Ik heb een vba gemaakt.
Deze heb ik op blad 1 (handleiding) geplaatst.
Nu wil ik dat deze vba op alle tabbladen toegepast wordt.
Hoe krijg ik dit voor elkaar?
Heb tabbladen met de namen:
worksheetnaam: planning_2011.xls
met de onderliggende tabbladen:
handleding / Jan / Feb / Mrt / Apr / etc..
Hoop dat dit voldoende info is voor dit probleem.
Private Sub Worksheet_Change(ByVal Target As Excel.Range)
With Target
Select Case .Value
Case Is = "BcD"
.Font.ColorIndex = 6
.Interior.ColorIndex = 10
Case Is = "CIT"
.Font.ColorIndex = 1
.Interior.ColorIndex = 8
Case Is = "CU"
.Interior.ColorIndex = 3
Case Is = "CL"
.Interior.ColorIndex = 5
Case Is = "CV"
Case Is = "E"
.Interior.ColorIndex = 36
Case Is = "P"
.Interior.ColorIndex = 6
Case Is = "TIN"
Case Is = "L"
Case Is = "IL"
Case Is = "InV"
Case Is = "InL"
Case Is = "V"
.Interior.ColorIndex = 4
Case Is = "DV"
Case Is = "VC"
Case Is = "S"
.Interior.ColorIndex = 7
Case Is = "TL"
Case Is = "O"
Case Is = "To"
Case Is = "Z"
.Interior.ColorIndex = 44
Case Else
.Interior.ColorIndex = xlNone
End Select
If Target.Value = "C" Then
Target.Value = "Ci"
If Target.Value = "I" Then
Target.Value = "In"
If Target.Value = "B" Then
Target.Value = "BcD"
If Target.Value = "TT" Then
Target.Value = "T2T"
