jkpieterse
- 18 mei 2015
@EvR: Kan je mijn methode ook eens timen (heeft geen zin als ik het doe, kan je niet vergelijken als het niet dezelfde machine e.d. was)?
Privacywetgeving
Sub DoItMyWay()
With ThisWorkbook.Sheets("Eindresultaat")
.UsedRange.Clear
With ThisWorkbook.Sheets("Draaitabel").PivotTables(1)
.RefreshTable
.TableRange2.Copy
.Cells(1).PasteSpecial 12
With .UsedRange
.Columns(1).SpecialCells(4).FormulaR1C1 = "=R[-1]C"
.Columns(3).Insert
.Columns(3).Formula = "=A1&B1"
.Columns(3).NumberFormat = "@"
.Value = .Value
.Cells(1, 3) = "string"
.Columns.AutoFit
Sub M_snb_eenlussig()
sn = Sheets("Input_van_VPIG").Cells(1).CurrentRegion
With CreateObject("scripting.dictionary")
For j = 2 To UBound(sn)
c00 = sn(j, 1) & "_" & sn(j, 2) & "_" & sn(j, 1) & sn(j, 2)
.Item(c00) = Val(.Item(c00)) + sn(j, 3) & "_" & c00
Next
sn = .items
With CreateObject("New:{8BD21D20-EC42-11CE-9E0D-00AA006002F3}")
.List = sn
Sheets("output_voor_analyse").Cells(1).Resize(.ListCount) = .List
Application.DisplayAlerts = False
Sheets("output_voor_analyse").Cells(1, 1).CurrentRegion.Columns(1).TextToColumns , , , , 0, 0, 0, 0, -1, "_"
Sub M_snb_evaluate()
Sheets("input_van_VPIG").Activate
sn = [index(A2:A2000&"_"&B2:B2000&"_"&A2:A2000&B2:B2000&"_"&sumifs(C2:C2000,A$2:A$2000,A2:A2000,B2:B2000,B2:B2000),)]
For Each it In sn
x0 = .Item(it)
Next
Sheets("output_voor_analyse").Cells(1, 20).Resize(.Count) = Application.Transpose(.keys)
Sheets("output_voor_analyse").Cells(1, 20).CurrentRegion.Columns(1).TextToColumns , , , , 0, 0, 0, 0, -1, "_"
Sub hsv()
sn = Sheets("input_van_VPIG").Cells(1).CurrentRegion
Set dic = CreateObject("scripting.dictionary")
For i = 2 To UBound(sn)
dic.Item(sn(i, 1) & "_" & sn(i, 2) & "_" & sn(i, 1) & sn(i, 2)) = dic.Item(sn(i, 1) & "_" & sn(i, 2) & "_" & sn(i, 1) & sn(i, 2)) + sn(i, 3)
sn(dic.Count, 2) = dic.keys()(dic.Count - 1)
sn(dic.Count, 1) = dic.Item(dic.keys()(dic.Count - 1))
Next
With Sheets("output_voor_analyse").Cells(1)
.Resize(dic.Count, 2) = sn
.CurrentRegion.Columns(2).TextToColumns , , , , 0, 0, 0, 0, -1, "_"
Sub M_hsv_snb()
sn = Sheets("input_van_VPIG").Cells(1).CurrentRegion.Resize(, 4)
c00 = sn(j, 1) & sn(j, 2)
.Item(c00) = .Item(c00) + sn(j, 3)
sn(.Count, 1) = sn(j, 1)
sn(.Count, 2) = sn(j, 2)
sn(.Count, 3) = c00
sn(.Count, 4) = .Item(c00)
Next
Sheets("output_voor_analyse").Cells(1, 30).Resize(.Count, UBound(sn, 2)) = sn
Zette me aan het denken tot:
hsv_snb 4,835938
hsv na een aantal minuten maar afgekapt
Verbaasde mij ook, hoewel de uitkomst in PowerQuery meteen in een opgemaakte tabel staat, geen VBA nodig is en wellicht nog wat andere voordelen heeft. Maar ik had het sneller verwachtsnb zei:Wat me wel verbaast is, dat het script duidelijk sneller ......... suboptimale techniek. (correct me if I'm wrong)
Sub M_snb_querytable()
Sheet3.QueryTables.Add("ODBC;DSN=Excel files;DBQ=" & ThisWorkbook.FullName, Sheet3.Cells(1, 10), "SELECT afne, arti, afne&arti, aant FROM `Input_van_VPIG$` ").Refresh False
Sheet3.QueryTables.Add("ODBC;DSN=Excel files;DBQ=" & ThisWorkbook.FullName, Sheet3.Cells(1, 10), "SELECT afne, arti ,afne&arti, sum(aant) FROM `Input_van_VPIG$` GROUP BY afne, arti, afne&arti ").Refresh False
7,902344 (nieuwe query)
6,640625 (bestaande refresh)
Sub M_snb_listobject()
With Sheet3.ListObjects.Add(0, "ODBC;DSN=Excel files;DBQ=" & ThisWorkbook.FullName, True, xlYes, Sheet3.Cells(1, 10)).QueryTable
.CommandText = "SELECT afne, arti ,afne&arti, sum(aant) FROM `Input_van_VPIG$` GROUP BY afne, arti, afne&arti "
.Refresh False
Sub M_snb_querytable_002()
With ThisWorkbook.Connections.Add("snb_dicht", " ", "ODBC;DSN=Excel files;DBQ=" & ThisWorkbook.FullName, "SELECT afne, arti ,afne&arti, sum(aant) FROM `Input_van_VPIG$` GROUP BY afne, arti, afne&arti ").ODBCConnection
Sheet3.QueryTables.Add(.Connection, Sheet3.Cells(1, 10), .CommandText).Refresh False
M_snb_listobject 7,230469
M_snb_querytable_002 8,507813
