Draadloze en 5ghz2.4ghz wifi valt steeds uit na reboot weer tijdje oke en dan weer...
Kobusstevens
6 jan 2014
Hallo ik heb een sitecom wl309 gaming router II die steeds uitvalt op steeds verschillende momenten hij valt meestal uit bij zwaar gebruik van het draadloze netwerk in mijn huis ik heb hier de log maar kan hier zelf niet zo veel mee: Message
[INFO]	Sat Jan 31 10:38:57 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:38:57 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:38:46 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:38:46 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 213.249.226.175:3074 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 86.131.60.222:3074 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 5.81.230.102:3074 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 81.131.201.84:3074 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 86.162.136.71:20708 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 80.7.235.245:3074 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:38:42 2004	Blocked incoming UDP packet from 86.152.205.8:3074 to 213.93.107.82:3074
[INFO]	Sat Jan 31 10:38:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:38:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:38:24 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:38:24 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:38:13 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:38:13 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:38:02 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:38:02 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:37:59 2004	Allowed configuration authentication by IP address 192.168.0.193
[INFO]	Sat Jan 31 10:37:38 2004	Administrator logout
[INFO]	Sat Jan 31 10:37:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:37:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:37:24 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:37:24 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:37:13 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:37:13 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:37:02 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:37:02 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:36:51 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:36:51 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:36:40 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:36:40 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:36:30 2004	Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.197 to 17.154.239.223
[INFO]	Sat Jan 31 10:36:30 2004	Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.197 to 17.173.255.222
[INFO]	Sat Jan 31 10:36:30 2004	Above message repeated 1 times
[WARN]	Sat Jan 31 10:36:30 2004	Blocked incoming UDP packet from 17.173.255.223:16387 to 213.93.107.82:16403
[WARN]	Sat Jan 31 10:36:29 2004	Above message repeated 13 times
[INFO]	Sat Jan 31 10:36:29 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:36:29 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[WARN]	Sat Jan 31 10:36:29 2004	Blocked incoming UDP packet from 17.173.255.223:16387 to 213.93.107.82:16403
[WARN]	Sat Jan 31 10:36:25 2004	Above message repeated 25 times
[INFO]	Sat Jan 31 10:36:18 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:36:18 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:36:07 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:36:07 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:35:56 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:35:56 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:35:51 2004	Blocked incoming ICMP error message (ICMP type 3) from 65.55.42.131 to 213.93.107.82 as there is no UDP session active between 213.93.107.82:3074 and 65.55.42.131:3074
[INFO]	Sat Jan 31 10:35:51 2004	Above message repeated 1 times
[WARN]	Sat Jan 31 10:35:49 2004	A network computer (7CED8DB08861) was assigned the IP address of 192.168.0.195.
[INFO]	Sat Jan 31 10:35:47 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 7CED8DB08861 secured with: AES
[INFO]	Sat Jan 31 10:35:47 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 7CED8DB08861 linked
[INFO]	Sat Jan 31 10:35:45 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:35:45 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:35:44 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 7CED8DB08861 associated
[INFO]	Sat Jan 31 10:35:33 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:35:33 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:35:22 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:35:22 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[WARN]	Sat Jan 31 10:35:15 2004	Blocked incoming TCP packet from 27.131.143.162:24529 to 213.93.107.82:22
[INFO]	Sat Jan 31 10:35:11 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:35:11 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:35:00 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:35:00 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[WARN]	Sat Jan 31 10:34:53 2004	Blocked incoming TCP packet from 141.212.121.77:58300 to 213.93.107.82:443
[INFO]	Sat Jan 31 10:34:49 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:34:49 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:34:38 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:34:38 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:34:27 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:34:27 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:34:16 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:34:16 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:34:05 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:34:05 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:33:54 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:33:54 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:33:43 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:33:43 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:33:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:33:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:33:25 2004	Blocked incoming TCP packet from 188.125.68.129:993 to 213.93.107.82:51552 as PSH:ACK received but there is no active connection
[INFO]	Sat Jan 31 10:33:21 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:33:21 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:33:10 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:33:10 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:32:59 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:32:59 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:32:54 2004	Blocked incoming TCP packet from 188.125.68.129:993 to 213.93.107.82:51552 as PSH:ACK received but there is no active connection
[INFO]	Sat Jan 31 10:32:39 2004	Above message repeated 1 times
[INFO]	Sat Jan 31 10:32:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:32:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:32:32 2004	Blocked incoming TCP packet from 188.125.68.129:993 to 213.93.107.82:51552 as PSH:ACK received but there is no active connection
[INFO]	Sat Jan 31 10:32:24 2004	Above message repeated 4 times
[INFO]	Sat Jan 31 10:32:24 2004	Blocked incoming TCP packet from 188.125.68.129:993 to 213.93.107.82:51552 as FIN:PSH:ACK received but there is no active connection
[INFO]	Sat Jan 31 10:32:24 2004	Blocked incoming TCP packet from 188.125.68.129:993 to 213.93.107.82:51552 as PSH:ACK received but there is no active connection
[WARN]	Sat Jan 31 10:32:23 2004	A network computer (00254B8B8BC6) was assigned the IP address of 192.168.0.196.
