<?php
function sMail($recepient, $subject, $message, $sender, $senderName = '', $recipientName = '', $server = 'relay.webdoos.be', $port = 25, $username = 'maildoos', $password = 'dsg547dhyj48zef84eh584n54cxv54t') {
try {
$message = preg_replace('/\\\\/','', $message);
$mail = new PHPMailer(true);
$mail->IsSMTP();
$mail->SMTPAuth = true;
$mail->set('Port', $port);
$mail->set('Host', $server);
$mail->set('Username', $username);
$mail->set('Password', $password);
$mail->set('ReturnPath', $sender);
$mail->set('From', $sender);
$mail->set('FromName', $senderName);
$mail->IsSendmail();
$mail->AddReplyTo($sender, $senderName);
$mail->AddAddress($recepient, $recipientName);
$mail->AddBCC('formcatcher@webdoos.be', 'Formcatcher');
$mail->AddCustomHeader("X-Complaints-To: abuse@maildoos.be");
$mail->AddCustomHeader("X-Abuse-To: abuse@maildoos.be");
$mail->Subject = $subject;
$mail->WordWrap = 80;
$mail->MsgHTML($message);
$mail->IsHTML(true);
$mail->Mailer = 'smtp';
$mail->Send();
return 'Message has been sent!';
} catch (phpmailerException $e) {
return $e->errorMessage();
} catch (Exception $e) {
return $e->getMessage();
}//try
}//sMail
/*~ class.phpmailer.php
| Software: PHPMailer - PHP email class |
| Version: 5.1 |
| Contact: via sourceforge.net support pages (also www.worxware.com) |
| Info: http://phpmailer.sourceforge.net |
| Support: http://sourceforge.net/projects/phpmailer/ |
| Admin: Andy Prevost (project admininistrator) |
| Authors: Andy Prevost (codeworxtech) codeworxtech@users.sourceforge.net |
| : Marcus Bointon (coolbru) coolbru@users.sourceforge.net |
| Founder: Brent R. Matzelle (original founder) |
| Copyright (c) 2004-2009, Andy Prevost. All Rights Reserved. |
| Copyright (c) 2001-2003, Brent R. Matzelle |
| License: Distributed under the Lesser General Public License (LGPL) |
| http://www.gnu.org/copyleft/lesser.html |
| This program is distributed in the hope that it will be useful - WITHOUT |
| ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or |
| FITNESS FOR A PARTICULAR PURPOSE. |
| We offer a number of paid services (www.worxware.com): |
| - Web Hosting on highly optimized fast and secure servers |
| - Technology Consulting |
| - Oursourcing (highly qualified programmers and graphic designers) |
* PHPMailer - PHP email transport class
* NOTE: Requires PHP version 5 or later
* @package PHPMailer
* @author Andy Prevost
* @author Marcus Bointon
* @copyright 2004 - 2009 Andy Prevost
* @version $Id: class.phpmailer.php 447 2009-05-25 01:36:38Z codeworxtech $
* @license http://www.gnu.org/copyleft/lesser.html GNU Lesser General Public License
if (version_compare(PHP_VERSION, '5.0.0', '<') ) exit("Sorry, this version of PHPMailer will only run on PHP version 5 or greater!\n");
class PHPMailer {
* Email priority (1 = High, 3 = Normal, 5 = low).
* @var int
public $Priority = 3;
* Sets the CharSet of the message.
* @var string
public $CharSet = 'iso-8859-1';
* Sets the Content-type of the message.
* @var string
public $ContentType = 'text/plain';
* Sets the Encoding of the message. Options for this are
* "8bit", "7bit", "binary", "base64", and "quoted-printable".
* @var string
public $Encoding = '8bit';
* Holds the most recent mailer error message.
* @var string
public $ErrorInfo = '';
* Sets the From email address for the message.
* @var string
public $From = 'root@localhost';
* Sets the From name of the message.
* @var string
public $FromName = 'Root User';
* Sets the Sender email (Return-Path) of the message. If not empty,
* will be sent via -f to sendmail or as 'MAIL FROM' in smtp mode.
* @var string
public $Sender = '';
* Sets the Subject of the message.
* @var string
public $Subject = '';
* Sets the Body of the message. This can be either an HTML or text body.
* If HTML then run IsHTML(true).
* @var string
public $Body = '';
* Sets the text-only body of the message. This automatically sets the
* email to multipart/alternative. This body can be read by mail
* clients that do not have HTML email capability such as mutt. Clients
* that can read HTML will view the normal Body.
* @var string
public $AltBody = '';
* Sets word wrapping on the body of the message to a given number of
* characters.
* @var int
public $WordWrap = 0;
* Method to send mail: ("mail", "sendmail", or "smtp").
* @var string
public $Mailer = 'mail';
* Sets the path of the sendmail program.
* @var string
public $Sendmail = '/usr/sbin/sendmail';
* Path to PHPMailer plugins. Useful if the SMTP class
* is in a different directory than the PHP include path.
* @var string
public $PluginDir = '';
* Sets the email address that a reading confirmation will be sent.
* @var string
public $ConfirmReadingTo = '';
* Sets the hostname to use in Message-Id and Received headers
* and as default HELO string. If empty, the value returned
* by SERVER_NAME is used or 'localhost.localdomain'.
* @var string
public $Hostname = '';
* Sets the message ID to be used in the Message-Id header.
* If empty, a unique id will be generated.
* @var string
public $MessageID = '';
* Sets the SMTP hosts. All hosts must be separated by a
* semicolon. You can also specify a different port
* for each host by using this format: [hostname:port]
* (e.g. "smtp1.example.com:25;smtp2.example.com").
* Hosts will be tried in order.
* @var string
public $Host = 'localhost';
* Sets the default SMTP server port.
* @var int
public $Port = 25;
* Sets the SMTP HELO of the message (Default is $Hostname).
* @var string
public $Helo = '';
* Sets connection prefix.
* Options are "", "ssl" or "tls"
* @var string
public $SMTPSecure = '';
* Sets SMTP authentication. Utilizes the Username and Password variables.
* @var bool
public $SMTPAuth = false;
* Sets SMTP username.
* @var string
public $Username = '';
* Sets SMTP password.
* @var string
public $Password = '';
* Sets the SMTP server timeout in seconds.
* This function will not work with the win32 version.
* @var int
public $Timeout = 10;
* Sets SMTP class debugging on or off.
* @var bool
public $SMTPDebug = false;
* Prevents the SMTP connection from being closed after each mail
* sending. If this is set to true then to close the connection
* requires an explicit call to SmtpClose().
* @var bool
public $SMTPKeepAlive = false;
* Provides the ability to have the TO field process individual
* emails, instead of sending to entire TO addresses
* @var bool
public $SingleTo = false;
* If SingleTo is true, this provides the array to hold the email addresses
* @var bool
public $SingleToArray = array();
* Provides the ability to change the line ending
* @var string
public $LE = "\n";
* Used with DKIM DNS Resource Record
* @var string
public $DKIM_selector = 'phpmailer';
* optional, in format of email address 'you@yourdomain.com'
* @var string
public $DKIM_identity = '';
* @var string
public $DKIM_domain = '';
* @var string
public $DKIM_private = '';
* Callback Action function name
* the function that handles the result of the send email action. Parameters:
* bool $result result of the send action
* string $to email address of the recipient
* string $cc cc email addresses
* string $bcc bcc email addresses
* string $subject the subject
* string $body the email body
* @var string
public $action_function = ''; //'callbackAction';
* Sets the PHPMailer Version number
* @var string
public $Version = '5.1';
private $smtp = NULL;
private $to = array();
private $cc = array();
private $bcc = array();
private $ReplyTo = array();
private $all_recipients = array();
private $attachment = array();
private $CustomHeader = array();
private $message_type = '';
private $boundary = array();
protected $language = array();
private $error_count = 0;
private $sign_cert_file = "";
private $sign_key_file = "";
private $sign_key_pass = "";
private $exceptions = false;
const STOP_MESSAGE = 0; // message only, continue processing
const STOP_CONTINUE = 1; // message?, likely ok to continue processing
const STOP_CRITICAL = 2; // message, plus full stop, critical error reached
* Constructor
* @param boolean $exceptions Should we throw external exceptions?
public function __construct($exceptions = false) {
$this->exceptions = ($exceptions == true);
* Sets message type to HTML.
* @param bool $ishtml
* @return void
public function IsHTML($ishtml = true) {
if ($ishtml) {
$this->ContentType = 'text/html';
} else {
$this->ContentType = 'text/plain';
* Sets Mailer to send message using SMTP.
* @return void
public function IsSMTP() {
$this->Mailer = 'smtp';
* Sets Mailer to send message using PHP mail() function.
* @return void
public function IsMail() {
$this->Mailer = 'mail';
* Sets Mailer to send message using the $Sendmail program.
* @return void
public function IsSendmail() {
if (!stristr(ini_get('sendmail_path'), 'sendmail')) {
$this->Sendmail = '/var/qmail/bin/sendmail';
$this->Mailer = 'sendmail';
* Sets Mailer to send message using the qmail MTA.
* @return void
public function IsQmail() {
if (stristr(ini_get('sendmail_path'), 'qmail')) {
* Adds a "To" address.
* @param string $address
* @param string $name
* @return boolean true on success, false if address already used
public function AddAddress($address, $name = '') {
return $this->AddAnAddress('to', $address, $name);
* Adds a "Cc" address.
