PhpMyAdmin
Atwist
24 jan 2006
Wndows 11
Ik heb op mijn server net PHPMyAdmin geinstalleerd maar als ik localhost/phpmyadmin doe dan krijg ik onderstaande te zien.
Heb geen idee wat er fout is, heb al vaker met phpmyadmin gewerkt dus daar kan het niet aan liggen dit keer.:D:D:D
Dit zou het startscherm moeten zijn.
addJSON( 'list', PMA_RecentFavoriteTable::getInstance('recent')->getHtmlList() ); exit; } if ($GLOBALS['PMA_Config']->isGitRevision()) { if (isset($_REQUEST['git_revision']) && $GLOBALS['is_ajax_request'] == true) { PMA_printGitRevision(); exit; } echo '
'; } // Handles some variables that may have been sent by the calling script $GLOBALS['db'] = ''; $GLOBALS['table'] = ''; $show_query = '1'; // Any message to display? if (! empty($message)) { echo PMA_Util::getMessage($message); unset($message); } $common_url_query = PMA_URL_getCommon(); $mysql_cur_user_and_host = ''; // when $server > 0, a server has been chosen so we can display // all MySQL-related information if ($server > 0) { include 'libraries/server_common.inc.php'; include 'libraries/StorageEngine.class.php'; // Use the verbose name of the server instead of the hostname // if a value is set $server_info = ''; if (! empty($cfg['Server']['verbose'])) { $server_info .= htmlspecialchars($cfg['Server']['verbose']); if ($GLOBALS['cfg']['ShowServerInfo']) { $server_info .= ' ('; } } if ($GLOBALS['cfg']['ShowServerInfo'] || empty($cfg['Server']['verbose'])) { $server_info .= $GLOBALS['dbi']->getHostInfo(); } if (! empty($cfg['Server']['verbose']) && $GLOBALS['cfg']['ShowServerInfo']) { $server_info .= ')'; } $mysql_cur_user_and_host = $GLOBALS['dbi']->fetchValue('SELECT USER();'); // should we add the port info here? $short_server_info = (!empty($GLOBALS['cfg']['Server']['verbose']) ? $GLOBALS['cfg']['Server']['verbose'] : $GLOBALS['cfg']['Server']['host']); } echo '
' . "\n"; // Anchor for favorite tables synchronization. echo PMA_RecentFavoriteTable::getInstance('favorite')->getHtmlSyncFavoriteTables(); echo '
'; if ($server > 0 || count($cfg['Servers']) > 1 ) { if ($cfg['DBG']['demo']) { echo '
'; echo '
' . __('phpMyAdmin Demo Server') . '
'; echo '
'; printf( __( 'You are using the demo server. You can do anything here, but ' . 'please do not change root, debian-sys-maint and pma users. ' . 'More information is available at %s.' ), 'demo.phpmyadmin.net' ); echo '
'; echo '
'; } echo '
'; echo '
' . __('General settings') . '
'; echo '
    '; /** * Displays the MySQL servers choice form */ if ($cfg['ServerDefault'] == 0 || (! $cfg['NavigationDisplayServers'] && (count($cfg['Servers']) > 1 || ($server == 0 && count($cfg['Servers']) == 1))) ) { echo '
    '; include_once 'libraries/select_server.lib.php'; echo PMA_Util::getImage('s_host.png') . " " . PMA_selectServer(true, true); echo '
    '; } /** * Displays the mysql server related links */ if ($server > 0 && ! PMA_DRIZZLE) { include_once 'libraries/check_user_privileges.lib.php'; // Logout for advanced authentication if ($cfg['Server']['auth_type'] != 'config') { if ($cfg['ShowChgPassword']) { $conditional_class = 'ajax'; PMA_printListItem( PMA_Util::getImage('s_passwd.png') . " " . __('Change password'), 'li_change_password', 'user_password.php' . $common_url_query, null, null, 'change_password_anchor', "no_bullets", $conditional_class ); } } // end if echo '
    '; echo '
    ' . "\n" . PMA_URL_getHiddenInputs(null, null, 4, 'collation_connection') . ' ' . "\n" . ' ' . PMA_Util::getImage('s_asci.png') . " " . __('Server connection collation') . "\n" // put the doc link in the form so that it appears on the same line . PMA_Util::showMySQLDocu('Charset-connection') . ': ' . "\n" . ' ' . "\n" . PMA_generateCharsetDropdownBox( PMA_CSDROPDOWN_COLLATION, 'collation_connection', 'select_collation_connection', $collation_connection, true, true ) . '