[INFO]	Sat Jan 31 10:32:23 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 00254B8B8BC6 secured with: AES
[INFO]	Sat Jan 31 10:32:23 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 00254B8B8BC6 linked
[INFO]	Sat Jan 31 10:32:23 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 00254B8B8BC6 associated
[INFO]	Sat Jan 31 10:32:21 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:32:21 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:32:10 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:32:10 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:31:59 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:31:59 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:31:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:31:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:31:21 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:31:21 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:31:10 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:31:10 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[WARN]	Sat Jan 31 10:31:09 2004	Blocked incoming UDP packet from 65.55.42.183:3074 to 213.93.107.82:3074
[WARN]	Sat Jan 31 10:31:05 2004	A network computer (iPhonevnDaniela) was assigned the IP address of 192.168.0.197.
[INFO]	Sat Jan 31 10:31:03 2004	Radio 1 SitecomF149B1: Wireless system with MAC address EC358664E684 secured with: AES
[INFO]	Sat Jan 31 10:31:03 2004	Radio 1 SitecomF149B1: Wireless system with MAC address EC358664E684 linked
[INFO]	Sat Jan 31 10:31:03 2004	Radio 1 SitecomF149B1: Wireless system with MAC address EC358664E684 associated
[WARN]	Sat Jan 31 10:31:00 2004	A network computer (Windows-Phone) was assigned the IP address of 192.168.0.198.
[INFO]	Sat Jan 31 10:31:00 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:31:00 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 associated
[INFO]	Sat Jan 31 10:30:59 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:30:59 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:30:56 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 disconnected for reason: Received Deauthentication
[INFO]	Sat Jan 31 10:30:55 2004	Radio 2 SitecomF14D99: Wireless system with MAC address BCCFCC73FD80 secured with: AES
[INFO]	Sat Jan 31 10:30:55 2004	Radio 2 SitecomF14D99: Wireless system with MAC address BCCFCC73FD80 linked
[INFO]	Sat Jan 31 10:30:55 2004	Radio 2 SitecomF14D99: Wireless system with MAC address BCCFCC73FD80 associated
[WARN]	Sat Jan 31 10:30:55 2004	A network computer (Hostname) was assigned the IP address of 192.168.0.190.
[INFO]	Sat Jan 31 10:30:53 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 associated
[WARN]	Sat Jan 31 10:30:53 2004	A network computer (Hostname) was assigned the IP address of 192.168.0.190.
[INFO]	Sat Jan 31 10:30:48 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:30:48 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[WARN]	Sat Jan 31 10:30:44 2004	A network computer (Djhoon) was assigned the IP address of 192.168.0.193.
[INFO]	Sat Jan 31 10:30:44 2004	Radio 1 SitecomF149B1: Wireless system with MAC address 041552B72FF3 secured with: AES
[INFO]	Sat Jan 31 10:30:44 2004	Radio 1 SitecomF149B1: Wireless system with MAC address 041552B72FF3 linked
[INFO]	Sat Jan 31 10:30:44 2004	Radio 1 SitecomF149B1: Wireless system with MAC address 041552B72FF3 associated
[INFO]	Sat Jan 31 10:30:40 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 041552B72FF3 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:30:40 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 041552B72FF3 associated
[WARN]	Sat Jan 31 10:30:39 2004	Blocked incoming UDP packet from 212.64.149.184:3074 to 213.93.107.82:3074
[INFO]	Sat Jan 31 10:30:39 2004	Firmware upgrade server [url]www.sitecom.com[/url] is at IP address 217.148.166.179
[WARN]	Sat Jan 31 10:30:39 2004	Blocked incoming UDP packet from 65.55.42.183:3074 to 213.93.107.82:3074
[INFO]	Sat Jan 31 10:30:38 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 disconnected for reason: Received Deauthentication
[INFO]	Sat Jan 31 10:30:37 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 disconnected for reason: Authentication Failed
[INFO]	Sat Jan 31 10:30:37 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 68A86D61ED57 associated
[INFO]	Sat Jan 31 10:30:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 64D1A31B09BB secured with: AES
[INFO]	Sat Jan 31 10:30:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 64D1A31B09BB linked
[INFO]	Sat Jan 31 10:30:35 2004	Radio 2 SitecomF14D99: Wireless system with MAC address 64D1A31B09BB associated
[INFO]	Sat Jan 31 10:30:35 2004	WAN interface speed measurement completed. Upstream speed is 6543 kbps
[INFO]	Sat Jan 31 10:30:34 2004	LAN Auto-IP obtained address 169.254.73.36
[INFO]	Sat Jan 31 10:30:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 associated
[INFO]	Sat Jan 31 10:30:32 2004	Radio 2 SitecomF14D99: Wireless system with MAC address EC358664E684 disconnected for reason: Authentication Failed
[WARN]	Sat Jan 31 10:30:29 2004	A network computer (HP8A7539) was assigned the IP address of 192.168.0.199.
