Als je clone cd 4.xxx installeerd , heb je er een virtueel schijfstation bij.Dit kan je gebruiken als je bv een iso of bin file gedownload hebt. En je wilt controleren of de afbeelding (image) 100% in orde is.
Als dit zo is kan je de image branden.
De help file van clone cd is in het engels en daar staat een heel stuk hoe je de optie moet gebruiken.
De extra schijf kan geen kwaad en de rest blijft het ook gewoon nog doen.
Bijgevoegd is een stukje helpfile.....
Virtual CloneDrive" is a virtual drive, lined up with all the "real" drives in your desktop folder "My Computer". With a virtual drive you are able to play copied music, games or movies without burning a CD or DVD. You only have to mount your virtual CD or DVD in form of a Image from your hard disk or the local network into the "Virtual CloneDrive" and there you go...
Virtual CloneDrive Top-Features:
Virtual CloneDrive supports the following Images: CCD, IMG, BIN, ISO, UDF
Virtual CloneDrive works for DVDs and CDs, even over the network
Virtual CloneDrive is optimised for CloneCD: You can copy "On-the-Fly" from a virtual drive to another drive
Images read with CloneCD are automatically listed in the History of the Virtual CloneDrive
Virtual CloneDrive automatically adapts the Region Code for DVD-Images
Virtual CloneDrive supports audio playback via digital audio emulation
Virtual CloneDrive uses sheep icons for easier recognition of the virtual drives
Virtual CloneDrive can be used to convert older CloneCD Images to the latest version
After installing CloneCD, you will find the Menu Item "Virtual CloneDrive" in the Tray Icon Menu.
Note: Please do ignore the requests of the operating system during the installation process. Please always click "Next" or "OK" when you are asked if you like to continue the installation process.
"Number of Drives": This option lets you decide how many virtual drives you want to use
"Virtual Sheep": If you enable this option, the Virtual CloneDrives are marked with a sheep
Further Menu Items are found by clicking with the right mouse button on a "Virtual CloneDrive". You can find all the virtual drives by double-clicking on your Desktop Icon "My Computer". They are marked with a sheep. If you don't like the sheep, deactivate the check box in the Virtual CloneDrive window.
Please click the right mouse button on a virtual drive created by CloneCD. A Menu with several Menu Items opens. The Menu Items are similar to the ones of a "real" drive ("Open", "Explore" etc.). Only the Menu Item "Virtual CloneDrive" is special and different from the "real" ones.
If you stop your mouse at the Menu Item "Virtual CloneDrive" another menu opens with the following functions:
"Mount": Allows to insert the desired Image through a automatically opend browser window
"Unmount": Removes the currently inserted Image
Hint: The Menu Item "Unmount" is not the same as "Eject". With "Eject" you only open the drawer of the virtual drive: The "virtual CD" stays in the drive. If you now close the drive, the currently inserted Image will be mounted again. With "Unmount" you really remove the "virtual CD"!
Mazzel Mike