* Note: this function works with the SMTP mailer on win32, not with the "mail" mailer.
public function AddCC($address, $name = '') {
return $this->AddAnAddress('cc', $address, $name);
* Adds a "Bcc" address.
public function AddBCC($address, $name = '') {
return $this->AddAnAddress('bcc', $address, $name);
* Adds a "Reply-to" address.
* @return boolean
public function AddReplyTo($address, $name = '') {
return $this->AddAnAddress('ReplyTo', $address, $name);
* Adds an address to one of the recipient arrays
* Addresses that have been added already return false, but do not throw exceptions
* @param string $kind One of 'to', 'cc', 'bcc', 'ReplyTo'
* @param string $address The email address to send to
* @return boolean true on success, false if address already used or invalid in some way
* @access private
private function AddAnAddress($kind, $address, $name = '') {
if (!preg_match('/^(to|cc|bcc|ReplyTo)$/', $kind)) {
echo 'Invalid recipient array: ' . kind;
return false;
$address = trim($address);
$name = trim(preg_replace('/[\r\n]+/', '', $name)); //Strip breaks and trim
if (!self::ValidateAddress($address)) {
$this->SetError($this->Lang('invalid_address').': '. $address);
if ($this->exceptions) {
throw new phpmailerException($this->Lang('invalid_address').': '.$address);
echo $this->Lang('invalid_address').': '.$address;
return false;
if ($kind != 'ReplyTo') {
if (!isset($this->all_recipients[strtolower($address)])) {
array_push($this->$kind, array($address, $name));
$this->all_recipients[strtolower($address)] = true;
return true;
} else {
if (!array_key_exists(strtolower($address), $this->ReplyTo)) {
$this->ReplyTo[strtolower($address)] = array($address, $name);
return true;
return false;
* Set the From and FromName properties
* @return boolean
public function SetFrom($address, $name = '',$auto=1) {
return false;
$this->From = $address;
$this->FromName = $name;
if ($auto) {
if (empty($this->ReplyTo)) {
if (empty($this->Sender)) {
$this->Sender = $address;
return true;
* Check that a string looks roughly like an email address should
* Static so it can be used without instantiation
* Tries to use PHP built-in validator in the filter extension (from PHP 5.2), falls back to a reasonably competent regex validator
* Conforms approximately to RFC2822
* @link http://www.hexillion.com/samples/#Regex Original pattern found here
* @param string $address The email address to check
* @return boolean
* @static
* @access public
public static function ValidateAddress($address) {
if (function_exists('filter_var')) { //Introduced in PHP 5.2
if(filter_var($address, FILTER_VALIDATE_EMAIL) === FALSE) {
return false;
} else {
return true;
} else {
return preg_match('/^(?:[\w\!\#\$\%\&\'\*\+\-\/\=\?\^\`\{\|\}\~]+\.)*[\w\!\#\$\%\&\'\*\+\-\/\=\?\^\`\{\|\}\~]+@(?:(?:(?:[a-zA-Z0-9_](?:[a-zA-Z0-9_\-](?!\.)){0,61}[a-zA-Z0-9_-]?\.)+[a-zA-Z0-9_](?:[a-zA-Z0-9_\-](?!$)){0,61}[a-zA-Z0-9_]?)|(?:\[(?:(?:[01]?\d{1,2}|2[0-4]\d|25[0-5])\.){3}(?:[01]?\d{1,2}|2[0-4]\d|25[0-5])\]))$/', $address);
* Creates message and assigns Mailer. If the message is
* not sent successfully then it returns false. Use the ErrorInfo
* variable to view description of the error.
* @return bool
public function Send() {
try {
if ((count($this->to) + count($this->cc) + count($this->bcc)) < 1) {
throw new phpmailerException($this->Lang('provide_address'), self::STOP_CRITICAL);
// Set whether the message is multipart/alternative
if(!empty($this->AltBody)) {
$this->ContentType = 'multipart/alternative';
$this->error_count = 0; // reset errors
$this->SetMessageType();
$header = $this->CreateHeader();
$body = $this->CreateBody();
if (empty($this->Body)) {
throw new phpmailerException($this->Lang('empty_message'), self::STOP_CRITICAL);
// digitally sign with DKIM if enabled
if ($this->DKIM_domain && $this->DKIM_private) {
$header_dkim = $this->DKIM_Add($header,$this->Subject,$body);
$header = str_replace("\r\n","\n",$header_dkim) . $header;
// Choose the mailer and send through it
switch($this->Mailer) {
case 'sendmail':
return $this->SendmailSend($header, $body);
case 'smtp':
return $this->SmtpSend($header, $body);
default:
return $this->MailSend($header, $body);
$this->SetError($e->getMessage());
throw $e;
echo $e->getMessage()."\n";
return false;
* Sends mail using the $Sendmail program.
* @param string $header The message headers
* @param string $body The message body
* @access protected
* @return bool
protected function SendmailSend($header, $body) {
if ($this->Sender != '') {
$sendmail = sprintf("%s -oi -f %s -t", escapeshellcmd($this->Sendmail), escapeshellarg($this->Sender));
} else {
$sendmail = sprintf("%s -oi -t", escapeshellcmd($this->Sendmail));
if ($this->SingleTo === true) {
foreach ($this->SingleToArray as $key => $val) {
if(!@$mail = popen($sendmail, 'w')) {
throw new phpmailerException($this->Lang('execute') . $this->Sendmail, self::STOP_CRITICAL);
fputs($mail, "To: " . $val . "\n");
fputs($mail, $header);
fputs($mail, $body);
$result = pclose($mail);
// implement call back function if it exists
$isSent = ($result == 0) ? 1 : 0;
$this->doCallback($isSent,$val,$this->cc,$this->bcc,$this->Subject,$body);
if($result != 0) {
} else {
$this->doCallback($isSent,$this->to,$this->cc,$this->bcc,$this->Subject,$body);
if($result != 0) {
return true;
* Sends mail using the PHP mail() function.
* @access protected
* @return bool
protected function MailSend($header, $body) {
$toArr = array();
foreach($this->to as $t) {
$toArr[] = $this->AddrFormat($t);
$to = implode(', ', $toArr);
$params = sprintf("-oi -f %s", $this->Sender);
if ($this->Sender != '' && strlen(ini_get('safe_mode'))< 1) {
$old_from = ini_get('sendmail_from');
ini_set('sendmail_from', $this->Sender);
if ($this->SingleTo === true && count($toArr) > 1) {
foreach ($toArr as $key => $val) {
$rt = @mail($val, $this->EncodeHeader($this->SecureHeader($this->Subject)), $body, $header, $params);
$isSent = ($rt == 1) ? 1 : 0;
} else {
$rt = @mail($to, $this->EncodeHeader($this->SecureHeader($this->Subject)), $body, $header, $params);
$this->doCallback($isSent,$to,$this->cc,$this->bcc,$this->Subject,$body);
} else {
} else {
$rt = @mail($to, $this->EncodeHeader($this->SecureHeader($this->Subject)), $body, $header);
if (isset($old_from)) {
ini_set('sendmail_from', $old_from);
if(!$rt) {
throw new phpmailerException($this->Lang('instantiate'), self::STOP_CRITICAL);
return true;
* Sends mail via SMTP using PhpSMTP
* Returns false if there is a bad MAIL FROM, RCPT, or DATA input.
* @uses SMTP
* @access protected
* @return bool
protected function SmtpSend($header, $body) {
require_once $this->PluginDir . 'class.smtp.php';
$bad_rcpt = array();
if(!$this->SmtpConnect()) {
throw new phpmailerException($this->Lang('smtp_connect_failed'), self::STOP_CRITICAL);
$smtp_from = ($this->Sender == '') ? $this->From : $this->Sender;
if(!$this->smtp->Mail($smtp_from)) {
throw new phpmailerException($this->Lang('from_failed') . $smtp_from, self::STOP_CRITICAL);
// Attempt to send attach all recipients
foreach($this->to as $to) {
if (!$this->smtp->Recipient($to[0])) {
$bad_rcpt[] = $to[0];
$isSent = 0;
$this->doCallback($isSent,$to[0],'','',$this->Subject,$body);
} else {
$isSent = 1;
foreach($this->cc as $cc) {
if (!$this->smtp->Recipient($cc[0])) {
$bad_rcpt[] = $cc[0];
$isSent = 0;
$this->doCallback($isSent,'',$cc[0],'',$this->Subject,$body);
} else {
$isSent = 1;
foreach($this->bcc as $bcc) {
if (!$this->smtp->Recipient($bcc[0])) {
$bad_rcpt[] = $bcc[0];
$isSent = 0;
$this->doCallback($isSent,'','',$bcc[0],$this->Subject,$body);
} else {
$isSent = 1;
if (count($bad_rcpt) > 0 ) { //Create error message for any bad addresses
$badaddresses = implode(', ', $bad_rcpt);
throw new phpmailerException($this->Lang('recipients_failed') . $badaddresses);
if(!$this->smtp->Data($header . $body)) {
throw new phpmailerException($this->Lang('data_not_accepted'), self::STOP_CRITICAL);
if($this->SMTPKeepAlive == true) {
$this->smtp->Reset();
return true;
* Initiates a connection to an SMTP server.
* Returns false if the operation failed.
