Privacywetgeving
Sub test1()
Dim mydate As Variant: mydate = Month(DTPicker1)
Dim title As String: title = ActiveWorkbook.Worksheets(1).Range("C8")
If mydate = 1 Then GoTo 1
If mydate = 2 Then GoTo 2
If mydate = 3 Then GoTo 3
If mydate = 4 Then GoTo 4
If mydate = 5 Then GoTo 5
If mydate = 6 Then GoTo 6
If mydate = 7 Then GoTo 7
If mydate = 8 Then GoTo 8
If mydate = 9 Then GoTo 9
If mydate = 10 Then GoTo 10
If mydate = 11 Then GoTo 11
If mydate = 12 Then GoTo 12
1:
If ActiveCell.Offset(0, 5).Value > 0 Then GoTo 1110 'cell is (0,8) has been filled
If ActiveCell.Offset(0, 5).Value = "" Then 'cell is (0,8) is empty
ActiveCell.Offset(0, 5).Value = title
Exit Sub
1110:
If ActiveCell.Offset(0, 5 + 1).Value > 0 Then GoTo 1120 'cell is (0,5 +1) has been filled
If ActiveCell.Offset(0, 5 + 1).Value = "" Then 'cell is (0,5 +1) is empty
ActiveCell.Offset(0, 5 + 1).Value = title
Exit Sub
1120:
If ActiveCell.Offset(0, 5 + 2).Value > 0 Then GoTo msgbox 'cell is (0,5 +1) has been filled
If ActiveCell.Offset(0, 5 + 2).Value = "" Then 'cell is (0,5 +1) is empty
ActiveCell.Offset(0, 5 + 2).Value = title
Exit Sub
Sub test1()
with ActiveCell.Offset(, 4+Month(DTPicker1))
.offset(,abs(.value=0)) =sheets(1).Range("C8")
end with
end sub
