Hmmpf ik heb Call.Of.Duty.World.At.War-RELOADED Gedownload en ik heb em geinstalleerd en crack erop gezet (die zat bij de iso file) En nouw doed hij het niet :S
Hij gaf een fout aan : Call of duty world at war werkt niet meer (er wordt naar een oplossing gezocht etc) (ik heb vista)
Daarna kreeg ik een Cod 5 Console met daarin
----- Initializing Renderer ----
execing ragdoll.cfg from disk
----- Client Initialization -----
----- Client Initialization Complete -----
Trying SMP acceleration...
...succeeded.
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 3.0
Vertex shader version is 3.0
Shader model 2.0 code path is available.
Shader model 3.0 code path is available.
Using Shader model 3.0 code path because it is the best available path on this hardware.
Attempting 800 x 600 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Using 4x anti-aliasing
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Loading fastfile code_post_gfx
Loading fastfile ui
Loading fastfile common
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Loading fastfile 'code_post_gfx'
used 1.13 MB memory in DB alloc
Loading fastfile 'ui'
used 39.48 MB memory in DB alloc
Setting initial state...
DirectX reports 512 MB of video memory and 1710 MB of available texture memory.
Using video memory size to cap used texture memory at 496 MB.
Texture detail is set automatically.
Using picmip 0 on most textures, 0 on normal maps, and 3 on specular maps
Error: Could not load material "water_droplet".
Error: Could not load material "water_dynamic_spray".
------- sound system initialization -------
Error during initialization:
Unhandled exception caught
Iemand ideeen ? :thumb:
...succeeded.
----- R_Init -----
Loading fastfile ui