* @uses SMTP
* @access public
* @return bool
public function SmtpConnect() {
if(is_null($this->smtp)) {
$this->smtp = new SMTP();
$this->smtp->do_debug = $this->SMTPDebug;
$hosts = explode(';', $this->Host);
$index = 0;
$connection = $this->smtp->Connected();
// Retry while there is no connection
try {
while($index < count($hosts) && !$connection) {
$hostinfo = array();
if (preg_match('/^(.+):([0-9]+)$/', $hosts[$index], $hostinfo)) {
$host = $hostinfo[1];
$port = $hostinfo[2];
} else {
$host = $hosts[$index];
$port = $this->Port;
$tls = ($this->SMTPSecure == 'tls');
$ssl = ($this->SMTPSecure == 'ssl');
if ($this->smtp->Connect(($ssl ? 'ssl://':'').$host, $port, $this->Timeout)) {
$hello = ($this->Helo != '' ? $this->Helo : $this->ServerHostname());
$this->smtp->Hello($hello);
if ($tls) {
if (!$this->smtp->StartTLS()) {
throw new phpmailerException($this->Lang('tls'));
//We must resend HELO after tls negotiation
$connection = true;
if ($this->SMTPAuth) {
if (!$this->smtp->Authenticate($this->Username, $this->Password)) {
throw new phpmailerException($this->Lang('authenticate'));
$index++;
if (!$connection) {
throw new phpmailerException($this->Lang('connect_host'));
throw $e;
return true;
* Closes the active SMTP session if one exists.
* @return void
public function SmtpClose() {
if(!is_null($this->smtp)) {
if($this->smtp->Connected()) {
$this->smtp->Quit();
$this->smtp->Close();
* Sets the language for all class error messages.
* Returns false if it cannot load the language file. The default language is English.
* @param string $langcode ISO 639-1 2-character language code (e.g. Portuguese: "br")
* @param string $lang_path Path to the language file directory
* @access public
function SetLanguage($langcode = 'en', $lang_path = 'language/') {
//Define full set of translatable strings
$PHPMAILER_LANG = array(
'provide_address' => 'You must provide at least one recipient email address.',
'mailer_not_supported' => ' mailer is not supported.',
'execute' => 'Could not execute: ',
'instantiate' => 'Could not instantiate mail function.',
'authenticate' => 'SMTP Error: Could not authenticate.',
'from_failed' => 'The following From address failed: ',
'recipients_failed' => 'SMTP Error: The following recipients failed: ',
'data_not_accepted' => 'SMTP Error: Data not accepted.',
'connect_host' => 'SMTP Error: Could not connect to SMTP host.',
'file_access' => 'Could not access file: ',
'file_open' => 'File Error: Could not open file: ',
'encoding' => 'Unknown encoding: ',
'signing' => 'Signing Error: ',
'smtp_error' => 'SMTP server error: ',
'empty_message' => 'Message body empty',
'invalid_address' => 'Invalid address',
'variable_set' => 'Cannot set or reset variable: '
//Overwrite language-specific strings. This way we'll never have missing translations - no more "language string failed to load"!
$l = true;
if ($langcode != 'en') { //There is no English translation file
$l = @include $lang_path.'phpmailer.lang-'.$langcode.'.php';
$this->language = $PHPMAILER_LANG;
return ($l == true); //Returns false if language not found
* Return the current array of language strings
* @return array
public function GetTranslations() {
return $this->language;
* Creates recipient headers.
* @access public
* @return string
public function AddrAppend($type, $addr) {
$addr_str = $type . ': ';
$addresses = array();
foreach ($addr as $a) {
$addresses[] = $this->AddrFormat($a);
$addr_str .= implode(', ', $addresses);
$addr_str .= $this->LE;
return $addr_str;
* Formats an address correctly.
* @access public
* @return string
public function AddrFormat($addr) {
if (empty($addr[1])) {
return $this->SecureHeader($addr[0]);
} else {
return $this->EncodeHeader($this->SecureHeader($addr[1]), 'phrase') . " <" . $this->SecureHeader($addr[0]) . ">";
* Wraps message for use with mailers that do not
* automatically perform wrapping and for quoted-printable.
* Original written by philippe.
* @param string $message The message to wrap
* @param integer $length The line length to wrap to
* @param boolean $qp_mode Whether to run in Quoted-Printable mode
* @access public
* @return string
public function WrapText($message, $length, $qp_mode = false) {
$soft_break = ($qp_mode) ? sprintf(" =%s", $this->LE) : $this->LE;
// If utf-8 encoding is used, we will need to make sure we don't
// split multibyte characters when we wrap
$is_utf8 = (strtolower($this->CharSet) == "utf-8");
$message = $this->FixEOL($message);
if (substr($message, -1) == $this->LE) {
$message = substr($message, 0, -1);
$line = explode($this->LE, $message);
$message = '';
for ($i=0 ;$i < count($line); $i++) {
$line_part = explode(' ', $line[$i]);
$buf = '';
for ($e = 0; $e<count($line_part); $e++) {
$word = $line_part[$e];
if ($qp_mode and (strlen($word) > $length)) {
$space_left = $length - strlen($buf) - 1;
if ($e != 0) {
if ($space_left > 20) {
$len = $space_left;
if ($is_utf8) {
$len = $this->UTF8CharBoundary($word, $len);
} elseif (substr($word, $len - 1, 1) == "=") {
$len--;
} elseif (substr($word, $len - 2, 1) == "=") {
$len -= 2;
$part = substr($word, 0, $len);
$word = substr($word, $len);
$buf .= ' ' . $part;
$message .= $buf . sprintf("=%s", $this->LE);
} else {
$message .= $buf . $soft_break;
$buf = '';
while (strlen($word) > 0) {
$len = $length;
if ($is_utf8) {
$len--;
$len -= 2;
if (strlen($word) > 0) {
$message .= $part . sprintf("=%s", $this->LE);
} else {
$buf = $part;
} else {
$buf_o = $buf;
$buf .= ($e == 0) ? $word : (' ' . $word);
if (strlen($buf) > $length and $buf_o != '') {
$message .= $buf_o . $soft_break;
$buf = $word;
$message .= $buf . $this->LE;
return $message;
* Finds last character boundary prior to maxLength in a utf-8
* quoted (printable) encoded string.
* Original written by Colin Brown.
* @access public
* @param string $encodedText utf-8 QP text
* @param int $maxLength find last character boundary prior to this length
* @return int
public function UTF8CharBoundary($encodedText, $maxLength) {
$foundSplitPos = false;
$lookBack = 3;
while (!$foundSplitPos) {
$lastChunk = substr($encodedText, $maxLength - $lookBack, $lookBack);
$encodedCharPos = strpos($lastChunk, "=");
if ($encodedCharPos !== false) {
// Found start of encoded character byte within $lookBack block.
// Check the encoded byte value (the 2 chars after the '=')
$hex = substr($encodedText, $maxLength - $lookBack + $encodedCharPos + 1, 2);
$dec = hexdec($hex);
if ($dec < 128) { // Single byte character.
// If the encoded char was found at pos 0, it will fit
// otherwise reduce maxLength to start of the encoded char
$maxLength = ($encodedCharPos == 0) ? $maxLength :
$maxLength - ($lookBack - $encodedCharPos);
$foundSplitPos = true;
} elseif ($dec >= 192) { // First byte of a multi byte character
// Reduce maxLength to split at start of character
$maxLength = $maxLength - ($lookBack - $encodedCharPos);
} elseif ($dec < 192) { // Middle byte of a multi byte character, look further back
$lookBack += 3;
} else {
// No encoded character found
return $maxLength;
* Set the body wrapping.
* @access public
* @return void
public function SetWordWrap() {
if($this->WordWrap < 1) {
return;
switch($this->message_type) {
case 'alt':
case 'alt_attachments':
$this->AltBody = $this->WrapText($this->AltBody, $this->WordWrap);
break;
default:
$this->Body = $this->WrapText($this->Body, $this->WordWrap);
break;
* Assembles message header.
* @access public
* @return string The assembled header
public function CreateHeader() {
$result = '';
// Set the boundaries
$uniq_id = md5(uniqid(time()));
$this->boundary[1] = 'b1_' . $uniq_id;
$this->boundary[2] = 'b2_' . $uniq_id;
$result .= $this->HeaderLine('Date', self::RFCDate());
if($this->Sender == '') {
$result .= $this->HeaderLine('Return-Path', trim($this->From));
} else {
$result .= $this->HeaderLine('Return-Path', trim($this->Sender));
// To be created automatically by mail()
if($this->Mailer != 'mail') {
$this->SingleToArray[] = $this->AddrFormat($t);
} else {
if(count($this->to) > 0) {
$result .= $this->AddrAppend('To', $this->to);
} elseif (count($this->cc) == 0) {
$result .= $this->HeaderLine('To', 'undisclosed-recipients:;');
$from = array();
$from[0][0] = trim($this->From);
$from[0][1] = $this->FromName;
$result .= $this->AddrAppend('From', $from);
// sendmail and mail() extract Cc from the header before sending
if(count($this->cc) > 0) {
$result .= $this->AddrAppend('Cc', $this->cc);
// sendmail and mail() extract Bcc from the header before sending
if((($this->Mailer == 'sendmail') || ($this->Mailer == 'mail')) && (count($this->bcc) > 0)) {
$result .= $this->AddrAppend('Bcc', $this->bcc);
if(count($this->ReplyTo) > 0) {
$result .= $this->AddrAppend('Reply-to', $this->ReplyTo);
// mail() sets the subject itself
$result .= $this->HeaderLine('Subject', $this->EncodeHeader($this->SecureHeader($this->Subject)));
if($this->MessageID != '') {
$result .= $this->HeaderLine('Message-ID',$this->MessageID);
} else {
$result .= sprintf("Message-ID: <%s@%s>%s", $uniq_id, $this->ServerHostname(), $this->LE);
$result .= $this->HeaderLine('X-Priority', $this->Priority);
$result .= $this->HeaderLine('X-Mailer', 'PHPMailer '.$this->Version.' (phpmailer.sourceforge.net)');
if($this->ConfirmReadingTo != '') {
$result .= $this->HeaderLine('Disposition-Notification-To', '<' . trim($this->ConfirmReadingTo) . '>');
// Add custom headers
for($index = 0; $index < count($this->CustomHeader); $index++) {
$result .= $this->HeaderLine(trim($this->CustomHeader[$index][0]), $this->EncodeHeader(trim($this->CustomHeader[$index][1])));
if (!$this->sign_key_file) {
$result .= $this->HeaderLine('MIME-Version', '1.0');
$result .= $this->GetMailMIME();
return $result;
* Returns the message MIME.
