aanvulling VBA code email
jan excel
4 mrt 2007
Hoi Experts,
Via Ron de Bruin heb ik onderstaande VBA code toegepast, werkt perfect.
Echter ik wil meerdere personen deze email sturen, wie kan mij helpen om de code aan te passen zodat er meerdere personen de mail krijgen.
Alvast bedankt
Sub Mail_Selection()
'Working in 2000-2007
Dim Source As Range
Dim Dest As Workbook
Dim wb As Workbook
Dim TempFilePath As String
Dim TempFileName As String
Dim FileExtStr As String
Dim FileFormatNum As Long
Set Source = Nothing
On Error Resume Next
Set Source = Selection.SpecialCells(xlCellTypeVisible)
On Error GoTo 0
If Source Is Nothing Then
MsgBox "The source is not a range or the sheet is protected, " & _
"please correct and try again.", vbOKOnly
Exit Sub
If ActiveWindow.SelectedSheets.Count > 1 Or _
Selection.Cells.Count = 1 Or _
Selection.Areas.Count > 1 Then
MsgBox "Foutieve handeling :" & vbNewLine & vbNewLine & _
"Je hebt meer dan één sheet geselecteerd." & vbNewLine & _
"Je hebt maar één cel geselecteerd." & vbNewLine & _
"Selecteer de range met gegevens." & vbNewLine & vbNewLine & _
"Als dit is gedaan, bevestig dit door op OK te klikken.", vbOKOnly
Exit Sub
With Application
.ScreenUpdating = False
.EnableEvents = False
Set wb = ActiveWorkbook
Set Dest = Workbooks.Add(xlWBATWorksheet)
Source.Copy
With Dest.Sheets(1)
.Cells(1).PasteSpecial Paste:=8
.Cells(1).PasteSpecial Paste:=xlPasteValues
.Cells(1).PasteSpecial Paste:=xlPasteFormats
.Cells(1).Select
TempFilePath = Environ$("temp") & "\"
TempFileName = "" & wb.Name & " " _
& Format(Now, "dd-mmm-yy h-mm-ss")
If Val(Application.Version) < 12 Then
'You use Excel 2000-2003
FileExtStr = ".xls": FileFormatNum = -4143
Else
'You use Excel 2007
FileExtStr = ".xlsx": FileFormatNum = 51
With Dest
.SaveAs TempFilePath & TempFileName & FileExtStr, _
FileFormat:=FileFormatNum
.SendMail "jan007@hccnet.nl", _
"test bericht"
On Error GoTo 0
.Close SaveChanges:=False
Kill TempFilePath & TempFileName & FileExtStr
With Application
.ScreenUpdating = True
.EnableEvents = True
Hoi Experts,
Alvast bedankt
Dim Source As Range
Dim wb As Workbook
On Error GoTo 0
Exit Sub
Exit Sub
With Application
Source.Copy
With Dest.Sheets(1)
.Cells(1).Select
Else
'You use Excel 2007
With Dest
"test bericht"
On Error GoTo 0
With Application
Oplossing gevonden:
SendMail Array("piet1123@hccnet.nl", "jan007@hccnet.nl", "klaas jansen@hetnet.nl"), _
