On drives that are larger than 32 GB there is a Capacity Limitation Jumper (CLJ) or the Alternate Capacity (AC) Jumper setting. This jumper will limit the capacity of the drive to 32 GB and should only be used when the BIOS hangs when trying to auto-detect the drive. If you have two jumpers shunts on the drive you will need to remove the CLJ or AC jumper. To resolve the issue use the standard jumper settings