* @access public
* @return string
public function GetMailMIME() {
$result = '';
case 'plain':
$result .= $this->HeaderLine('Content-Transfer-Encoding', $this->Encoding);
$result .= sprintf("Content-Type: %s; charset=\"%s\"", $this->ContentType, $this->CharSet);
break;
case 'attachments':
if($this->InlineImageExists()){
$result .= sprintf("Content-Type: %s;%s\ttype=\"text/html\";%s\tboundary=\"%s\"%s", 'multipart/related', $this->LE, $this->LE, $this->boundary[1], $this->LE);
} else {
$result .= $this->HeaderLine('Content-Type', 'multipart/mixed;');
$result .= $this->TextLine("\tboundary=\"" . $this->boundary[1] . '"');
break;
case 'alt':
$result .= $this->HeaderLine('Content-Type', 'multipart/alternative;');
break;
$result .= $this->LE.$this->LE;
return $result;
* Assembles the message body. Returns an empty string on failure.
* @access public
* @return string The assembled message body
public function CreateBody() {
$body = '';
if ($this->sign_key_file) {
$body .= $this->GetMailMIME();
$this->SetWordWrap();
case 'alt':
$body .= $this->GetBoundary($this->boundary[1], '', 'text/plain', '');
$body .= $this->EncodeString($this->AltBody, $this->Encoding);
$body .= $this->LE.$this->LE;
$body .= $this->GetBoundary($this->boundary[1], '', 'text/html', '');
$body .= $this->EncodeString($this->Body, $this->Encoding);
$body .= $this->EndBoundary($this->boundary[1]);
break;
case 'plain':
break;
case 'attachments':
$body .= $this->GetBoundary($this->boundary[1], '', '', '');
$body .= $this->LE;
$body .= $this->AttachAll();
break;
$body .= sprintf("--%s%s", $this->boundary[1], $this->LE);
$body .= sprintf("Content-Type: %s;%s" . "\tboundary=\"%s\"%s", 'multipart/alternative', $this->LE, $this->boundary[2], $this->LE.$this->LE);
$body .= $this->GetBoundary($this->boundary[2], '', 'text/plain', '') . $this->LE; // Create text body
$body .= $this->GetBoundary($this->boundary[2], '', 'text/html', '') . $this->LE; // Create the HTML body
$body .= $this->EndBoundary($this->boundary[2]);
break;
if ($this->IsError()) {
$body = '';
} elseif ($this->sign_key_file) {
try {
$file = tempnam('', 'mail');
file_put_contents($file, $body); //TODO check this worked
$signed = tempnam("", "signed");
if (@openssl_pkcs7_sign($file, $signed, "file://".$this->sign_cert_file, array("file://".$this->sign_key_file, $this->sign_key_pass), NULL)) {
@unlink($file);
@unlink($signed);
$body = file_get_contents($signed);
} else {
@unlink($file);
@unlink($signed);
throw new phpmailerException($this->Lang("signing").openssl_error_string());
$body = '';
throw $e;
return $body;
* Returns the start of a message boundary.
* @access private
private function GetBoundary($boundary, $charSet, $contentType, $encoding) {
$result = '';
if($charSet == '') {
$charSet = $this->CharSet;
if($contentType == '') {
$contentType = $this->ContentType;
if($encoding == '') {
$encoding = $this->Encoding;
$result .= $this->TextLine('--' . $boundary);
$result .= sprintf("Content-Type: %s; charset = \"%s\"", $contentType, $charSet);
$result .= $this->LE;
$result .= $this->HeaderLine('Content-Transfer-Encoding', $encoding);
return $result;
* Returns the end of a message boundary.
* @access private
private function EndBoundary($boundary) {
return $this->LE . '--' . $boundary . '--' . $this->LE;
* Sets the message type.
* @access private
* @return void
private function SetMessageType() {
if(count($this->attachment) < 1 && strlen($this->AltBody) < 1) {
$this->message_type = 'plain';
} else {
if(count($this->attachment) > 0) {
$this->message_type = 'attachments';
if(strlen($this->AltBody) > 0 && count($this->attachment) < 1) {
$this->message_type = 'alt';
if(strlen($this->AltBody) > 0 && count($this->attachment) > 0) {
$this->message_type = 'alt_attachments';
* Returns a formatted header line.
* @access public
* @return string
public function HeaderLine($name, $value) {
return $name . ': ' . $value . $this->LE;
* Returns a formatted mail line.
* @access public
* @return string
public function TextLine($value) {
return $value . $this->LE;
* Adds an attachment from a path on the filesystem.
* Returns false if the file could not be found
* or accessed.
* @param string $path Path to the attachment.
* @param string $name Overrides the attachment name.
* @param string $encoding File encoding (see $Encoding).
* @param string $type File extension (MIME) type.
* @return bool
public function AddAttachment($path, $name = '', $encoding = 'base64', $type = 'application/octet-stream') {
try {
if ( !@is_file($path) ) {
throw new phpmailerException($this->Lang('file_access') . $path, self::STOP_CONTINUE);
$filename = basename($path);
if ( $name == '' ) {
$name = $filename;
$this->attachment[] = array(
0 => $path,
1 => $filename,
2 => $name,
3 => $encoding,
4 => $type,
5 => false, // isStringAttachment
6 => 'attachment',
7 => 0
throw $e;
if ( $e->getCode() == self::STOP_CRITICAL ) {
return false;
return true;
* Return the current array of attachments
* @return array
public function GetAttachments() {
return $this->attachment;
* Attaches all fs, string, and binary attachments to the message.
* Returns an empty string on failure.
* @access private
* @return string
private function AttachAll() {
// Return text of body
$mime = array();
$cidUniq = array();
$incl = array();
// Add all attachments
foreach ($this->attachment as $attachment) {
// Check for string attachment
$bString = $attachment[5];
if ($bString) {
$string = $attachment[0];
} else {
$path = $attachment[0];
if (in_array($attachment[0], $incl)) { continue; }
$filename = $attachment[1];
$name = $attachment[2];
$encoding = $attachment[3];
$type = $attachment[4];
$disposition = $attachment[6];
$cid = $attachment[7];
$incl[] = $attachment[0];
if ( $disposition == 'inline' && isset($cidUniq[$cid]) ) { continue; }
$cidUniq[$cid] = true;
$mime[] = sprintf("--%s%s", $this->boundary[1], $this->LE);
$mime[] = sprintf("Content-Type: %s; name=\"%s\"%s", $type, $this->EncodeHeader($this->SecureHeader($name)), $this->LE);
$mime[] = sprintf("Content-Transfer-Encoding: %s%s", $encoding, $this->LE);
if($disposition == 'inline') {
$mime[] = sprintf("Content-ID: <%s>%s", $cid, $this->LE);
$mime[] = sprintf("Content-Disposition: %s; filename=\"%s\"%s", $disposition, $this->EncodeHeader($this->SecureHeader($name)), $this->LE.$this->LE);
// Encode as string attachment
if($bString) {
$mime[] = $this->EncodeString($string, $encoding);
if($this->IsError()) {
return '';
$mime[] = $this->LE.$this->LE;
} else {
$mime[] = $this->EncodeFile($path, $encoding);
return '';
$mime[] = sprintf("--%s--%s", $this->boundary[1], $this->LE);
return join('', $mime);
* Encodes attachment in requested format.
* @param string $path The full path to the file
* @param string $encoding The encoding to use; one of 'base64', '7bit', '8bit', 'binary', 'quoted-printable'
* @see EncodeFile()
* @access private
* @return string
private function EncodeFile($path, $encoding = 'base64') {
try {
if (!is_readable($path)) {
throw new phpmailerException($this->Lang('file_open') . $path, self::STOP_CONTINUE);
if (function_exists('get_magic_quotes')) {
function get_magic_quotes() {
return false;
if (PHP_VERSION < 6) {
$magic_quotes = get_magic_quotes_runtime();
set_magic_quotes_runtime(0);
$file_buffer = file_get_contents($path);
$file_buffer = $this->EncodeString($file_buffer, $encoding);
if (PHP_VERSION < 6) { set_magic_quotes_runtime($magic_quotes); }
return $file_buffer;
return '';
* Encodes string to requested format.
* @param string $str The text to encode
* @access public
* @return string
public function EncodeString ($str, $encoding = 'base64') {
$encoded = '';
switch(strtolower($encoding)) {
case 'base64':
$encoded = chunk_split(base64_encode($str), 76, $this->LE);
break;
case '7bit':
case '8bit':
$encoded = $this->FixEOL($str);
//Make sure it ends with a line break
if (substr($encoded, -(strlen($this->LE))) != $this->LE)
$encoded .= $this->LE;
break;
case 'binary':
$encoded = $str;
break;
case 'quoted-printable':
$encoded = $this->EncodeQP($str);
break;
default:
$this->SetError($this->Lang('encoding') . $encoding);
break;
return $encoded;
* Encode a header string to best (shortest) of Q, B, quoted or none.
