethods&&(' +
// unroll the `createElement` calls
getElements().join().replace(/\w+/g, function(nodeName) {
data.frag.createElement(nodeName);
return 'c("' + nodeName + '")';
');return n}'
)(html5, data.frag);
* Shivs the given document.
* @memberOf html5
* @param {Document} ownerDocument The document to shiv.
* @returns {Document} The shived document.
function shivDocument(ownerDocument) {
var data = getExpandoData(ownerDocument);
if (html5.shivCSS && !supportsHtml5Styles && !data.hasCSS) {
data.hasCSS = !!addStyleSheet(ownerDocument,
// corrects block display not defined in IE6/7/8/9
'article,aside,figcaption,figure,footer,header,hgroup,nav,section{display:block}' +
// adds styling not present in IE6/7/8/9
'mark{background:#FF0;color:#000}'
if (!supportsUnknownElements) {
shivMethods(ownerDocument, data);
return ownerDocument;
* The `html5` object is exposed so that more elements can be shived and
* existing shiving can be detected on iframes.
* @type Object
* @example
* // options can be changed before the script is included
* html5 = { 'elements': 'mark section', 'shivCSS': false, 'shivMethods': false };
var html5 = {
* An array or space separated string of node names of the elements to shiv.
* @memberOf html5
* @type Array|String
'elements': options.elements || 'abbr article aside audio bdi canvas data datalist details figcaption figure footer header hgroup mark meter nav output progress section summary time video',
* A flag to indicate that the HTML5 style sheet should be inserted.
* @memberOf html5
* @type Boolean
'shivCSS': (options.shivCSS !== false),
* Is equal to true if a browser supports creating unknown/HTML5 elements
* @memberOf html5
* @type boolean
'supportsUnknownElements': supportsUnknownElements,
* A flag to indicate that the document's `createElement` and `createDocumentFragment`
* methods should be overwritten.
* @memberOf html5
* @type Boolean
'shivMethods': (options.shivMethods !== false),
* A string to describe the type of `html5` object ("default" or "default print").
* @memberOf html5
* @type String
'type': 'default',
// shivs the document according to the specified `html5` object options
'shivDocument': shivDocument,
//creates a shived element
createElement: createElement,
//creates a shived documentFragment
createDocumentFragment: createDocumentFragment
// expose html5
window.html5 = html5;
// shiv the document
shivDocument(document);
}(this, document));
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ /profile.php?username=$1
<?php
ob_start();
include 'core/init.php';
logged_in_redirect();
include 'includes/overall/header.php';
if (isset($_GET['success']) === true && empty($_GET['success']) === true) {
<h2>Bedankt, we hebben uw account geactiveerd ...</h2>
<p>Je bent vrij om in te loggen!</p>
<?php
} else if (isset($_GET['email'], $_GET['email_code']) === true) {
$email = trim($_GET['email']);
$email_code = trim($_GET['email_code']);
if (email_exists($email) === false) {
$errors[] = 'Oeps, ging er iets mis, en we konden dat email adres niet vinden!';
} else if (activate($email, $email_code) === false) {
$errors[] = 'We hebben problemen met het activeren van je account';
if (empty($errors) === false) {
<h2>Foutje...</h2>
<?php
echo output_errors($errors);
} else {
header('Location: activate.php?success');
exit();
} else {
header('Location: index.php');
exit();
include 'includes/overall/footer.php';
ob_end_flush();
<?php
protect_page();
admin_protect();
<h1>Admin</h1>
<p>Admin page</p>
<?php
include 'includes/widgets/infouser.php';
<?php include 'includes/overall/footer.php'; ?>
<?php
ob_start();
protect_page();
if (empty($_POST) === false) {
$required_fields = array('current_password', 'password', 'password_again');
foreach($_POST as $key=>$value) {
if (empty($value) && in_array($key, $required_fields) === true) {
$errors[] = 'Velden gemarkeerd met een sterretje zijn verplicht';
break 1;
if (md5($_POST['current_password']) === $user_data['password']) {
if (trim($_POST['password']) !== trim($_POST['password_again'])) {
$errors[] = 'Uw nieuwe wachtwoorden komen niet overeen';
} else if (strlen($_POST['password']) < 6) {
$errors[] = 'Uw wachtwoord moet minstens 6 karakters';
