Beste helper is het mogelijk om deze code korter te schrijven.
En hoe zou deze er dan uit zien"
Private Sub KoeliisendemperInCombobox_Change()
Select Case KoeliisendemperInCombobox.Text
Case "ZT.200.80-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 1
Case "ZT.200.80-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 2
Case "ZT.200.80-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 3
Case "ZT.200.80-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 4
Case "ZT.200.80-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 5
Case "ZT.200.80-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 6
Case "ZT.200.80-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 7
Case "ZT.200.80-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 8
Case "ZT.200.80-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 9
Case "ZT.200.100-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 10
Case "ZT.200.100-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 11
Case "ZT.200.100-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 12
Case "ZT.200.100-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 13
Case "ZT.200.100-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 14
Case "ZT.200.100-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 15
Case "ZT.200.100-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 16
Case "ZT.200.100-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 17
Case "ZT.200.100-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 18
Case "ZT.200.120-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 19
Case "ZT.200.120-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 20
Case "ZT.200.120-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 21
Case "ZT.200.120-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 22
Case "ZT.200.120-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 23
Case "ZT.200.120-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 24
Case "ZT.200.120-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 25
Case "ZT.200.120-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 26
Case "ZT.200.120-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 27
Case "ZT.200.140-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 28
Case "ZT.200.140-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 29
Case "ZT.200.140-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 30
Case "ZT.200.140-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 31
Case "ZT.200.140-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 32
Case "ZT.200.140-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 33
Case "ZT.200.140-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 34
Case "ZT.200.140-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 35
Case "ZT.200.140-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 36
Case "ZT.200.160-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 37
Case "ZT.200.160-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 38
Case "ZT.200.160-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 39
Case "ZT.200.160-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 40
Case "ZT.200.160-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 41
Case "ZT.200.160-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 42
Case "ZT.200.160-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 43
Case "ZT.200.160-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 44
Case "ZT.200.160-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 45
Case "ZT.200.180-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 46
Case "ZT.200.180-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 47
Case "ZT.200.180-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 48
Case "ZT.200.180-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 49
Case "ZT.200.180-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 50
Case "ZT.200.180-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 51
Case "ZT.200.180-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 52
Case "ZT.200.180-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 53
Case "ZT.200.180-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 54
Case "ZT.200.200-500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 55
Case "ZT.200.200-750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 56
Case "ZT.200.200-1000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 57
Case "ZT.200.200-1250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 58
Case "ZT.200.200-1500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 59
Case "ZT.200.200-1750"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 60
Case "ZT.200.200-2000"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 61
Case "ZT.200.200-2250"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 62
Case "ZT.200.200-2500"
Sheets("AIRFLOW 1 SET").Range("koelzoek") = 63
End Select
