code van lus
SUVERMO
22 dec 2019
hoe moet ik de code aanpassen, is onder deel van de grootte code
If TELLER > 0 Then Next i Else
    If MsgBox("er is een voorbeeld naar uw e-mailadres verstuurd, is deze goed?", vbYesNo + vbDefaultButton2) = vbNo Then Exit Sub
    If MsgBox("mogen er " & Range("AANTAL_MAILS") & " e-mails verzonden worden?", vbYesNo + vbDefaultButton2) = vbNo Then Exit Sub
    If MsgBox("weet U zeker dat de " & Range("AANTAL_MAILS") & " e-mails mogen worden verzonden?", vbYesNo + vbDefaultButton2) = vbNo Then Exit Sub
    If MsgBox("dit is uw laatste kans om op nee te drukken", vbYesNo) = vbNo Then Exit Sub
    Next i
Sub mails_versturen()
    Sheets("E_mail").Activate
    Range("BEGINCEL") = " "
    Sheets("E_mailadres").Visible = False
    Sheets("Rekenen").Visible = False
    Sheets("REEDS VERZONDEN").Visible = False
    Range("TELLER") = 0
    x = Range("AANTAL_MAILS").Value
    a = Range("E_MAILONDERWERP").Value
    BESTANDSNAAM = Range("BESTANDSNAAM").Value
    Windows(BESTANDSNAAM).Activate
    'Application.ScreenUpdating = True
    'Application.ScreenUpdating = False
    BEWAAR_XLSM_OUD = Range("BEWAAR_XLSM").Value
    BEWAARNAAM_XLSM = Range("BEWAARNAAM_XLSM").Value
    OPENNAAM = Range("OPENNAAM").Value
    Workbooks.Open Filename:=OPENNAAM
    Application.DisplayAlerts = False
    ActiveWorkbook.SaveAs Filename:=BEWAARNAAM_XLSM
    Application.DisplayAlerts = True
    Application.ActivateMicrosoftApp xlMicrosoftMail
    Application.Wait DateAdd("s", 5, Now)
    For i = 0 To x
    wacht = Application.WorksheetFunction.RandBetween(5, 10) * 0.000001 '5 = 0,5sec ; 10 = 1,0sec
    Application.Wait (Now + wacht)
    BEWAARNAAM_XLSM_OUD = Range("BEWAARNAAM_XLSM").Value
    TELLER = i
    Range("TELLER") = i
    BEWAAR_XLSM = Range("BEWAAR_XLSM").Value
    BEWAARNAAM_PDF = Range("BEWAARNAAM_PDF").Value
    E_MAILADRES = Range("E_MAILADRES").Value
    CC_E_MAILADRES = Range("E_MAILADRES_CC").Value
    NAAM = Range("NAAM").Value
    ACHTERNAAM = Range("ACHTERNAAM").Value
    ADRES = Range("ADRES").Value
    POSTCODE = Range("POSTCODE").Value
    INZENDERSCODE = Range("INZENDERSCODE").Value
    PLAATS = Range("PLAATS").Value
    TELEFOON = Range("TELEFOON").Value
    GEBOORTEDATUM = Range("GEBOORTEDATUM").Value
    KLN_NUMMER = Range("KLN_NUMMER").Value
    NBS_NUMMER = Range("NBS_NUMMER").Value
    VIVFN_NUMMER = Range("VIVFN_NUMMER").Value
    VERENIGING = Range("VERENIGING").Value
    SPECIAALCLUB = Range("SPECIAALCLUB").Value
    Windows(BEWAAR_XLSM_OUD).Activate
    If TELLER > 1 Then Kill BEWAARNAAM_XLSM_OUD
    Windows(BEWAAR_XLSM).Activate
    Range("E_MAILADRES") = E_MAILADRES
    Range("ACHTERNAAM") = ACHTERNAAM
    Range("ADRES") = ADRES
    Range("POSTCODE") = POSTCODE
    Range("INZENDERSCODE") = INZENDERSCODE
    Range("PLAATS") = PLAATS
    Range("TELEFOON") = TELEFOON
    Range("GEBOORTEDATUM") = GEBOORTEDATUM
    Range("KLN_NUMMER") = KLN_NUMMER
    Range("NBS_NUMMER") = NBS_NUMMER
    Range("VIVFN_NUMMER") = VIVFN_NUMMER
    Range("VERENIGING") = VERENIGING
    Range("SPECIAALCLUB") = SPECIAALCLUB
    Range("PRINTGEDEELTE").ExportAsFixedFormat Type:=xlTypePDF, Filename:=BEWAARNAAM_PDF
    BIJLAGE_1 = Range("BIJLAGE_1").Value
    BIJLAGE_2 = Range("BIJLAGE_2").Value
    BIJLAGE_3 = Range("BIJLAGE_3").Value
    BIJLAGE_4 = Range("BIJLAGE_4").Value
    BIJLAGE_5 = Range("BIJLAGE_5").Value
    BIJLAGE_6 = Range("BIJLAGE_6").Value
    BIJLAGE_7 = Range("BIJLAGE_7").Value
    BIJLAGE_8 = Range("BIJLAGE_8").Value
    BIJLAGE_9 = Range("BIJLAGE_9").Value
    BIJLAGE_10 = Range("BIJLAGE_10").Value
    E_MAILONDERWERP = TELLER & "." & Range("AANTAL_MAILS").Value & "." & a
    tekst = Range("E_MAILTEKST")
    For j = 1 To UBound(tekst)
        E_MAILTEKST = E_MAILTEKST & "<tr><td>" & Join(Application.Index(tekst, j), "</td><td>") & "</td></tr>"
    Next
    E_MAILTEKST = E_MAILTEKST & "</table><P></P><P></P>"
    With CreateObject("Outlook.Application").CreateItem(0)
        .To = E_MAILADRES
        .CC = CC_E_MAILADRES
        .Subject = E_MAILONDERWERP
        .HTMLBody = E_MAILTEKST
        If BIJLAGE_1 <> "" Then .attachments.Add BIJLAGE_1
        If BIJLAGE_2 <> "" Then .attachments.Add BIJLAGE_2
        If BIJLAGE_3 <> "" Then .attachments.Add BIJLAGE_3
        If BIJLAGE_4 <> "" Then .attachments.Add BIJLAGE_4
        If BIJLAGE_5 <> "" Then .attachments.Add BIJLAGE_5
        If BIJLAGE_6 <> "" Then .attachments.Add BIJLAGE_6
        If BIJLAGE_7 <> "" Then .attachments.Add BIJLAGE_7
        If BIJLAGE_8 <> "" Then .attachments.Add BIJLAGE_8
        If BIJLAGE_9 <> "" Then .attachments.Add BIJLAGE_9
        If BIJLAGE_10 <> "" Then .attachments.Add BIJLAGE_10
        .Send
    E_MAILTEKST = ""
    If LCase(Left(BEWAAR_XLSM, 4)) = "mail" Then Kill BEWAARNAAM_PDF
    Next i
    ActiveWindow.Close
    Sheets("E_mailadres").Visible = True
    Sheets("Rekenen").Visible = True
    Sheets("REEDS VERZONDEN").Visible = True
    'If LCase(Left(BEWAAR_XLSM, 4)) = "mail" Then Kill BEWAARNAAM_PDF
