Kreeg een paar dagen geleden een blauw scherm.
Heb toen min videokaartdrivers geupdate
Nu lreeg ik net weer een blauw scherm maar ik snap er geen hout van
Dit staat op de respons van Microsoft:
Error Caused by Graphics Device Driver
Thank you for submitting an error report. Microsoft is unable to specifically determine what caused the problem you reported. If you would like to try and troubleshoot the problem, please utilize the information listed below.
Analysis
A device driver installed on your system caused the problem, but we cannot determine the precise cause. Depending on which situation is applicable to you, do one of the following:
* If you are running Windows Server 2003 you may experience crashes if you have adjusted the Hardware Acceleration setting. Microsoft recommends that the Hardware Acceleration setting be set to None for server systems. To check your Hardware Acceleration setting, go to the advanced section of the display properties dialog box.
* If you know the manufacturer of the device, contact the manufacturer's product support service for assistance.
* If you don't know the driver's manufacturer and need help diagnosing and resolving this problem, contact your computer manufacturer's product support service.
* Updated drivers might be available on the Microsoft Windows Update Web site. At Windows Update, you can have your computer scanned and, if there are updated drivers available, Windows Update will offer a selection of drivers that you might be able to use. To learn more about updated drivers that might be available, visit Microsoft Windows Update.
* For information about Microsoft support options, visit Microsoft Product Support Services.
Additional Technical Information
* Error Message: STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER (Q293078)
Waar gaat dit over??
Analysis
