Codec {audio} probleem
lmk43
4 mrt 2006
Ik heb een probleem met sommige videos in Vista.{Schokkerig en traag}
Ik heb ook audioproblemen met dezelfde videos in Windows 98Se.
Ze spelen goed in Windows 98SE maar hebbben geen audio.Deze zouden wel audio moeten hebben in Windows 98SE en Vista
Probleem{Qua audio} in Windows 98SE
Windows Media Audio 9.1
16 kbps, 16 kHz, mono 1-pass CBR
8 kbps, 8 kHz, mono (A/V) 1-pass CBR
32 kbps, 32 kHz, stereo (A/V) 1-pass CBR
Geinstalleerde codecs in Windows 98SE
Video Compression Codecs
3ivxVfWCodec{3iv2}
AVImszh Compressor and Decompressor
AVIzlib Compressor and Decompressor
Cinepak{TM}
DivX5.1.1 Codec???
DivX{MPEG-4 {FAST-MOTION}
DivX{MPEG-4 {LOW-MOTION}
DivX Codec 4.01
Huffjuv lossless codec
Indeo{TM}R3.1
Indeo{TM}R3.2
Indeo Video 5.04???
Indeo v4.51 16.2 Ineractive code
Intel I.263 Video Driver 2.55.012{i263}
Intel IndeoVideo 4.3{IV40}
Ir32_32{IV32}???
LEAD MCMP/MJPEG Codec
Ligos IndeoXP Video 5.2
MS-MPEG-4 Video Codec V1
MS-MPEG-4 Video Codec V2
MS-MPEG-4 Video Codec V3
Microsoft Windows Media Video 9
msh261 {M261}
msh263{M263}
msyuv {UYVY}
msyuv {YUY2}
msyuv {YVYU}
On2 VP3
ON2 VP60 {Simple Profile}
On2 VP61 {Advanced Profile}
On2 VP62 {Advanced Profile}
RLE
VDOnet VDOWave Video Codec
VFAPI Reader Codec 1.01
Video 1
Xvid v1.03
Audio Compression Codecs
Lernout & Hauspie CODECs
Microsoft IMA ADPCM CODEC
Microsoft ADPCM CODEC
MIcrosoft GSM 6.10 Audio CODEC
Microsoft CCITT G.771 A-Law and u-Law CODEC
DSP Group TrueSpeech{TM} Software CODEC
Microsoft G.723.1 CODEC
Indeo audio software
Windows Media Audio
Sipro Lab Telecom ACELP.net audio codec
MPEG Layer-3 Codec {professional}
Ogg Vorbis Audio CODEC
Lame MP3 Codec v9.0 - 3.96{stable}
DivX WMA Audio Compressornew
Fraunhofer IIS MPEG Layer-3 Codec{advanced}
Lame MP3 Encoder ACM Codec???Missing
Intel Music Coder
Microsoft PCM Converter
Windows Media Player Version 11.0.6000.6324
Geinstalleerde codecs in Windows Vista
Video Codecs
Type Name Format Binary Version
ICM Microsoft RLE MRLE msrle32.dll 6.0.6000.16386
ICM Microsoft Video 1 MSVC msvidc32.dll 6.0.6000.16386
ICM Microsoft YUV UYVY msyuv.dll 6.0.6000.16386
ICM Intel IYUV codec IYUV iyuv_32.dll 6.0.6000.16386
ICM Toshiba YUV Codec Y411 tsbyuv.dll 6.0.6000.16386
ICM Cinepak Codec by Radius cvid iccvid.dll 1.10.0.12
ICM XviD MPEG-4 Codec XVID
ICM DivX ;-) MPEG-4 Low-Motion DIV3 DivXc32.dll 4.1.0.3927
ICM DivX ;-) MPEG-4 Fast-Motion DIV4 DivXc32f.dll 4.1.0.3917
ICM 3ivx D4 4.5.1 Pro Video Codec 3IV2 3ivxVfWCodec.dll 4.5.1.30
ICM Huffyuv v2.1.1 - CCESP Patch v0.2.5 HFYU huffyuv.dll 2.1.1.1
ICM Indeo® video 5.10 IV50 Ir50_32.dll 5.2562.15.55
ICM Intel I.263 Video Driver 2.55.012 I263 i263_32.drv 2.55.1.12
DMO Mpeg4s Decoder DMO mp4s, MP4S, m4s2, M4S2 mp4sdecd.dll 11.0.6000.6324
DMO WMV Screen decoder DMO MSS1, MSS2 wmvsdecd.dll 11.0.6000.6324
DMO WMVideo Decoder DMO WMV1, WMV2, WMV3, WMVP, WVP2, WMVR, WMVA, WVC1 wmvdecod.dll 11.0.6000.6324
DMO Mpeg43 Decoder DMO mp43, MP43 mp43decd.dll 11.0.6000.6324
DMO Mpeg4 Decoder DMO MPG4, mpg4, mp42, MP42 mpg4decd.dll 11.0.6000.6324
MPEG/DVD Filters
