Gripmaster
- 10 okt 2013
Privacywetgeving
Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean)
Run AutoFitMergedCellRowHeight 'oftewel je macronaam
Run AutoFitMergedCellRowHeight()
Dim CurrentRowHeight As Single, MergedCellRgWidth As Single
Dim CurrCell As Range
Dim ActiveCellWidth As Single, PossNewRowHeight As Single
Dim StartCell As Range, c As Range, MergeRng As Range, Cell As Range
Dim a() As String, isect As Range, i
'Take a note of current active cell
Set StartCell = ActiveCell
'Create an array of merged cell addresses that have wrapped text
For Each c In ActiveSheet.UsedRange
If c.MergeCells Then
With c.MergeArea
If .Rows.Count = 1 And .WrapText = True Then
If MergeRng Is Nothing Then
Set MergeRng = c.MergeArea
ReDim a(0)
a(0) = c.MergeArea.Address
Else
Set isect = Intersect(c, MergeRng)
If isect Is Nothing Then
Set MergeRng = Union(MergeRng, c.MergeArea)
ReDim Preserve a(UBound(a) + 1)
a(UBound(a)) = c.MergeArea.Address
Next c
'Loop thru merged cells
For i = 0 To UBound(a)
Range(a(i)).Select
With ActiveCell.MergeArea
'Application.ScreenUpdating = False
CurrentRowHeight = .RowHeight
ActiveCellWidth = ActiveCell.ColumnWidth
For Each CurrCell In Selection
MergedCellRgWidth = CurrCell.ColumnWidth + MergedCellRgWidth
Next
.MergeCells = False
.Cells(1).ColumnWidth = MergedCellRgWidth
.EntireRow.AutoFit
PossNewRowHeight = .RowHeight
.Cells(1).ColumnWidth = ActiveCellWidth
.MergeCells = True
.RowHeight = IIf(CurrentRowHeight > PossNewRowHeight, _
CurrentRowHeight, PossNewRowHeight)
MergedCellRgWidth = 0
Next i
StartCell.Select
'Clean up
Set CurrCell = Nothing
Set StartCell = Nothing
Set c = Nothing
Set MergeRng = Nothing
Set Cell = Nothing
