]beste,
ik heb sins 4 dagen een ieuw moederbord in het systeem gezet van mijn vader..
sins dien hebben we tot nu alleen maar problemen ermee ..
hij heeft onder het gamen tot nu al 2 bsod gekregen en het lijkt niet op te houden
ik heb whocrash gedownload om te kijken wat het zou kunnen zijn
deze zegt als volgt :
mvg
HTML:
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Wed 9/25/2013 4:05:36 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini092513-01.dmp
This was probably caused by the following module: rtenicxp.sys (Rtenicxp+0xACEC)
Bugcheck code: 0x100000D1 (0xFFFFFFFFB7E06599, 0x2, 0x8, 0xFFFFFFFFB7E06599)
Error: CUSTOM_ERROR
file path: C:\WINDOWS\system32\drivers\rtenicxp.sys
product: Realtek 10/100/1000 NIC Family all in one NDIS Driver
company: Realtek Semiconductor Corporation
description: Realtek 10/100/1000 NDIS 5.1 Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rtenicxp.sys (Realtek 10/100/1000 NDIS 5.1 Driver , Realtek Semiconductor Corporation ).
Google query: Realtek Semiconductor Corporation CUSTOM_ERROR
On Mon 9/23/2013 7:15:07 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini092313-01.dmp
This was probably caused by the following module: nv4_disp.dll (nv4_disp+0x1502AD)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFFFFFBF936B86, 0xFFFFFFFFAF343C9C, 0xFFFFFFFFAF343998)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\WINDOWS\system32\nv4_disp.dll
product: NVIDIA Windows XP Display driver, Version 327.23
company: NVIDIA Corporation
description: NVIDIA Windows XP Display driver, Version 327.23
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nv4_disp.dll (NVIDIA Windows XP Display driver, Version 327.23 , NVIDIA Corporation).
Google query: NVIDIA Corporation SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Conclusion
2 crash dumps have been found and analyzed. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
ik heb eerst de drivers van de videokaart verwijderd en toen weer nieuw geinstalleerd..
vandaag zei die weer het volgende: zie hierboven ..
weet iemand wat ik nu precies moet doen ??
ik ben niet al te best met engels maar ik kan er het volgende uithalen
er is een driver gevonden die het systeem heeft laten crashen en ik moet nu kijken of ik rtenicxp.sys krijg geupdate ??
waaar vind ik dat en hoe doe ik dat ??
of is het beste dat ik de drivers gewoon geheel verwijder en opnieuw installeeer ?
wie kan me even verder op weg helpen
