backdoor.Sdbot
willem313
2 jun 2003
Ik heb een virus in het bestand system 32 hoe moet ik dit verwijderen of verhelpen
1) Click on Start
2) Click on Find or Search (depending on Windows version)
3) Click on Files or Folders or All Files and Folders
4) Type in the name of the file such as I5Eexplore and search the hard drive for it
5) Delete the file
6) Now click on Start, Run, type in REGEDIT and click OK to open the Registry Editor
7) Delete the entry below in each of the following locations in the Registry (However, do this at your own risk - deleting the wrong keys and cause the computer to not boot correctly or operate correctly)
In the right pane, delete any value that refers to the file
"Config Loadatiorin"="<I5Eexplore.exe>"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce
8) Exit the Registry Editor
9) Restart the computer and check the Registry again for the trojan
Er schijne er verschillende te zijn die ik gaf heb ik gevonden op google en is de sdbot en die van Masera is de backdoor sdbot.h