* @access public
* @return string
public function EncodeHeader($str, $position = 'text') {
$x = 0;
switch (strtolower($position)) {
case 'phrase':
if (!preg_match('/[\200-\377]/', $str)) {
// Can't use addslashes as we don't know what value has magic_quotes_sybase
$encoded = addcslashes($str, "\0..\37\177\\\"");
if (($str == $encoded) && !preg_match('/[^A-Za-z0-9!#$%&\'*+\/=?^_`{|}~ -]/', $str)) {
return ($encoded);
} else {
return ("\"$encoded\"");
$x = preg_match_all('/[^\040\041\043-\133\135-\176]/', $str, $matches);
break;
case 'comment':
$x = preg_match_all('/[()"]/', $str, $matches);
// Fall-through
case 'text':
default:
$x += preg_match_all('/[\000-\010\013\014\016-\037\177-\377]/', $str, $matches);
break;
if ($x == 0) {
return ($str);
$maxlen = 75 - 7 - strlen($this->CharSet);
// Try to select the encoding which should produce the shortest output
if (strlen($str)/3 < $x) {
$encoding = 'B';
if (function_exists('mb_strlen') && $this->HasMultiBytes($str)) {
// Use a custom function which correctly encodes and wraps long
// multibyte strings without breaking lines within a character
$encoded = $this->Base64EncodeWrapMB($str);
} else {
$encoded = base64_encode($str);
$maxlen -= $maxlen % 4;
$encoded = trim(chunk_split($encoded, $maxlen, "\n"));
} else {
$encoding = 'Q';
$encoded = $this->EncodeQ($str, $position);
$encoded = $this->WrapText($encoded, $maxlen, true);
$encoded = str_replace('='.$this->LE, "\n", trim($encoded));
$encoded = preg_replace('/^(.*)$/m', " =?".$this->CharSet."?$encoding?\\1?=", $encoded);
$encoded = trim(str_replace("\n", $this->LE, $encoded));
return $encoded;
* Checks if a string contains multibyte characters.
* @access public
* @param string $str multi-byte text to wrap encode
* @return bool
public function HasMultiBytes($str) {
if (function_exists('mb_strlen')) {
return (strlen($str) > mb_strlen($str, $this->CharSet));
} else { // Assume no multibytes (we can't handle without mbstring functions anyway)
return false;
* Correctly encodes and wraps long multibyte strings for mail headers
* without breaking lines within a character.
* Adapted from a function by paravoid at http://uk.php.net/manual/en/function.mb-encode-mimeheader.php
* @access public
* @return string
public function Base64EncodeWrapMB($str) {
$start = "=?".$this->CharSet."?B?";
$end = "?=";
$encoded = "";
$mb_length = mb_strlen($str, $this->CharSet);
// Each line must have length <= 75, including $start and $end
$length = 75 - strlen($start) - strlen($end);
// Average multi-byte ratio
$ratio = $mb_length / strlen($str);
// Base64 has a 4:3 ratio
$offset = $avgLength = floor($length * $ratio * .75);
for ($i = 0; $i < $mb_length; $i += $offset) {
$lookBack = 0;
do {
$offset = $avgLength - $lookBack;
$chunk = mb_substr($str, $i, $offset, $this->CharSet);
$chunk = base64_encode($chunk);
$lookBack++;
while (strlen($chunk) > $length);
$encoded .= $chunk . $this->LE;
// Chomp the last linefeed
$encoded = substr($encoded, 0, -strlen($this->LE));
return $encoded;
* Encode string to quoted-printable.
* Only uses standard PHP, slow, but will always work
* @access public
* @param string $string the text to encode
* @param integer $line_max Number of chars allowed on a line before wrapping
* @return string
public function EncodeQPphp( $input = '', $line_max = 76, $space_conv = false) {
$hex = array('0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F');
$lines = preg_split('/(?:\r\n|\r|\n)/', $input);
$eol = "\r\n";
$escape = '=';
$output = '';
while( list(, $line) = each($lines) ) {
$linlen = strlen($line);
$newline = '';
for($i = 0; $i < $linlen; $i++) {
$c = substr( $line, $i, 1 );
$dec = ord( $c );
if ( ( $i == 0 ) && ( $dec == 46 ) ) { // convert first point in the line into =2E
$c = '=2E';
if ( $dec == 32 ) {
if ( $i == ( $linlen - 1 ) ) { // convert space at eol only
$c = '=20';
} else if ( $space_conv ) {
$c = '=20';
} elseif ( ($dec == 61) || ($dec < 32 ) || ($dec > 126) ) { // always encode "\t", which is *not* required
$h2 = floor($dec/16);
$h1 = floor($dec%16);
$c = $escape.$hex[$h2].$hex[$h1];
if ( (strlen($newline) + strlen($c)) >= $line_max ) { // CRLF is not counted
$output .= $newline.$escape.$eol; // soft line break; " =\r\n" is okay
$newline = '';
// check if newline first character will be point or not
if ( $dec == 46 ) {
$c = '=2E';
$newline .= $c;
} // end of for
$output .= $newline.$eol;
} // end of while
return $output;
* Encode string to RFC2045 (6.7) quoted-printable format
* Uses a PHP5 stream filter to do the encoding about 64x faster than the old version
* Also results in same content as you started with after decoding
* @see EncodeQPphp()
* @access public
* @param boolean $space_conv Dummy param for compatibility with existing EncodeQP function
* @return string
public function EncodeQP($string, $line_max = 76, $space_conv = false) {
if (function_exists('quoted_printable_encode')) { //Use native function if it's available (>= PHP5.3)
return quoted_printable_encode($string);
$filters = stream_get_filters();
if (!in_array('convert.*', $filters)) { //Got convert stream filter?
return $this->EncodeQPphp($string, $line_max, $space_conv); //Fall back to old implementation
$fp = fopen('php://temp/', 'r+');
$string = preg_replace('/\r\n?/', $this->LE, $string); //Normalise line breaks
$params = array('line-length' => $line_max, 'line-break-chars' => $this->LE);
$s = stream_filter_append($fp, 'convert.quoted-printable-encode', STREAM_FILTER_READ, $params);
fputs($fp, $string);
rewind($fp);
$out = stream_get_contents($fp);
stream_filter_remove($s);
$out = preg_replace('/^\./m', '=2E', $out); //Encode . if it is first char on a line, workaround for bug in Exchange
fclose($fp);
return $out;
* Encode string to q encoding.
* @link http://tools.ietf.org/html/rfc2047
* @param string $str the text to encode
* @param string $position Where the text is going to be used, see the RFC for what that means
* @access public
* @return string
public function EncodeQ ($str, $position = 'text') {
// There should not be any EOL in the string
$encoded = preg_replace('/[\r\n]*/', '', $str);
case 'phrase':
$encoded = preg_replace("/([^A-Za-z0-9!*+\/ -])/e", "'='.sprintf('%02X', ord('\\1'))", $encoded);
break;
case 'comment':
$encoded = preg_replace("/([\(\)\"])/e", "'='.sprintf('%02X', ord('\\1'))", $encoded);
case 'text':
default:
// Replace every high ascii, control =, ? and _ characters
//TODO using /e (equivalent to eval()) is probably not a good idea
$encoded = preg_replace('/([\000-\011\013\014\016-\037\075\077\137\177-\377])/e',
break;
// Replace every spaces to _ (more readable than =20)
$encoded = str_replace(' ', '_', $encoded);
return $encoded;
* Adds a string or binary attachment (non-filesystem) to the list.
* This method can be used to attach ascii or binary data,
* such as a BLOB record from a database.
* @param string $string String attachment data.
* @param string $filename Name of the attachment.
* @return void
public function AddStringAttachment($string, $filename, $encoding = 'base64', $type = 'application/octet-stream') {
// Append to $attachment array
0 => $string,
1 => $filename,
2 => basename($filename),
3 => $encoding,
4 => $type,
5 => true, // isStringAttachment
6 => 'attachment',
7 => 0
* Adds an embedded attachment. This can include images, sounds, and
* just about any other document. Make sure to set the $type to an
* image type. For JPEG images use "image/jpeg" and for GIF images
* use "image/gif".
* @param string $cid Content ID of the attachment. Use this to identify
* the Id for accessing the image in an HTML form.
* @return bool
public function AddEmbeddedImage($path, $cid, $name = '', $encoding = 'base64', $type = 'application/octet-stream') {
$this->SetError($this->Lang('file_access') . $path);
return false;
$name = $filename;
0 => $path,
1 => $filename,
2 => $name,
3 => $encoding,
4 => $type,
6 => 'inline',
7 => $cid
return true;
* Returns true if an inline attachment is present.
* @access public
* @return bool
public function InlineImageExists() {
foreach($this->attachment as $attachment) {
if ($attachment[6] == 'inline') {
return true;
return false;
* Clears all recipients assigned in the TO array. Returns void.
* @return void
public function ClearAddresses() {
unset($this->all_recipients[strtolower($to[0])]);
$this->to = array();
* Clears all recipients assigned in the CC array. Returns void.
* @return void
public function ClearCCs() {
unset($this->all_recipients[strtolower($cc[0])]);
$this->cc = array();
* Clears all recipients assigned in the BCC array. Returns void.