} else {
$errors[] = 'Uw huidige wachtwoord is onjuist';
<h1>Change Password</h1>
<?php
echo 'Uw wachtwoord is gewijzigd.';
} else {
if (isset($_GET['force']) === true && empty($_GET['force']) === true) {
<p>U moet uw wachtwoord nu dat u hebt gevraagd te veranderen.</p>
<?php
if (empty($_POST) === false && empty($errors) === true) {
change_password($session_user_id, $_POST['password']);
header('Location: changepassword.php?success');
} else if (empty($errors) === false) {
<form action="" method="post">
<ul>
<li>
Huidige wachtwoord *:<br>
<input type="password" name="current_password">
</li>
<li>
Nieuwe Wachtwoord*:<br>
</li>
<li>
Nieuwe wachtwoord nog een keer *:<br>
<input type="password" name="password_again">
</li>
<li>
<input type="submit" value="Verander u wachtwoord">
</li>
</ul>
</form>
<?php
ob_end_flush();
<?php
<h1>Contact</h1>
<p>Contact details</p>
<?php
ini_set('display_errors', 'On');
error_reporting(E_ALL);
protect_page();
include 'core/database/connect.php';
<<?php
<?php
<?php
protect_page();
<h1> welkom</h1>
<?php
<h1>Home</h1>
<p>Just a template.</p>
<?php
$username = $_POST['username'];
$password = $_POST['password'];
if (empty($username) === true || empty($password) === true) {
$errors[] = 'U moet een gebruikersnaam en wachtwoord in te voeren';
} else if (user_exists($username) === false) {
$errors[] = 'We kunnen die gebruikersnaam niet vinden. Ben je geregistreerd?';
} else if (user_active($username) === false) {
$errors[] = 'Je hebt je account niet geactiveerd!';
} else {
if (strlen($password) > 32) {
$errors[] = 'U wachtwoord is te lang.';
$login = login($username, $password);
if ($login === false) {
$errors[] = 'U gebruikersnaam / wachtwoord combinatie is onjuist';
} else {
$_SESSION['user_id'] = $login;
exit();
} else {
$errors[] = 'No data received';
<h2>We hebben geprobeerd om u in te loggen, maar ...</h2>
<?php
<?php
session_start();
session_destroy();
<?php
protect_page();
admin_protect();
<h1>Email all users</h1>
<?php
<p>Email is verzonden</p>
<?php
} else {
if (empty($_POST['subject']) === true) {
$errors[] = 'Onderwerp is vereist';
if (empty($_POST['body']) === true) {
$errors[] = 'Body is vereist';
} else {
mail_users($_POST['subject'], $_POST['body']);
exit();
<ul>
<li>
Onderwerp*:<br>
<input type="text" name="subject">
</li>
<li>
Opmerking*:<br>
<textarea name="body"></textarea>
</li>
<li>
<input type="submit" value="Verzenden">
</li>
</ul>
</form>
<?php
<?php
if (isset($_GET['username']) === true && empty($_GET['username']) === false) {
$username = $_GET['username'];
if (user_exists($username) === true) {
$user_id = user_id_from_username($username);
$profile_data = user_data($user_id, 'first_name', 'last_name', 'email');
<h1><?php echo $profile_data['first_name']; ?>'s Profile</h1>
<p><?php echo $profile_data['email']; ?></p>
<?php
} else {
echo 'Sorry, betekent dat de gebruiker niet bestaat!';
} else {
exit();
<?php
<h1>Sorry, je moet ingelogd zijn om dat te doen!</h1>
<p>Registreer of log in</p>
<?php
ob_start();
<h1>Recover</h1>
<?php
<p>Thanks, we've emailed you.</p>
<?php
} else {
$mode_allowed = array('username', 'password');
if (isset($_GET['mode']) === true && in_array($_GET['mode'], $mode_allowed) === true) {
if (isset($_POST['email']) === true && empty($_POST['email']) === false) {
if (email_exists($_POST['email']) === true) {
recover($_GET['mode'], $_POST['email']);
header('Location: recover.php?success');
exit();
} else {
echo '<p>Oeps, we konden niet vinden dat e-mailadres!</p>';
<ul>
<li>
Vul uw e-mailadres:<br>
<input type="text" name="email">
</li>
<li><input type="submit" value="Versturen"></li>
</ul>
</form>
<?php
} else {
exit();
ob_end_flush(); ?>
<?php
ob_start();
$required_fields = array('username', 'password', 'password_again', 'first_name', 'email');
break 1;
if (empty($errors) === true) {
if (user_exists($_POST['username']) === true) {
$errors[] = 'Sorry, de Gebruikersnaam \'' . $_POST['username'] . '\' is al in gebruik';
if (preg_match("/\\s/", $_POST['username']) == true) {
$errors[] = 'Uw gebruikersnaam mag geen spaties bevatten.';
if ($_POST['password'] !== $_POST['password_again']) {
$errors[] = 'Uw wachtwoorden komen niet overeen';
