Je zou ze direct uit de database zo kunnen halen
[sql]
SELECT DATE_FORMAT(date, '%w %d %M %Y')
FROM tabel
[/sql]
http://dev.mysql.com/doc/refman/5.0/en/date-and-time-functions.html#function_date-format
Die zal echter altijd in het engels zijn.
Kijk eens naar de PHP functie date.
Ik zou zoiets proberen:
PHP:$date = "2009-08-17"; echo date ("l dd F YYYY", strtotime ($date));
Dat ie volgens jou niet werkt komt omdat er geen AS {iets} achter staat.
$date = mysql_query("SELECT DATE_FORMAT(datum, '%W %d %M %Y') AS datum FROM `revie` ORDER BY `id` DESC LIMIT 1");
$only = mysql_fetch_object($date);
echo $only->datum;
Ik zei toch ook:
Dus
PHP:$date = mysql_query("SELECT DATE_FORMAT(datum, '%W %d %M %Y') AS datum FROM `revie` ORDER BY `id` DESC LIMIT 1"); $only = mysql_fetch_object($date); echo $only->datum;
$language['nl']['days'][] = 'Zondag';
$language['nl']['days'][] = 'Maandag';
$language['nl']['days'][] = 'Dinsdag';
$language['nl']['days'][] = 'Woensdag';
$language['nl']['days'][] = 'Donderdag';
$language['nl']['days'][] = 'Vrijdag';
$language['nl']['days'][] = 'Zaterdag';
$language['nl']['month'][] = 'Januari';
$language['nl']['month'][] = 'Februari';
$language['nl']['month'][] = 'Maart';
$language['nl']['month'][] = 'April';
//etc
$query = "SELECT DATE_FORMAT(datum, '%w-%e-%c-%Y') as datum FROM revie";
$result = mysql_query($query);
if(!$result) {
echo 'Er is een fout opgetreden! MySQL zegt: '. mysql_error();
} else {
while($row = mysql_fetch_assoc($result)) {
$date = explode('-', $row['datum']);
echo $language['nl']['days'][$date[0]] .' '. $date[1] .' '. $language['nl']['month'][$date[3]-1] .' '. $date[4];
$queryr = "SELECT DATE_FORMAT(datum, '%w-%e-%c-%Y') as datum FROM revie ORDER BY `id` DESC LIMIT 1";
$result = mysql_query($queryr);
if(!$result) {
} else {
echo ' '.$language['nl']['days'][$date[0]] .' '. $date[1] .' '. $language['nl']['month'][$date[3]-1] .' '. $date[4];
