Cumulative Patch for Internet Explorer (818529)
virtually
16 mrt 2002
Microsoft Security Bulletin MS03-020 Print
Originally posted: June 4, 2003
Summary
Who should read this bulletin: Customers using Microsoft® Internet Explorer
Impact of vulnerability: Allow an attacker to execute code on a user’s system
Maximum Severity Rating: Critical
Recommendation: System administrators should install the patch immediately
End User Bulletin: An end user version of this bulletin is available at:
http://www.microsoft.com/security/security_bulletins/ms03-020.asp.
Affected Software:
Microsoft Internet Explorer 5.01
Microsoft Internet Explorer 5.5
Microsoft Internet Explorer 6.0
Microsoft Internet Explorer 6.0 for Windows Server 2003
Technical details
Technical description:
This is a cumulative patch that includes the functionality of all previously released patches for Internet Explorer 5.01, 5.5 and 6.0. In addition, it eliminates two newly discovered vulnerabilities:
A buffer overrun vulnerability that occurs because Internet Explorer does not properly determine an object type returned from a web server. It could be possible for an attacker who exploited this vulnerability to run arbitrary code on a user's system. If a user visited an attacker’s website, it would be possible for the attacker to exploit this vulnerability without any other user action. An attacker could also craft an HTML email that attempted to exploit this vulnerability.
A flaw that results because Internet Explorer does not implement an appropriate block on a file download dialog box. It could be possible for an attacker to exploit this vulnerability to run arbitrary code on a user's system. If a user simply visited an attacker’s website, it would be possible for the attacker to exploit this vulnerability without any other user action. An attacker could also craft an HTML email that attempted to exploit this vulnerability.
In order to exploit these flaws, the attacker would have to create a specially formed HTML email and send it to the user. Alternatively an attacker would have to host a malicious web site that contained a web page designed to exploit these vulnerabilities. The attacker would then have to persuade a user to visit that site.
As with the previous Internet Explorer cumulative patches released with bulletins MS03-004 and MS03-015, this cumulative patch will cause window.showHelp( ) to cease to function if you have not applied the HTML Help update. If you have installed the updated HTML Help control from Knowledge Base article 811630, you will still be able to use HTML Help functionality after applying this patch.
Mitigating factors: The following mitigating factors apply to both vulnerabilities discussed in this bulletin:
By default, Internet Explorer on Windows Server 2003 runs in Enhanced Security Configuration. This default configuration of Internet Explorer blocks these attacks. If Internet Explorer Enhanced Security Configuration has been disabled, the protections put in place that prevent these vulnerabilities from being exploited would be removed.
In the Web based attack scenario, the attacker would have to host a web site that contained a web page used to exploit these vulnerabilities. An attacker would have no way to force users to visit a malicious web site outside of the HTML email vector. Instead, the attacker would need to lure them there, typically by getting them to click on a link that would take them to the attacker's site.
Code that executed on the system would only run under the privileges of the logged in user.
En hierbij de download link, wel eerst de gewenste taal selecteren
http://www.microsoft.com/windows/ie/downloads/critical/818529/default.asp
Hij is trouwens ook via de reguliere update te halen
http://v4.windowsupdate.microsoft.com/nl/default.asp
Groetjes
Bedankt virtually,
Ik kreeg hem al binnen via Microsoft critical update, dus hij werd automatisch geinstalleerd bij me.
m$ critical update
Critical update en automatisch geïnstalleerd, dat is handig.
heb je de link??
groetjes
The Critical Update Notifier
To install the Critical Update Notifier:
1.Click on the 'Start' button.
2.Click on 'Windows Update' option (near the top of the menu).
3.This will open an Internet Explorer window pointed to Microsoft's product updates page. Click on the 'Product Updates' link.
4.Click the box marked 'Keeping Windows Up-to-Date Automatically' or 'Critical Update Notifier' (this procedure works with Windows 95, 98, Me, NT, 2000 and (presumably) XP computers, however notation differs slightly between operating systems)
5.Click 'Download' and follow the given instructions.
After installation, you will receive a notification of all new security updates. The notice will give you the option to install the fix.
Stap 1 en 2 lukken niet, ik heb daar de windows update verwijderd, maar dan zou het nog moeten lukken toch...
Ik kan wel bij Windows 2000 pro de automatische updates inschakelen, is dat hetzelfde als de critical update notifier??
Groetjes
bij mij was ie ook van zelf al binnen gekomen, maar dan via de Automatische update van Windows Zelf. (kan je aan zetten in XP en 2k en onder eerdere OS en geeft ie wel melding dat er updates zijn, hij download ze alleen niet)
wat heb je dan aan zo een extern programma wat alleen maar resources vreet? (gewoon benieuwd waarom jullie het gebruiken)
*edit* ow zie nu pas dat we over het zelfde praten :P maar dat kan je toch ook gewoon simpel aanzetten door rechts op deze computer te klikken en eigenschappen en het dan bij tab update aan te zetten?
sith warrior bedankt voor je reactie, ik neem aan dat het over "deze" gaat, zie bijlage.
Deze staat bij niet in de eigenschappen v.d. compu, maar in het config.scherm, ik heb dan Win2000pro, jij waarschijnlijk XP?
Verder heb ik de neiging om alles wat automatisch verbinding zoekt naar updates uit te schakelen, dus zo ook bij windows.
Via andere kanalen ben ik toch meestal eerder op de hoogte van een lek dan windows.....
Maar dit is dus hetzelfde als die "Critical Update Notifier", kreeg nl. de indruk dat het een ander "programmaatje" was.
Groetjes
    24,1 KB · Weergaven: 20
Dit is trouwens ook de eerste patch voor Windows server 2003.