* @return void
public function ClearBCCs() {
unset($this->all_recipients[strtolower($bcc[0])]);
$this->bcc = array();
* Clears all recipients assigned in the ReplyTo array. Returns void.
* @return void
public function ClearReplyTos() {
$this->ReplyTo = array();
* Clears all recipients assigned in the TO, CC and BCC
* array. Returns void.
* @return void
public function ClearAllRecipients() {
$this->all_recipients = array();
* Clears all previously set filesystem, string, and binary
* attachments. Returns void.
* @return void
public function ClearAttachments() {
$this->attachment = array();
* Clears all custom headers. Returns void.
* @return void
public function ClearCustomHeaders() {
$this->CustomHeader = array();
// CLASS METHODS, MISCELLANEOUS
* Adds the error message to the error container.
* @access protected
* @return void
protected function SetError($msg) {
$this->error_count++;
if ($this->Mailer == 'smtp' and !is_null($this->smtp)) {
$lasterror = $this->smtp->getError();
if (!empty($lasterror) and array_key_exists('smtp_msg', $lasterror)) {
$msg .= '<p>' . $this->Lang('smtp_error') . $lasterror['smtp_msg'] . "</p>\n";
$this->ErrorInfo = $msg;
* Returns the proper RFC 822 formatted date.
* @access public
* @return string
* @static
public static function RFCDate() {
$tz = date('Z');
$tzs = ($tz < 0) ? '-' : '+';
$tz = abs($tz);
$tz = (int)($tz/3600)*100 + ($tz%3600)/60;
$result = sprintf("%s %s%04d", date('D, j M Y H:i:s'), $tzs, $tz);
return $result;
* Returns the server hostname or 'localhost.localdomain' if unknown.
* @access private
* @return string
private function ServerHostname() {
if (!empty($this->Hostname)) {
$result = $this->Hostname;
} elseif (isset($_SERVER['SERVER_NAME'])) {
$result = $_SERVER['SERVER_NAME'];
} else {
$result = 'localhost.localdomain';
return $result;
* Returns a message in the appropriate language.
* @access private
* @return string
private function Lang($key) {
if(count($this->language) < 1) {
$this->SetLanguage('en'); // set the default language
if(isset($this->language[$key])) {
return $this->language[$key];
} else {
return 'Language string failed to load: ' . $key;
* Returns true if an error occurred.
* @access public
* @return bool
public function IsError() {
return ($this->error_count > 0);
* Changes every end of line from CR or LF to CRLF.
* @access private
* @return string
private function FixEOL($str) {
$str = str_replace("\r\n", "\n", $str);
$str = str_replace("\r", "\n", $str);
$str = str_replace("\n", $this->LE, $str);
return $str;
* Adds a custom header.
* @access public
* @return void
public function AddCustomHeader($custom_header) {
$this->CustomHeader[] = explode(':', $custom_header, 2);
* Evaluates the message and returns modifications for inline images and backgrounds
* @access public
* @return $message
public function MsgHTML($message, $basedir = '') {
preg_match_all("/(src|background)=\"(.*)\"/Ui", $message, $images);
if(isset($images[2])) {
foreach($images[2] as $i => $url) {
// do not change urls for absolute images (thanks to corvuscorax)
if (!preg_match('#^[A-z]+://#',$url)) {
$filename = basename($url);
$directory = dirname($url);
($directory == '.')?$directory='':'';
$cid = 'cid:' . md5($filename);
$ext = pathinfo($filename, PATHINFO_EXTENSION);
$mimeType = self::_mime_types($ext);
if ( strlen($basedir) > 1 && substr($basedir,-1) != '/') { $basedir .= '/'; }
if ( strlen($directory) > 1 && substr($directory,-1) != '/') { $directory .= '/'; }
if ( $this->AddEmbeddedImage($basedir.$directory.$filename, md5($filename), $filename, 'base64',$mimeType) ) {
$message = preg_replace("/".$images[1][$i]."=\"".preg_quote($url, '/')."\"/Ui", $images[1][$i]."=\"".$cid."\"", $message);
$this->IsHTML(true);
$this->Body = $message;
$textMsg = trim(strip_tags(preg_replace('/<(head|title|style|script)[^>]*>.*?<\/\\1>/s','',$message)));
if (!empty($textMsg) && empty($this->AltBody)) {
$this->AltBody = html_entity_decode($textMsg);
if (empty($this->AltBody)) {
$this->AltBody = 'To view this email message, open it in a program that understands HTML!' . "\n\n";
* Gets the MIME type of the embedded or inline image
* @param string File extension
* @access public
* @return string MIME type of ext
* @static
public static function _mime_types($ext = '') {
$mimes = array(
'hqx' => 'application/mac-binhex40',
'cpt' => 'application/mac-compactpro',
'doc' => 'application/msword',
'bin' => 'application/macbinary',
'dms' => 'application/octet-stream',
'lha' => 'application/octet-stream',
'lzh' => 'application/octet-stream',
'exe' => 'application/octet-stream',
'class' => 'application/octet-stream',
'psd' => 'application/octet-stream',
'so' => 'application/octet-stream',
'sea' => 'application/octet-stream',
'dll' => 'application/octet-stream',
'oda' => 'application/oda',
'pdf' => 'application/pdf',
'ai' => 'application/postscript',
'eps' => 'application/postscript',
'ps' => 'application/postscript',
'smi' => 'application/smil',
'smil' => 'application/smil',
'mif' => 'application/vnd.mif',
'xls' => 'application/vnd.ms-excel',
'ppt' => 'application/vnd.ms-powerpoint',
'wbxml' => 'application/vnd.wap.wbxml',
'wmlc' => 'application/vnd.wap.wmlc',
'dcr' => 'application/x-director',
'dir' => 'application/x-director',
'dxr' => 'application/x-director',
'dvi' => 'application/x-dvi',
'gtar' => 'application/x-gtar',
'php' => 'application/x-httpd-php',
'php4' => 'application/x-httpd-php',
'php3' => 'application/x-httpd-php',
'phtml' => 'application/x-httpd-php',
'phps' => 'application/x-httpd-php-source',
'js' => 'application/x-javascript',
'swf' => 'application/x-shockwave-flash',
'sit' => 'application/x-stuffit',
'tar' => 'application/x-tar',
'tgz' => 'application/x-tar',
'xhtml' => 'application/xhtml+xml',
'xht' => 'application/xhtml+xml',
'zip' => 'application/zip',
'mid' => 'audio/midi',
'midi' => 'audio/midi',
'mpga' => 'audio/mpeg',
'mp2' => 'audio/mpeg',
'mp3' => 'audio/mpeg',
'aif' => 'audio/x-aiff',
'aiff' => 'audio/x-aiff',
'aifc' => 'audio/x-aiff',
'ram' => 'audio/x-pn-realaudio',
'rm' => 'audio/x-pn-realaudio',
'rpm' => 'audio/x-pn-realaudio-plugin',
'ra' => 'audio/x-realaudio',
'rv' => 'video/vnd.rn-realvideo',
'wav' => 'audio/x-wav',
'bmp' => 'image/bmp',
'gif' => 'image/gif',
'jpeg' => 'image/jpeg',
'jpg' => 'image/jpeg',
'jpe' => 'image/jpeg',
'png' => 'image/png',
'tiff' => 'image/tiff',
'tif' => 'image/tiff',
'css' => 'text/css',
'html' => 'text/html',
'htm' => 'text/html',
'shtml' => 'text/html',
'txt' => 'text/plain',
'text' => 'text/plain',
'log' => 'text/plain',
'rtx' => 'text/richtext',
'rtf' => 'text/rtf',
'xml' => 'text/xml',
'xsl' => 'text/xml',
'mpeg' => 'video/mpeg',
'mpg' => 'video/mpeg',
'mpe' => 'video/mpeg',
'qt' => 'video/quicktime',
'mov' => 'video/quicktime',
'avi' => 'video/x-msvideo',
'movie' => 'video/x-sgi-movie',
'word' => 'application/msword',
'xl' => 'application/excel',
'eml' => 'message/rfc822'
return (!isset($mimes[strtolower($ext)])) ? 'application/octet-stream' : $mimes[strtolower($ext)];
* Set (or reset) Class Objects (variables)
* Usage Example:
* $page->set('X-Priority', '3');
* @access public
* @param string $name Parameter Name
* @param mixed $value Parameter Value
* NOTE: will not work with arrays, there are no arrays to set/reset
* @todo Should this not be using __set() magic function?
public function set($name, $value = '') {
try {
if (isset($this->$name) ) {
$this->$name = $value;
} else {
throw new phpmailerException($this->Lang('variable_set') . $name, self::STOP_CRITICAL);
if ($e->getCode() == self::STOP_CRITICAL) {
return false;
return true;
* Strips newlines to prevent header injection.
* @access public
* @param string $str String
* @return string
public function SecureHeader($str) {
$str = str_replace("\r", '', $str);
$str = str_replace("\n", '', $str);
return trim($str);
* Set the private key file and password to sign the message.
