Code van VB.Net naar VB6
murdoch201
31 mei 2008
Ik heb hier een stuk code voor een encryptie toe te passen op een string in VB.NET. Ik heb reeds geprobeerd om de code om te zetten naar VB6, maar heb een beetje moeite.
De originele code:
Module AESstring
    Public Function AES_Encrypt(ByVal input As String, ByVal pass As String) As String
        Dim AES As New System.Security.Cryptography.RijndaelManaged
        Dim Hash_AES As New System.Security.Cryptography.MD5CryptoServiceProvider
        Dim encrypted As String = ""
        Try
            Dim hash(31) As Byte
            Dim temp As Byte() = Hash_AES.ComputeHash(System.Text.ASCIIEncoding.ASCII.GetBytes(pass))
            Array.Copy(temp, 0, hash, 0, 16)
            Array.Copy(temp, 0, hash, 15, 16)
            AES.Key = hash
            AES.Mode = Security.Cryptography.CipherMode.ECB
            Dim DESEncrypter As System.Security.Cryptography.ICryptoTransform = AES.CreateEncryptor
            Dim Buffer As Byte() = System.Text.ASCIIEncoding.ASCII.GetBytes(input)
            encrypted = Convert.ToBase64String(DESEncrypter.TransformFinalBlock(Buffer, 0, Buffer.Length))
            Return encrypted
        Catch ex As Exception
        End Try
    End Function
    Public Function AES_Decrypt(ByVal input As String, ByVal pass As String) As String
        Dim decrypted As String = ""
        Try
            AES.Key = hash
            Dim DESDecrypter As System.Security.Cryptography.ICryptoTransform = AES.CreateDecryptor
            Dim Buffer As Byte() = Convert.FromBase64String(input)
            decrypted = System.Text.ASCIIEncoding.ASCII.GetString(DESDecrypter.TransformFinalBlock(Buffer, 0, Buffer.Length))
            Return decrypted
        End Try
    End Function
End Module
De code voor VB6 (tot nu toe):
Public Function AES_Encrypt(ByVal inputt As String, ByVal pass As String) As String
        encrpyted = ""
        On Error GoTo notifyy:
            Dim temp As Byte
            temp = Hash_AES.ComputeHash(System.Text.ASCIIEncoding.ASCII.GetBytes(pass))
            copyarray (temp), 0, hash, 0, 16
            copyarray (temp), 0, hash, 15, 16
            a
            AES.Key = hash
            DESEncrypter = AES.CreateEncryptor
            Dim Buffer As Byte
            Buffer = System.Text.ASCIIEncoding.ASCII.GetBytes(inputt)
            AES_Encrypt = encrypted
    End Function
    Public Function AES_Decrypt(ByVal inputt As String, ByVal pass As String) As String
        decrypted = ""
            AES.Key = hash
            AES_Decrypt = decrypted
    End Function
notifyy:
Form1.logadd ("red"), "Error occured somewhere when encrypting/decrypting"
Wat doe ik met Array.copy? Die functie bestaat niet in VB6. En volgens mij gaat System.* ook niet werken, wat gebruik ik in de plaats? En ziet deze code er verder goed uit?
Alvast bedankt! :D
Groetjes,
murdoch