    ' . "\n" . '
    ' . "\n"; } // end of if ($server > 0 && !PMA_DRIZZLE) echo '
'; echo '
'; } echo '
'; echo '
' . __('Appearance settings') . '
'; echo '
    '; // Displays language selection combo if (empty($cfg['Lang']) && count($GLOBALS['available_languages']) > 1) { echo '
    '; include_once 'libraries/display_select_lang.lib.php'; echo PMA_Util::getImage('s_lang.png') . " " . PMA_getLanguageSelectorHtml(); echo '
    '; } // ThemeManager if available if ($GLOBALS['cfg']['ThemeManager']) { echo '
    '; echo PMA_Util::getImage('s_theme.png') . " " . $_SESSION['PMA_Theme_Manager']->getHtmlSelectBox(); echo '
    '; } echo '
    '; echo PMA_Config::getFontsizeForm(); echo '
    '; echo '
'; // User preferences if ($server > 0) { echo '
    '; PMA_printListItem( PMA_Util::getImage('b_tblops.png') . " " . __('More settings'), 'li_user_preferences', 'prefs_manage.php' . $common_url_query, null, null, null, "no_bullets" ); echo '
'; } echo '
'; echo '
'; echo '
'; if ($server > 0 && $GLOBALS['cfg']['ShowServerInfo']) { echo '
'; echo '
' . __('Database server') . '
'; echo '
    ' . "\n"; PMA_printListItem( __('Server:') . ' ' . $server_info, 'li_server_info' ); PMA_printListItem( __('Server type:') . ' ' . PMA_Util::getServerType(), 'li_server_type' ); PMA_printListItem( __('Server version:') . ' ' . PMA_MYSQL_STR_VERSION . ' - ' . PMA_MYSQL_VERSION_COMMENT, 'li_server_version' ); PMA_printListItem( __('Protocol version:') . ' ' . $GLOBALS['dbi']->getProtoInfo(), 'li_mysql_proto' ); PMA_printListItem( __('User:') . ' ' . htmlspecialchars($mysql_cur_user_and_host), 'li_user_info' ); echo '
    '; echo ' ' . __('Server charset:') . ' ' . ' '; if (! PMA_DRIZZLE) { echo ' ' . $mysql_charsets_descriptions[$mysql_charset_map['utf-8']]; } echo ' (' . $mysql_charset_map['utf-8'] . ')' . ' ' . '
'; } if ($GLOBALS['cfg']['ShowServerInfo'] || $GLOBALS['cfg']['ShowPhpInfo']) { echo '
'; echo '
' . __('Web server') . '
'; echo '
    '; if ($GLOBALS['cfg']['ShowServerInfo']) { PMA_printListItem($_SERVER['SERVER_SOFTWARE'], 'li_web_server_software'); if ($server > 0) { $client_version_str = $GLOBALS['dbi']->getClientInfo(); if (preg_match('#\d+\.\d+\.\d+#', $client_version_str)) { $client_version_str = 'libmysql - ' . $client_version_str; } PMA_printListItem( __('Database client version:') . ' ' . $client_version_str, 'li_mysql_client_version' ); $php_ext_string = __('PHP extension:') . ' '; if (PMA_DatabaseInterface::checkDbExtension('mysqli')) { $extension = 'mysqli'; } else { $extension = 'mysql'; } $php_ext_string .= $extension . ' ' . PMA_Util::showPHPDocu('book.' . $extension . '.php'); PMA_printListItem( $php_ext_string, 'li_used_php_extension' ); $php_version_string = __('PHP version:') . ' ' . phpversion(); PMA_printListItem( $php_version_string, 'li_used_php_version' ); } } if ($cfg['ShowPhpInfo']) { PMA_printListItem( __('Show PHP information'), 'li_phpinfo', 'phpinfo.php' . $common_url_query, null, '_blank' ); } echo '
'; echo '
'; } echo '
'; echo '
phpMyAdmin
'; echo '
    '; $class = null; // We rely on CSP to allow access to http://www.phpmyadmin.net, but IE lacks // support here and does not allow request to http once using https. if ($GLOBALS['cfg']['VersionCheck'] && (! $GLOBALS['PMA_Config']->get('is_https') || PMA_USR_BROWSER_AGENT != 'IE') ) { $class = 'jsversioncheck'; } PMA_printListItem( __('Version information:') . ' ' . PMA_VERSION . '', 'li_pma_version', null, null, null, null, $class ); PMA_printListItem( __('Documentation'), 'li_pma_docs', PMA_Util::getDocuLink('index'), null, '_blank' ); PMA_printListItem( __('Wiki'), 'li_pma_wiki', PMA_linkURL('http://wiki.phpmyadmin.net/'), null, '_blank' ); // does not work if no target specified, don't know why PMA_printListItem( __('Official Homepage'), 'li_pma_homepage', PMA_linkURL('http://www.phpMyAdmin.net/'), null, '_blank' ); PMA_printListItem( __('Contribute'), 'li_pma_contribute', PMA_linkURL('https://www.phpmyadmin.net/contribute/'), null, '_blank' ); PMA_printListItem( __('Get support'), 'li_pma_support', PMA_linkURL('https://www.phpmyadmin.net/support/'), null, '_blank' ); PMA_printListItem( __('List of changes'), 'li_pma_changes', 'changelog.php' . PMA_URL_getCommon(), null, '_blank' ); echo '