* @access public
* @param string $key_filename Parameter File Name
* @param string $key_pass Password for private key
public function Sign($cert_filename, $key_filename, $key_pass) {
$this->sign_cert_file = $cert_filename;
$this->sign_key_file = $key_filename;
$this->sign_key_pass = $key_pass;
* @access public
public function DKIM_QP($txt) {
$tmp="";
$line="";
for ($i=0;$i<strlen($txt);$i++) {
$ord=ord($txt[$i]);
if ( ((0x21 <= $ord) && ($ord <= 0x3A)) || $ord == 0x3C || ((0x3E <= $ord) && ($ord <= 0x7E)) ) {
$line.=$txt[$i];
} else {
$line.="=".sprintf("%02X",$ord);
return $line;
* Generate DKIM signature
* @access public
* @param string $s Header
public function DKIM_Sign($s) {
$privKeyStr = file_get_contents($this->DKIM_private);
if ($this->DKIM_passphrase!='') {
$privKey = openssl_pkey_get_private($privKeyStr,$this->DKIM_passphrase);
} else {
$privKey = $privKeyStr;
if (openssl_sign($s, $signature, $privKey)) {
return base64_encode($signature);
* Generate DKIM Canonicalization Header
* @access public
public function DKIM_HeaderC($s) {
$s=preg_replace("/\r\n\s+/"," ",$s);
$lines=explode("\r\n",$s);
foreach ($lines as $key=>$line) {
list($heading,$value)=explode(":",$line,2);
$heading=strtolower($heading);
$value=preg_replace("/\s+/"," ",$value) ; // Compress useless spaces
$lines[$key]=$heading.":".trim($value) ; // Don't forget to remove WSP around the value
$s=implode("\r\n",$lines);
return $s;
* Generate DKIM Canonicalization Body
* @access public
* @param string $body Message Body
public function DKIM_BodyC($body) {
if ($body == '') return "\r\n";
// stabilize line endings
$body=str_replace("\r\n","\n",$body);
$body=str_replace("\n","\r\n",$body);
// END stabilize line endings
while (substr($body,strlen($body)-4,4) == "\r\n\r\n") {
$body=substr($body,0,strlen($body)-2);
return $body;
* Create the DKIM header, body, as new header
* @access public
* @param string $headers_line Header lines
* @param string $subject Subject
* @param string $body Body
public function DKIM_Add($headers_line,$subject,$body) {
$DKIMsignatureType = 'rsa-sha1'; // Signature & hash algorithms
$DKIMcanonicalization = 'relaxed/simple'; // Canonicalization of header/body
$DKIMquery = 'dns/txt'; // Query method
$DKIMtime = time() ; // Signature Timestamp = seconds since 00:00:00 - Jan 1, 1970 (UTC time zone)
$subject_header = "Subject: $subject";
$headers = explode("\r\n",$headers_line);
foreach($headers as $header) {
if (strpos($header,'From:') === 0) {
$from_header=$header;
} elseif (strpos($header,'To:') === 0) {
$to_header=$header;
$from = str_replace('|','=7C',$this->DKIM_QP($from_header));
$to = str_replace('|','=7C',$this->DKIM_QP($to_header));
$subject = str_replace('|','=7C',$this->DKIM_QP($subject_header)) ; // Copied header fields (dkim-quoted-printable
$body = $this->DKIM_BodyC($body);
$DKIMlen = strlen($body) ; // Length of body
$DKIMb64 = base64_encode(pack("H*", sha1($body))) ; // Base64 of packed binary SHA-1 hash of body
$ident = ($this->DKIM_identity == '')? '' : " i=" . $this->DKIM_identity . ";";
$dkimhdrs = "DKIM-Signature: v=1; a=" . $DKIMsignatureType . "; q=" . $DKIMquery . "; l=" . $DKIMlen . "; s=" . $this->DKIM_selector . ";\r\n".
"\tt=" . $DKIMtime . "; c=" . $DKIMcanonicalization . ";\r\n".
"\th=From:To:Subject;\r\n".
"\td=" . $this->DKIM_domain . ";" . $ident . "\r\n".
"\tz=$from\r\n".
"\t|$to\r\n".
"\t|$subject;\r\n".
"\tbh=" . $DKIMb64 . ";\r\n".
"\tb=";
$toSign = $this->DKIM_HeaderC($from_header . "\r\n" . $to_header . "\r\n" . $subject_header . "\r\n" . $dkimhdrs);
$signed = $this->DKIM_Sign($toSign);
return "X-PHPMAILER-DKIM: phpmailer.worxware.com\r\n".$dkimhdrs.$signed."\r\n";
protected function doCallback($isSent,$to,$cc,$bcc,$subject,$body) {
if (!empty($this->action_function) && function_exists($this->action_function)) {
$params = array($isSent,$to,$cc,$bcc,$subject,$body);
call_user_func_array($this->action_function,$params);
class phpmailerException extends Exception {
public function errorMessage() {
$errorMsg = '<strong>' . $this->getMessage() . "</strong><br />\n";
return $errorMsg;
/*~ class.smtp.php
* PHPMailer - PHP SMTP email transport class
* NOTE: Designed for use with PHP version 5 and up
* @copyright 2004 - 2008 Andy Prevost
* @license http://www.gnu.org/copyleft/lesser.html Distributed under the Lesser General Public License (LGPL)
* @version $Id: class.smtp.php 444 2009-05-05 11:22:26Z coolbru $
* SMTP is rfc 821 compliant and implements all the rfc 821 SMTP
* commands except TURN which will always return a not implemented
* error. SMTP also provides some utility methods for sending mail
* to an SMTP server.
* original author: Chris Ryan
class SMTP {
* SMTP server port
* @var int
public $SMTP_PORT = 25;
* SMTP reply line ending
* @var string
public $CRLF = "\r\n";
* Sets whether debugging is turned on
* @var bool
public $do_debug; // the level of debug to perform
* Sets VERP use on/off (default is off)
* @var bool
public $do_verp = false;
private $smtp_conn; // the socket to the server
private $error; // error if any on the last call
private $helo_rply; // the reply the server sent to us for HELO
* Initialize the class so that the data is in a known state.
* @access public
* @return void
public function __construct() {
$this->smtp_conn = 0;
$this->error = null;
$this->helo_rply = null;
$this->do_debug = 0;
* Connect to the server specified on the port specified.
* If the port is not specified use the default SMTP_PORT.
* If tval is specified then a connection will try and be
* established with the server for that number of seconds.
* If tval is not specified the default is 30 seconds to
* try on the connection.
* SMTP CODE SUCCESS: 220
* SMTP CODE FAILURE: 421
* @access public
* @return bool
public function Connect($host, $port = 0, $tval = 30) {
// set the error val to null so there is no confusion
// make sure we are __not__ connected
if($this->connected()) {
// already connected, generate error
$this->error = array("error" => "Already connected to a server");
return false;
if(empty($port)) {
$port = $this->SMTP_PORT;
// connect to the smtp server
$this->smtp_conn = @fsockopen($host, // the host of the server
$port, // the port to use
$errno, // error number if any
$errstr, // error message if any
$tval); // give up after ? secs
// verify we connected properly
if(empty($this->smtp_conn)) {
$this->error = array("error" => "Failed to connect to server",
"errno" => $errno,
"errstr" => $errstr);
if($this->do_debug >= 1) {
echo "SMTP -> ERROR: " . $this->error["error"] . ": $errstr ($errno)" . $this->CRLF . '<br />';
return false;
// SMTP server can take longer to respond, give longer timeout for first read
// Windows does not have support for this timeout function
if(substr(PHP_OS, 0, 3) != "WIN")
socket_set_timeout($this->smtp_conn, $tval, 0);
// get any announcement
$announce = $this->get_lines();
if($this->do_debug >= 2) {
echo "SMTP -> FROM SERVER:" . $announce . $this->CRLF . '<br />';
return true;
* Initiate a TLS communication with the server.
* SMTP CODE 220 Ready to start TLS
* SMTP CODE 501 Syntax error (no parameters allowed)
* SMTP CODE 454 TLS not available due to temporary reason
* @access public
* @return bool success
public function StartTLS() {
$this->error = null; # to avoid confusion
if(!$this->connected()) {
$this->error = array("error" => "Called StartTLS() without being connected");
return false;
fputs($this->smtp_conn,"STARTTLS" . $this->CRLF);
$rply = $this->get_lines();
$code = substr($rply,0,3);
echo "SMTP -> FROM SERVER:" . $rply . $this->CRLF . '<br />';
if($code != 220) {
$this->error =
array("error" => "STARTTLS not accepted from server",
"smtp_code" => $code,
"smtp_msg" => substr($rply,4));
echo "SMTP -> ERROR: " . $this->error["error"] . ": " . $rply . $this->CRLF . '<br />';
return false;
// Begin encrypted connection
if(!stream_socket_enable_crypto($this->smtp_conn, true, STREAM_CRYPTO_METHOD_TLS_CLIENT)) {
return false;
return true;
* Performs SMTP authentication. Must be run after running the
* Hello() method. Returns true if successfully authenticated.
* @access public
* @return bool
public function Authenticate($username, $password) {
// Start authentication
fputs($this->smtp_conn,"AUTH LOGIN" . $this->CRLF);
if($code != 334) {
$this->error =
array("error" => "AUTH not accepted from server",
return false;
// Send encoded username
fputs($this->smtp_conn, base64_encode($username) . $this->CRLF);
if($code != 334) {
$this->error =
array("error" => "Username not accepted from server",
return false;
// Send encoded password
fputs($this->smtp_conn, base64_encode($password) . $this->CRLF);
if($code != 235) {
$this->error =
array("error" => "Password not accepted from server",
return false;
return true;
* Returns true if connected to a server otherwise false
* @access public
* @return bool
public function Connected() {
if(!empty($this->smtp_conn)) {
$sock_status = socket_get_status($this->smtp_conn);
if($sock_status["eof"]) {
// the socket is valid but we are not connected
echo "SMTP -> NOTICE:" . $this->CRLF . "EOF caught while checking if connected";
$this->Close();
return false;
return true; // everything looks good
return false;
* Closes the socket and cleans up the state of the class.