[INFO]	Sat Jan 31 10:30:28 2004	Radio 2 SitecomF14D99: Wireless system with MAC address D8D3858A753A secured with: AES
[INFO]	Sat Jan 31 10:30:28 2004	Radio 2 SitecomF14D99: Wireless system with MAC address D8D3858A753A linked
[INFO]	Sat Jan 31 10:30:25 2004	Radio 2 SitecomF14D99: Wireless system with MAC address D8D3858A753A associated
[INFO]	Sat Jan 31 10:30:24 2004	Radio 2: Wireless link is up
[INFO]	Sat Jan 31 10:30:15 2004	Radio 1: Wireless link is up
[INFO]	Sat Jan 31 10:30:14 2004	Starting DHCP server
[INFO]	Sat Jan 31 10:30:14 2004	Estimating speed of WAN interface
[INFO]	Sat Jan 31 10:30:13 2004	Obtained IP Address using DHCP. IP address is 213.93.107.82
[INFO]	Sat Jan 31 10:30:13 2004	Bringing up WAN using DHCP
[INFO]	Sat Jan 31 10:30:13 2004	WAN interface cable has been connected
[INFO]	Sat Jan 31 10:30:12 2004	LAN interface is up
Ik heb de router trouwens al een paar keer gereset en de modem is ook al vaak herstart en sorry dat de log zo lang is ik dacht dat het vanaf de reset moest
ik heb de code tags r maar even omheen gezet.
Mijn muis wieltje begon te kraken :d
Wat het meest opvalt is >autentication failed<
Dus de wpa/wpa2 sleutel klopt niet.
En een hoop udp/tcp pakketten worden geblokkeerd.
En de router zit niet op internet met een datum van 2004.
Is al een ouwetje.
Is al een ouwetje.
De router is vrij nieuw maar door de reset die ik laatst had gedaan is de tijd vekeerd geworden maar het licht niet aan de tijjd instelling.
Dat autentication failed bericht komt omdat het wachtwoord weer naar standaard is verandert.
Ik weet alleen niet wat udp/tcp pakketten zijn wat ze doen of waarom ze geblokeerd worden:confused:
Ik bedenk mij net dat ik op mijn vorige router ook dit probleem had en dat het bericht
Blocked incoming tcp/udp packets ofzoiets er ook was maar ik weet alleen niet wat het betekend en wat ik er aan kan doen :(:(:(:(
Tja, als je een reset doet moet je ook alles weer opnieuw instellen.
SSID
WPA sleutel.
Eventueel ip adres.
De tijd moet automatisch gaan, want er altijd wel een tijd server voor ingesteld in de router.
Tenzij de router geen internet verbinding tot stand kan brengen.
SSID
WPA sleutel.
Eventueel ip adres.
Maar is dit denk je het probleem want voor de reset hat ik het ook al maar toen stond de tijd goed
Hier staat dat ik de tijd op manual heb staan
Nu ik toch ingelogd ben is hier nog wat meer informatie over mijn tijdelijke routerstatus
Je hebt inderdaad geen tijd server geselecteerd.
Even op de dropdown box klikken.
En stuur eens een plaatje van je firewall van de router.
Aan de DNS server te zien gebruik je UPC.
Dan heeft je sitecom router hetzelfde ip adres als je UPC modem.
Dit moet je ook veranderen
Plus de dhcp server van 1 van de 2 uitzetten.
Hier zijn een paar screenshots ik weet alleen niet precies welk stukje je wilt zien van de firewall dus heb ik een foto van t firewall menu en een paar van ergens bij advanced settings image.webpimage.webpimage.webp
Ik moet dus hier mijn router ip veranderen????? Sorry ik ben hier echt slecht in... image.webp
Vreemd dat je bij udp adress restricted hebt aangeklikt en bij tcp port and adress resticted.
Ik zou spi uitklikken
Het maakt je verbinding onnodig trager.
Je gebruikt dus Skype en iets wat op poort 68 zit.
Ik heb wel eens geprobeert twee routers te gebruiken en daarvoor moest ik zoiets doen dus als de rede op mijn ip adres te veranderen hetzelfde is als met twee routers dan is het misschien handig om te weten dat ik op mijn upc modem draadloos internet uitgeschakeld heb
Ja ik weet ook niet waarom dat allemaal aanstaat ik weet nieteens wat het betekend het zijn de standaard settings dus dat is wel raar van sitecom als ze reclameren met snelste router enzo
Beste Kobus, van harte welkom op Helpmij.nl
Ik heb je eerste 2 berichten samen gevoegd. Als je in het vervolg nog wat aan een bericht wil toevoegen kan je de knop "aanpassen" gebruiken.