'; echo '
'; echo '
'; echo '
'; /** * Warning if using the default MySQL privileged account */ if ($server != 0 && $cfg['Server']['user'] == 'root' && $cfg['Server']['password'] == '' ) { trigger_error( __( 'You are connected as \'root\' with no password, which' . ' corresponds to the default MySQL privileged account.' . ' Your MySQL server is running with this default, is open to' . ' intrusion, and you really should fix this security hole by' . ' setting a password for user \'root\'.' ), E_USER_WARNING ); } /** * As we try to handle charsets by ourself, mbstring overloads just * break it, see bug 1063821. */ if (@extension_loaded('mbstring') && @ini_get('mbstring.func_overload') > 1) { trigger_error( __( 'You have enabled mbstring.func_overload in your PHP ' . 'configuration. This option is incompatible with phpMyAdmin ' . 'and might cause some data to be corrupted!' ), E_USER_WARNING ); } /** * mbstring is used for handling multibytes inside parser, so it is good * to tell user something might be broken without it, see bug #1063149. */ if (! @extension_loaded('mbstring')) { trigger_error( __( 'The mbstring PHP extension was not found and you seem to be using' . ' a multibyte charset. Without the mbstring extension phpMyAdmin' . ' is unable to split strings correctly and it may result in' . ' unexpected results.' ), E_USER_WARNING ); } if ($cfg['LoginCookieValidityDisableWarning'] == false) { /** * Check whether session.gc_maxlifetime limits session validity. */ $gc_time = (int)@ini_get('session.gc_maxlifetime'); if ($gc_time < $GLOBALS['cfg']['LoginCookieValidity'] ) { trigger_error( __( 'Your PHP parameter [a@http://php.net/manual/en/session.' . 'configuration.php#ini.session.gc-maxlifetime@_blank]session.' . 'gc_maxlifetime[/a] is lower than cookie validity configured ' . 'in phpMyAdmin, because of this, your login might expire sooner ' . 'than configured in phpMyAdmin.' ), E_USER_WARNING ); } } /** * Check whether LoginCookieValidity is limited by LoginCookieStore. */ if ($GLOBALS['cfg']['LoginCookieStore'] != 0 && $GLOBALS['cfg']['LoginCookieStore'] < $GLOBALS['cfg']['LoginCookieValidity'] ) { trigger_error( __( 'Login cookie store is lower than cookie validity configured in ' . 'phpMyAdmin, because of this, your login will expire sooner than ' . 'configured in phpMyAdmin.' ), E_USER_WARNING ); } /** * Check if user does not have defined blowfish secret and it is being used. */ if (! empty($_SESSION['encryption_key']) && empty($GLOBALS['cfg']['blowfish_secret']) ) { trigger_error( __( 'The configuration file now needs a secret passphrase (blowfish_secret).' ), E_USER_WARNING ); } /** * Check for existence of config directory which should not exist in * production environment. */ if (file_exists('config')) { trigger_error( __( 'Directory [code]config
, which is used by the setup script, ' . 'still exists in your phpMyAdmin directory. It is strongly ' . 'recommended to remove it once phpMyAdmin has been configured. ' . 'Otherwise the security of your server may be compromised by ' . 'unauthorized people downloading your configuration.' ), E_USER_WARNING ); } if ($server > 0) { $cfgRelation = PMA_getRelationsParam(); if (! $cfgRelation['allworks'] && $cfg['PmaNoRelation_DisableWarning'] == false ) { $msg_text = __( 'The phpMyAdmin configuration storage is not completely ' . 'configured, some extended features have been deactivated. ' . '%sFind out why%s. ' ); if ($cfg['ZeroConf'] == true) { $msg_text .= '