* It is not considered good to use this function without
* first trying to use QUIT.
* @access public
* @return void
public function Close() {
$this->error = null; // so there is no confusion
// close the connection and cleanup
fclose($this->smtp_conn);
* Issues a data command and sends the msg_data to the server
* finializing the mail transaction. $msg_data is the message
* that is to be send with the headers. Each header needs to be
* on a single line followed by a <CRLF> with the message headers
* and the message body being seperated by and additional <CRLF>.
* Implements rfc 821: DATA <CRLF>
* SMTP CODE INTERMEDIATE: 354
* [data]
* <CRLF>.<CRLF>
* SMTP CODE SUCCESS: 250
* SMTP CODE FAILURE: 552,554,451,452
* SMTP CODE FAILURE: 451,554
* SMTP CODE ERROR : 500,501,503,421
* @access public
* @return bool
public function Data($msg_data) {
$this->error = null; // so no confusion is caused
"error" => "Called Data() without being connected");
return false;
fputs($this->smtp_conn,"DATA" . $this->CRLF);
if($code != 354) {
$this->error =
array("error" => "DATA command not accepted from server",
return false;
/* the server is ready to accept data!
* according to rfc 821 we should not send more than 1000
* including the CRLF
* characters on a single line so we will break the data up
* into lines by \r and/or \n then if needed we will break
* each of those into smaller lines to fit within the limit.
* in addition we will be looking for lines that start with
* a period '.' and append and additional period '.' to that
* line. NOTE: this does not count towards limit.
// normalize the line breaks so we know the explode works
$msg_data = str_replace("\r\n","\n",$msg_data);
$msg_data = str_replace("\r","\n",$msg_data);
$lines = explode("\n",$msg_data);
/* we need to find a good way to determine is headers are
* in the msg_data or if it is a straight msg body
* currently I am assuming rfc 822 definitions of msg headers
* and if the first field of the first line (':' sperated)
* does not contain a space then it _should_ be a header
* and we can process all lines before a blank "" line as
* headers.
$field = substr($lines[0],0,strpos($lines[0],":"));
$in_headers = false;
if(!empty($field) && !strstr($field," ")) {
$in_headers = true;
$max_line_length = 998; // used below; set here for ease in change
while(list(,$line) = @each($lines)) {
$lines_out = null;
if($line == "" && $in_headers) {
// ok we need to break this line up into several smaller lines
while(strlen($line) > $max_line_length) {
$pos = strrpos(substr($line,0,$max_line_length)," ");
// Patch to fix DOS attack
if(!$pos) {
$pos = $max_line_length - 1;
$lines_out[] = substr($line,0,$pos);
$line = substr($line,$pos);
} else {
$line = substr($line,$pos + 1);
/* if processing headers add a LWSP-char to the front of new line
* rfc 822 on long msg headers
if($in_headers) {
$line = "\t" . $line;
$lines_out[] = $line;
// send the lines to the server
while(list(,$line_out) = @each($lines_out)) {
if(strlen($line_out) > 0)
if(substr($line_out, 0, 1) == ".") {
$line_out = "." . $line_out;
fputs($this->smtp_conn,$line_out . $this->CRLF);
// message data has been sent
fputs($this->smtp_conn, $this->CRLF . "." . $this->CRLF);
if($code != 250) {
$this->error =
array("error" => "DATA not accepted from server",
return false;
return true;
* Sends the HELO command to the smtp server.
* This makes sure that we and the server are in
* the same known state.
* Implements from rfc 821: HELO <SP> <domain> <CRLF>
* SMTP CODE ERROR : 500, 501, 504, 421
* @access public
* @return bool
public function Hello($host = '') {
"error" => "Called Hello() without being connected");
return false;
// if hostname for HELO was not specified send default
if(empty($host)) {
// determine appropriate default to send to server
$host = "localhost";
// Send extended hello first (RFC 2821)
if(!$this->SendHello("EHLO", $host)) {
if(!$this->SendHello("HELO", $host)) {
return false;
return true;
* Sends a HELO/EHLO command.
* @access private
* @return bool
private function SendHello($hello, $host) {
fputs($this->smtp_conn, $hello . " " . $host . $this->CRLF);
echo "SMTP -> FROM SERVER: " . $rply . $this->CRLF . '<br />';
if($code != 250) {
$this->error =
array("error" => $hello . " not accepted from server",
return false;
$this->helo_rply = $rply;
return true;
* Starts a mail transaction from the email address specified in
* $from. Returns true if successful or false otherwise. If True
* the mail transaction is started and then one or more Recipient
* commands may be called followed by a Data command.
* Implements rfc 821: MAIL <SP> FROM:<reverse-path> <CRLF>
* SMTP CODE SUCCESS: 552,451,452
* SMTP CODE SUCCESS: 500,501,421
* @access public
* @return bool
public function Mail($from) {
"error" => "Called Mail() without being connected");
return false;
$useVerp = ($this->do_verp ? "XVERP" : "");
fputs($this->smtp_conn,"MAIL FROM:<" . $from . ">" . $useVerp . $this->CRLF);
if($code != 250) {
$this->error =
array("error" => "MAIL not accepted from server",
return false;
return true;
* Sends the quit command to the server and then closes the socket
* if there is no error or the $close_on_error argument is true.
* Implements from rfc 821: QUIT <CRLF>
* SMTP CODE SUCCESS: 221
* @access public
* @return bool
public function Quit($close_on_error = true) {
"error" => "Called Quit() without being connected");
return false;
// send the quit command to the server
fputs($this->smtp_conn,"quit" . $this->CRLF);
// get any good-bye messages
$byemsg = $this->get_lines();
echo "SMTP -> FROM SERVER:" . $byemsg . $this->CRLF . '<br />';
$rval = true;
$e = null;
$code = substr($byemsg,0,3);
if($code != 221) {
// use e as a tmp var cause Close will overwrite $this->error
$e = array("error" => "SMTP server rejected quit command",
"smtp_rply" => substr($byemsg,4));
$rval = false;
echo "SMTP -> ERROR: " . $e["error"] . ": " . $byemsg . $this->CRLF . '<br />';
if(empty($e) || $close_on_error) {
$this->Close();
return $rval;
* Sends the command RCPT to the SMTP server with the TO: argument of $to.
* Returns true if the recipient was accepted false if it was rejected.
* Implements from rfc 821: RCPT <SP> TO:<forward-path> <CRLF>
* SMTP CODE SUCCESS: 250,251
* SMTP CODE FAILURE: 550,551,552,553,450,451,452
* @access public
* @return bool
public function Recipient($to) {
"error" => "Called Recipient() without being connected");
return false;
fputs($this->smtp_conn,"RCPT TO:<" . $to . ">" . $this->CRLF);
if($code != 250 && $code != 251) {
$this->error =
array("error" => "RCPT not accepted from server",
return false;
return true;
* Sends the RSET command to abort and transaction that is
* currently in progress. Returns true if successful false
* otherwise.
* Implements rfc 821: RSET <CRLF>
* SMTP CODE ERROR : 500,501,504,421
* @access public
* @return bool
public function Reset() {
"error" => "Called Reset() without being connected");
return false;
fputs($this->smtp_conn,"RSET" . $this->CRLF);
if($code != 250) {
$this->error =
array("error" => "RSET failed",
return false;
return true;
* commands may be called followed by a Data command. This command
* will send the message to the users terminal if they are logged
* in and send them an email.
* Implements rfc 821: SAML <SP> FROM:<reverse-path> <CRLF>
* SMTP CODE SUCCESS: 500,501,502,421
* @access public
* @return bool
public function SendAndMail($from) {
"error" => "Called SendAndMail() without being connected");
return false;
fputs($this->smtp_conn,"SAML FROM:" . $from . $this->CRLF);
if($code != 250) {
$this->error =
array("error" => "SAML not accepted from server",
return false;
return true;
* This is an optional command for SMTP that this class does not
* support. This method is here to make the RFC821 Definition
* complete for this class and __may__ be implimented in the future
* Implements from rfc 821: TURN <CRLF>
* SMTP CODE FAILURE: 502
* SMTP CODE ERROR : 500, 503
* @access public
* @return bool
public function Turn() {
$this->error = array("error" => "This method, TURN, of the SMTP ".
"is not implemented");
echo "SMTP -> NOTICE: " . $this->error["error"] . $this->CRLF . '<br />';
return false;
* Get the current error
* @access public
* @return array
public function getError() {
return $this->error;
* Read in as many lines as possible
* either before eof or socket timeout occurs on the operation.
* With SMTP we can tell if we have more lines to read if the
* 4th character is '-' symbol. If it is a space then we don't
* need to read anything else.
* @access private
* @return string
private function get_lines() {
$data = "";
while($str = @fgets($this->smtp_conn,515)) {
if($this->do_debug >= 4) {
echo "SMTP -> get_lines(): \$data was \"$data\"" . $this->CRLF . '<br />';
echo "SMTP -> get_lines(): \$str is \"$str\"" . $this->CRLF . '<br />';
$data .= $str;
echo "SMTP -> get_lines(): \$data is \"$data\"" . $this->CRLF . '<br />';
// if 4th character is a space, we are done reading, break the loop
if(substr($str,3,1) == " ") { break; }
return $data;
