Macro / VBA werkbladen tonen of verbergen inkorten
abbcdcg
12 mrt 2012
Ik zit even te knutselen. "Database!B9" is een uitkomst vanuit een besturingselement. De macro staat onder het tabblad Database en werkt op deze manier goed.
Kan deze macro anders / korter....???
Thanks!
Private Sub Worksheet_Calculate()
 If Worksheets("Database").Range("B9") = "1" Then Sheets("Sheet A").Visible = False
 If Worksheets("Database").Range("B9") = "1" Then Sheets("Sheet B").Visible = False
 If Worksheets("Database").Range("B9") = "1" Then Sheets("Sheet C").Visible = False
 If Worksheets("Database").Range("B9") = "2" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "2" Then Sheets("Sheet B").Visible = False
 If Worksheets("Database").Range("B9") = "2" Then Sheets("Sheet C").Visible = False
 If Worksheets("Database").Range("B9") = "3" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "3" Then Sheets("Sheet B").Visible = False
 If Worksheets("Database").Range("B9") = "3" Then Sheets("Sheet C").Visible = False
 If Worksheets("Database").Range("B9") = "4" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "4" Then Sheets("Sheet B").Visible = True
 If Worksheets("Database").Range("B9") = "4" Then Sheets("Sheet C").Visible = True
 If Worksheets("Database").Range("B9") = "5" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "5" Then Sheets("Sheet B").Visible = True
 If Worksheets("Database").Range("B9") = "5" Then Sheets("Sheet C").Visible = True
 If Worksheets("Database").Range("B9") = "6" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "6" Then Sheets("Sheet B").Visible = False
 If Worksheets("Database").Range("B9") = "6" Then Sheets("Sheet C").Visible = False
 If Worksheets("Database").Range("B9") = "7" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "7" Then Sheets("Sheet B").Visible = False
 If Worksheets("Database").Range("B9") = "7" Then Sheets("Sheet C").Visible = False
 If Worksheets("Database").Range("B9") = "8" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "8" Then Sheets("Sheet B").Visible = True
 If Worksheets("Database").Range("B9") = "8" Then Sheets("Sheet C").Visible = True
 If Worksheets("Database").Range("B9") = "9" Then Sheets("Sheet A").Visible = True
 If Worksheets("Database").Range("B9") = "9" Then Sheets("Sheet B").Visible = True
 If Worksheets("Database").Range("B9") = "9" Then Sheets("Sheet C").Visible = True
 If Worksheets("Database").Range("B9") = "10" Then Sheets("Sheet A").Visible = False
 If Worksheets("Database").Range("B9") = "10" Then Sheets("Sheet B").Visible = True
 If Worksheets("Database").Range("B9") = "10" Then Sheets("Sheet C").Visible = True
 If Worksheets("Database").Range("B9") = "11" Then Sheets("Sheet A").Visible = False
 If Worksheets("Database").Range("B9") = "11" Then Sheets("Sheet B").Visible = True
 If Worksheets("Database").Range("B9") = "11" Then Sheets("Sheet C").Visible = True
Veel korter denk ik niet, maar wel netter en beter leesbaar:
Private Sub Workssdfheet_Calculate()
    Select Case Sheets("Database").Range("B9")
        Case 1
        Case 2
        Case 3
        Case 4
        Case 5
        Case 6
        Case 7
        Case 8
        Case 9
        Case 10
        Case 11
Maar bij 4 en 5 bijvoorbeeld moet hetzelfde gebeuren.
Dus dat nag je ook als Case 4, 5 noteren.
Dat scheelt weer 4 regels.
Of dat ook voor anderen geldt mag je zelf bekijken.
   Sheets("Sheet A").Visible = True              'alle 3 zichtbaar
   Select Case Worksheets("Database").Range("B9").Value   'afhankelijk van B9 enkele terug verbergen
      Case Is = "1"
      Case "2", "3", "6", "7"
      Case "4", "5", "8", "9"
      Case "10", "11"
   End Select
oei, Edmoor was sneller
Maar jij hebt er dieper naar gekeken en de combinaties gemaakt :)
      Case Is = "1"
      Case "10", "11"
   End Select
      Case Is = "1"
      Case "10", "11"
   End Select
Dit werkt super! Thanks!
Nu wil ik een stap verder door hierbij een volgende situatie aan toe te voegen.
Hoe kan ik hier nu een situatie aan toevoegen waarde de waarde uit (b.v.) Database!B10 wordt gehaald, en "Sheet D" wordt getoond / verborgen op basis van de Case 1 of 2?
bv. als laatste zin, na die "end select"en voor de "end sub".
Let wel, dat blad wordt getoond op waarde "1" en in alle andere gevallen, dus ook "2", verborgen.
Dat is lichtjes anders dan wat je wilde, maar je moet anders duidelijker zijn over wat er moet gebeuren bij andere waarden.
Sheets("Sheet D").Visible = (Worksheets("Database").Range("B10") = "1")
Maak een tabelletje met twee kolommen, kolom A de werkblad namen, kolom B een formule die op basis van je invoer een TRUE geeft (of WAAR in NL versie van Excel) als de sheet zichtbaar mag zijn of FALSE (ONWAAR) indien niet. Dan is je code heel simpel iets als:
   Dim Cl as Range
   For Each Cl In Worksheets("Settings").Range("A2:A4")
      If Cl.Offset(, 1).Value Then
         Sh.Visible = xlSheetVisible
      Else
         Sh.Visible = xlSheetHidden
   Next
Beter nog, zet het bereik met de bladnamen om in een tabel met de naam tblSheets en gebruik deze code (ik ging ervan uit dat e.e.a. op een werkblad genaamd "Settings" staat):
   Dim Cl as Range
   For Each Cl In ThisWorkbook.Worksheets("Settings").ListObjects("tblSheets").ListColumns(1).DataBodyRange
      Else
   Next
