Re: bedankt
Geplaatst door Mister D.
Bedankt voor de uitleg.
Maar nu wordt ik wel nieuwsgierig...
Wat betekenen die parameters precies?
Parameters
/n:
Opens a new window in single-paned (My Computer) view for each item selected, even if the new window duplicates a window that is already open.
/e:
Uses Windows Explorer view (Opens a 2 pane view of the selected folder).
/root,<object>:
Specifies the root level of the specified view.
The default is to use the normal namespace root (the desktop). Whatever is specified is the root for the display.
<object> designates the folder path
This switch is used with a folder object. It chooses the designated folder as the starting point (root) of the folder tree. (Ordinarily, \DESKTOP is the root).
/select,<object>:
Specifies the folder to receive the initial focus.
If "/select" is used, the parent folder is opened and the specified object is selected. Highlights the designated folder and displays the contents of the parent folder in the right pane.
Examples
Open Explorer with Folders View to the C:\WINDOWS\TEMP folder:
C:\WINDOWS\EXPLORER.EXE /n,/e,C:\WINDOWS\TEMP
To open a Windows Explorer view to explore only objects on
\\<server name>, use the following syntax:
C:\WINDOWS\EXPLORER.EXE /e,/root,\\<server name>
To view the C:\WINDOWS folder and select NOTEPAD.EXE, use the following syntax:
C:\WINDOWS\EXPLORER.EXE /select,c:\windows\notepad.exe
Bron.
