jha dat zij mijn vriend ook als je nou nieuwe ram koopt en meer geheuge dan meto die het wel doen
mijn cpu is te laag ofso vede
CPU
Minimum: Pentium 4 2.4 GHz/ Athlon 64 2800+ (Intel & Athlon 1.8 GHz Dual Core or better supported
You Have: Intel(R) Celeron(R) CPU 2.60GHz FAIL: Sorry, your CPU does not meet this minimum requirement. It may be time to purchase a more powerful computer to make your life easier. Click the 'We Recommend' button to discover how you can.
CPU Speed
Minimum: 2.4 GHz
You Have: 2.59 GHz PASS
System RAM
Minimum: 512 MB (768 MB for Windows Vista)
You Have: 511.5 MB PASS
Operating System
Minimum: Windows XP/Vista only
You Have: Microsoft Windows XP Home Edition (Build Service Pack 22600) PASS
Video Card
Minimum: 128MB 3d Hardware Accelerated card required-100% DirectX 9.0c compatible and latest drivers (NVIDIA GeForce 6600+ / ATI Radeon 9800 Pro+)
You Have: NVIDIA GeForce 7600 GS (GeForce 7600 GS) PASS
Video Card Features - Minimum attributes of your Video Card Video RAM: Required - 128 MB , You have - 256.0 MB
Video Card 3D Acceleration: Required - Yes , You have - Yes
Video HW Transform & Lighting: Required - Yes , You have - Yes
Vertex Shader Ver.: Required - 2.0 , You have - 3.0
Pixel Shader Ver.: Required - 2.0 , You have - 3.0
Video Card Driver Version (DirectX)
Your driver version number is: 6.14.11.6371 FYI: Your video card driver version is provided for your information, but it is not part of this analysis. But proper video card driver versions are important to the proper operation of your product.
DirectX Version
Minimum: 9.0c
You Have: 9.0c PASS
Sound Card
Minimum: Yes
You Have: SigmaTel Audio PASS
Sound Card Driver Version
Your driver version number is: 5.10 FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
Free Disk Space
Minimum: 8 GB of uncompressed free hard disk space (plus 600 MB for Windows swap file)
You Have: 8.5 GB PASS
DVD
Minimum: 6X DVD-ROM
r alles alles redelijk goed
dus wat is het probleem nu precies is mijn pc te zwak ervoor
maar als dat is wrm kan ik dan wel single player spele
mijn cpu is neti goed
CPU
tjha ik snap hier nisk van