if (filter_var($_POST['email'], FILTER_VALIDATE_EMAIL) === false) {
$errors[] = 'Een geldig e-mailadres nodig';
$errors[] = 'Sorry, het emailaderss \'' . $_POST['email'] . '\' is al in gebruik';
<h1>registreren</h1>
<?php
echo 'U bent succesvol geregistreerd! Controleer uw e-mail om uw account te activeren.';
} else {
$register_data = array(
'username' => $_POST['username'],
'password' => $_POST['password'],
'first_name' => $_POST['first_name'],
'last_name' => $_POST['last_name'],
'email' => $_POST['email'],
'email_code' => md5($_POST['username'] + microtime())
register_user($register_data);
header('Location: register.php?success');
exit();
<ul>
<li>
Gebruikersnaam*:<br>
</li>
<li>
wachtwoord*:<br>
</li>
<li>
wachtwoordt opnieuw*:<br>
</li>
<li>
Voornaam*:<br>
<input type="text" name="first_name">
</li>
<li>
Achternaam:<br>
<input type="text" name="last_name">
</li>
<li>
Email*:<br>
</li>
<li>
<input type="submit" value="registreren">
</li>
</ul>
</form>
<?php
ob_end_flush();
<?php
ob_start();
protect_page();
$required_fields = array('first_name', 'email');
break 1;
$errors[] = 'A valid email address is required';
} else if (email_exists($_POST['email']) === true && $user_data['email'] !== $_POST['email']) {
$errors[] = 'Sorry, het email \'' . $_POST['email'] . '\' is al in gebruik';
<h1>Settings</h1>
<?php
echo 'Uw gegevens zijn bijgewerkt!';
} else {
$update_data = array(
'allow_email' => ($_POST['allow_email'] == 'on') ? 1 : 0
update_user($session_user_id, $update_data);
header('Location: settings.php?success');
exit();
<ul>
<li>
Voornaam*:<br>
<input type="text" name="first_name" value="<?php echo $user_data['first_name']; ?>">
</li>
<li>
Achternaam:<br>
<input type="text" name="last_name" value="<?php echo $user_data['last_name']; ?>">
</li>
<li>
Email*:<br>
<input type="text" name="email" value="<?php echo $user_data['email']; ?>">
</li>
<li>
<input type="checkbox" name="allow_email" <?php if ($user_data['allow_email'] == 1) { echo 'checked="checked"'; } ?>> Would you like to receive email from us?
</li>
<li>
<input type="submit" value="Update">
</li>
</ul>
</form>
<?php
ob_end_flush();
Lees bovenstaande nog eens door en kijk naar je script!
@Ciske en David: Er word gevraagd om hulp bij het maken van het inlog/registratie form. Wat er daarna gebouwd word is voor later.
in de map core
PHP:<?php session_start(); //error_reporting(0); require 'database/connect.php'; require 'functions/general.php'; require 'functions/users.php'; $current_file = explode('/', $_SERVER['SCRIPT_NAME']); $current_file = end($current_file); if (logged_in() === true) { $session_user_id = $_SESSION['user_id']; $user_data = user_data($session_user_id, 'user_id', 'username', 'password', 'first_name', 'last_name', 'email', 'password_recover', 'type', 'allow_email', 'profile'); if (user_active($user_data['username']) === false) { session_destroy(); header('Location: index.php'); exit(); } if ($current_file !== 'changepassword.php' && $user_data['password_recover'] == 1) { header('Location: changepassword.php?force'); exit(); } } $errors = array(); ?>
sla deze op in de map core als init.php
de map includes
PHP:<aside> <?php if (logged_in() === true) { include 'includes/widgets/loggedin.php'; } else { include 'includes/widgets/login.php'; } include 'includes/widgets/user_count.php'; ?> </aside>
opslaan in map core/ opslaan als
opslaan in map core/ opslaan als aside.php
PHP:<footer> © moffia.nl 2013. © Alle rechten voorbehouden.. </footer>
opslaan in map core/ opslaan als footer.php
PHP:<head> <title>JE WEBSITE URL OF JE NAAM </title> <meta charset="UTF-8"> <link rel="stylesheet" href="css/screen.css"> <!--[if lt IE 9]> <script src="js/html5shiv.js"></script> <![endif]--> </head>
opslaan in map core/ opslaan als head.php
PHP:<header> <h1 class="logo">Logo</h1> <?php include 'includes/menu.php'; ?> <div class="clear"></div> </header>
opslaan in map core/ opslaan als header.php
PHP:<nav> <ul> <li><a href="index.php">Home</a></li> <li><a href="downloads.php">Downloads</a></li> <li><a href="forum.php">Forum</a></li> <li><a href="contact.php">Contact us</a></li> </ul> </nav>
opslaan in map core/ opslaan als menu.php