Type Name Binary Version
video Ligos MPEG Video Decoder mpeg2Decoder.ax 1.3.0.82
video Nero Video Decoder nevideo.ax 4.5.17.1
video Nero DVD Decoder nevideo.ax 4.5.17.1
video Microsoft MPEG-2 Video Decoder msmpeg2vdec.dll 11.0.5840.6324
video Nero Video Decoder HD nevideohd.ax 4.5.17.1
video CBVA DMO wrapper filter cbva.dll 6.0.6000.16386
audio ffdshow Audio Decoder ffdshow.ax 1.0.2.3
audio Ligos MPEG Audio Decoder lmpgad.ax 4.0.0.77
audio Nero Audio Decoder 2 neaudio2.ax 4.5.17.1
audio Microsoft MPEG-1/DD Audio Decoder msmpeg2adec.dll 11.0.5840.6324
Plug-ins
Background Morgan Stream Switcher
Audio Codecs
ACM Microsoft IMA ADPCM CODEC 0011 imaadp32.acm 6.0.6000.16386
ACM Microsoft CCITT G.711 A-Law and u-Law CODEC 0007 msg711.acm 6.0.6000.16386
ACM Microsoft GSM 6.10 Audio CODEC 0031 msgsm32.acm 6.0.6000.16386
ACM Microsoft ADPCM CODEC 0002 msadp32.acm 6.0.6000.16386
ACM Fraunhofer IIS MPEG Layer-3 Codec (decode only) 0055 L3codeca.acm 1.9.0.401
ACM Intel Music Coder 0401 imc32.acm 4.1.2.7
ACM AC-3 ACM Decompressor 2000 ac3acm.acm 0.8.0.0
ACM DivX WMA Audio Compressor 0161 DivXa32.acm 4.2.0.0
ACM Windows Media Audio 0161 DivXa32.acm 4.2.0.0
ACM Ogg Vorbis Audio CODEC 6771 vorbis.acm 0.0.3.0
ACM Microsoft PCM Converter 0001
DMO WMAudio Decoder DMO 0160, 0161, 0162, 0163 WMADMOD.DLL 11.0.6000.6324
DMO WMAPro over S/PDIF DMO 0162 WMADMOD.DLL 11.0.6000.6324
DMO WMSpeech Decoder DMO 000A, 000B WMSPDMOD.DLL 11.0.6000.6324
DMO MP3 Decoder DMO 0055 mp3dmod.dll 11.0.6000.6324
Kan iemand me helpen
LMK43
Denk je dat iemand die waslijst leest?:shocked:
Gooi alle codecs eraf, dus deïnstalleren via apparaatbeheer, dan alle bestanden met de extensie ax uit windows en windows\system32, wel eerst in de mapopties zo zetten dat je alles kunt zien, installeer na een reboot het K-Lite Mega Codec Pack maar wel de goede codecs en filters, die voor mpeg en mpeg2, DivX en Xvid, AC3 en booster, mp3, QuickTime en RealTime, geen FFDShow filters installeren en de players ook niet.
Mocht je wat missen, kun je die er later gewoon bij installeren, en met de diverse tools kun je de codecs controleren en kijken wat er gebruikt wordt bij de divers films met G-Spot.
Sorry voor de waslijst.IK dacht dat het een codec-probleem was maar het probleem zit denk ik hierin dat alleen de filmpjes met deze properties problemen geven{Zie onder}.Dezelfde problemen by Windows 98SE en by Windows Vista
Ik denk dat het daaraan ligt.Ik heb al de codecs van k-lite eraf gegooid en nog geen geluid
LMK43
Je hebt alle codecs van K-Lite eraf gegooit?
Kijk een met dat eerder genoemde tooltje welke codec je precies nodig hebt.
Misschien dat een herinstallatie van WMP zou kunnen helpen.
K-lite 3.4.0 geinstalleerd en Nero neemt de mpg-files over.Niet de bedoeling.Wil de mpg-files spelen op Windows Mediaplayer.Welke codecs moet ik wel en welke niet installeren zodat ik de mpg files op mijn mediaplayer hou???
Bij de opties van Mediaplayer kun je aangeven welke files WMP dient af te spelen, die setting vind je ook als je dat codec pack installeerd, daar wordt die vraag ook gesteld.
