USB disk beveiliging verwijderen
Dukkel
17 feb 2016
Win11 (25H2) Prof NL
Office365
Hallo Allemaal
Eén van m'n USB disks is (ongewild) beveiligd
Normaal gebruik ik hiervoor DISKPART, met de volgende commando's
List disk
Select disk X (X=drive)
Clear
Create Partition Primair
Select Partition 1
for fs=ntfs quick
Act
Assign
exit
Maar dit werkt nu niet meer in Windows 11
Het commando Clear komt niet meer voor in DIKSPART
Wat nu te doen?
Met vriendelijke groet
Dukkel
Moet dat niet CLEAN zijn?
Microsoft DiskPart version 10.0.22000.653
ACTIVE      - Mark the selected partition as active.
ADD         - Add a mirror to a simple volume.
ASSIGN      - Assign a drive letter or mount point to the selected volume.
ATTRIBUTES  - Manipulate volume or disk attributes.
ATTACH      - Attaches a virtual disk file.
AUTOMOUNT   - Enable and disable automatic mounting of basic volumes.
BREAK       - Break a mirror set.
CLEAN       - Clear the configuration information, or all information, off the
              disk.
COMPACT     - Attempts to reduce the physical size of the file.
CONVERT     - Convert between different disk formats.
CREATE      - Create a volume, partition or virtual disk.
DELETE      - Delete an object.
DETAIL      - Provide details about an object.
DETACH      - Detaches a virtual disk file.
EXIT        - Exit DiskPart.
EXTEND      - Extend a volume.
EXPAND      - Expands the maximum size available on a virtual disk.
FILESYSTEMS - Display current and supported file systems on the volume.
FORMAT      - Format the volume or partition.
GPT         - Assign attributes to the selected GPT partition.
HELP        - Display a list of commands.
IMPORT      - Import a disk group.
INACTIVE    - Mark the selected partition as inactive.
LIST        - Display a list of objects.
MERGE       - Merges a child disk with its parents.
ONLINE      - Online an object that is currently marked as offline.
OFFLINE     - Offline an object that is currently marked as online.
RECOVER     - Refreshes the state of all disks in the selected pack.
              Attempts recovery on disks in the invalid pack, and
              resynchronizes mirrored volumes and RAID5 volumes
              that have stale plex or parity data.
REM         - Does nothing. This is used to comment scripts.
REMOVE      - Remove a drive letter or mount point assignment.
REPAIR      - Repair a RAID-5 volume with a failed member.
RESCAN      - Rescan the computer looking for disks and volumes.
RETAIN      - Place a retained partition under a simple volume.
SAN         - Display or set the SAN policy for the currently booted OS.
SELECT      - Shift the focus to an object.
SETID       - Change the partition type.
SHRINK      - Reduce the size of the selected volume.
UNIQUEID    - Displays or sets the GUID partition table (GPT) identifier or
              master boot record (MBR) signature of a disk.
              disk.
Ja je hebt gelijk. Duidelijk een typefout
Meer dan bedankt Edmoor