' . __( 'Or alternately go to \'Operations\' tab of any database ' . 'to set it up there.' ); } $msg = PMA_Message::notice($msg_text); $msg->addParam( '', false ); $msg->addParam('', false); /* Show error if user has configured something, notice elsewhere */ if (!empty($cfg['Servers'][$server]['pmadb'])) { $msg->isError(true); } $msg->display(); } // end if } /** * Warning about different MySQL library and server version * (a difference on the third digit does not count). * If someday there is a constant that we can check about mysqlnd, * we can use it instead of strpos(). * If no default server is set, $GLOBALS['dbi'] is not defined yet. * Drizzle can speak MySQL protocol, so don't warn about version mismatch for * Drizzle servers. * We also do not warn if MariaDB is detected, as it has its own version * numbering. */ if (isset($GLOBALS['dbi']) && !PMA_DRIZZLE && $cfg['ServerLibraryDifference_DisableWarning'] == false ) { /** @var PMA_String $pmaString */ $pmaString = $GLOBALS['PMA_String']; $_client_info = $GLOBALS['dbi']->getClientInfo(); if ($server > 0 && /*overload*/mb_strpos($_client_info, 'mysqlnd') === false && /*overload*/mb_strpos(PMA_MYSQL_STR_VERSION, 'MariaDB') === false && substr(PMA_MYSQL_CLIENT_API, 0, 3) != substr( PMA_MYSQL_INT_VERSION, 0, 3 ) ) { trigger_error( PMA_sanitize( sprintf( __( 'Your PHP MySQL library version %s differs from your ' . 'MySQL server version %s. This may cause unpredictable ' . 'behavior.' ), $_client_info, substr( PMA_MYSQL_STR_VERSION, 0, strpos(PMA_MYSQL_STR_VERSION . '-', '-') ) ) ), E_USER_NOTICE ); } unset($_client_info); } /** * Warning about Suhosin only if its simulation mode is not enabled */ if ($cfg['SuhosinDisableWarning'] == false && @ini_get('suhosin.request.max_value_length') && @ini_get('suhosin.simulation') == '0' ) { trigger_error( sprintf( __( 'Server running with Suhosin. Please refer to %sdocumentation%s ' . 'for possible issues.' ), '[doc@faq1-38]', '[/doc]' ), E_USER_WARNING ); } /** * Warning about incomplete translations. * * The data file is created while creating release by ./scripts/remove-incomplete-mo */ if (file_exists('libraries/language_stats.inc.php')) { include 'libraries/language_stats.inc.php'; /* * This message is intentionally not translated, because we're * handling incomplete translations here and focus on english * speaking users. */ if (isset($GLOBALS['language_stats'][$lang]) && $GLOBALS['language_stats'][$lang] < $cfg['TranslationWarningThreshold'] ) { trigger_error( 'You are using an incomplete translation, please help to make it ' . 'better by [a@https://www.phpmyadmin.net/translate/' . '@_blank]contributing[/a].', E_USER_NOTICE ); } } /** * prints list item for main page * * @param string $name displayed text * @param string $listId id, used for css styles * @param string $url make item as link with $url as target * @param string $mysql_help_page display a link to MySQL's manual * @param string $target special target for $url * @param string $a_id id for the anchor, * used for jQuery to hook in functions * @param string $class class for the li element * @param string $a_class class for the anchor element * * @return void */ function PMA_printListItem($name, $listId = null, $url = null, $mysql_help_page = null, $target = null, $a_id = null, $class = null, $a_class = null ) { echo PMA\Template::get('list/item') ->render( array( 'content' => $name, 'id' => $listId, 'class' => $class, 'url' => array( 'href' => $url, 'target' => $target, 'id' => $a_id, 'class' => $a_class, ), 'mysql_help_page' => $mysql_help_page, ) ); } [/CODE]
Dat heet nou PHP-code wat je ziet, en dat hoort niet.
Werkt een normaal php-bestand wel? En welke PHP-tags gebruik je?
Ha zit ik weer goed.:thumb:
Maar een php site werkt wel goed
Opgelost dus? Wat was de oplossing in dat geval? :)
Zo niet, welke phpMyAdmin installeer je?
En nog een tip: Besef wel dat de mysql_*() functies niet meer werken, en dat je nu mysqli_*() moet gebruiken ;-)
Php4u,
PHP werkt wel maar phpmyadmin niet
PHP is Versie 7.0.7-4
Phpmyadmin Versie 4:4.5.4.1
Dus het hele Mysql is vervangen door Mysqi als ik het goed begrijp :eek:
Nee, de oude MySQL-driver voor de functies is eruit gesloopt. Dus als jijzelf applicaties hebt draaien die nog mysql_.....() functies gebruiken, dan moet je die ombouwen.
Dat je PHP-code ziet in phpMyAdmin staat er los van. Ik vermoed dat er ergens een configuratiefout is in je virtual-host.
Maar je kan ook eens proberen om phpMyAdmin 4.6.3 (de nieuwste) te installeren.
de tool phpmyadmin is niet php7 ready.
tja wat je kan doen is met mysqlbrowser,heidisql verbinding maken naar de server (waar je toegang zal moeten krijgen) op ip verbinding .
het is niet alleen mysqli maar ook nog de deprecated functionaliteiten die eruit gaan.
Zoals ik vermoede zal ik mij klaar moeten houden voor geld te verdienen (de echte programmeurs komen aan zet Yesssss).
denk aan het volgende alle libs die je tot nu toe gebruikte kunnen stoppen met werken.
denk ook aan dat niet alle libs zullen worden geupdate doordat de makers er geen zin in hebben en of het niet gratis gaan doen omdat zij nu in dienst zijn van een werkgever.
DUS : alle mensen die te veel afhankelijk zijn van tooltjes zullen op bek gaan.
maar wat wil je doen ik heb een cms php7 ready.Ik ben nog pdf aan het bekijken.Mail (bassed on protocol layer) lijkt bijna af te zijn.
Inderdaad ik zag op phpmyadmin.net dat er een nieuwe versie is ga die eens proberen.
Ik kan me dit niet indenken? Het is één van de meeste gebruikte tools, en de ontwikkeling van PHP zit alweer in de PHP 7.1 branch.
Ja, dat werkt wel een stuk beter van phpMyAdmin.
Zeker, maar als je nu nog te maken hebt met deprecated-meldingen, dan is je vorige versie van PHP echt ver heen.
Ik ben eruit althans het werkt nu heb wel alles op nieuw geinstalleerd en ipv Ubuntu Server 16.04 heb ik Debian 8 op de pc gezet en met Debian werkt het zo als ik het wil
Maar wat er nu aan de hand is weet ik nog steeds niet, als eerste had ik Apache2 Mysql en phpmyadmin eraf gegooid Ubuntu Server up to date gemaakt geen fouten in de pakketten dus eerst Apache2 erop gezet deze getest en werkte toen Mysql ok deze werkte maar toen phpmyadmin weer het zelfde probleem.
Toen werd ik er zo flauw van dat ik helemaal opnieuw ben begonnen maar dan met Debian 8 :d
